Dodge Cummins Diesel Forum - View Single Post - Need some help
Thread: Need some help
post #2 of (permalink) Old 06-15-2018, 09:02 PM
thrashingcows
thrashingcows's Avatar
I highly doubt it would be a direct fit. Most likely the connection to the throttle pedal will be totally different, as well as the clip for where it passes through the firewall, and then the cable may be too long/short to mate up with the throttle lever on the IP.
Check out car-part.com they link 1000's of junkyards all over north america....might be able to find what you need?
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
