Dodge Cummins Diesel Forum - View Single Post - How to remove rear brake drum on '92 Dodge D250 3/4 ton
post #6 of (permalink) Old 06-02-2018, 01:56 PM
myother4x4isaCJ7
myother4x4isaCJ7's Avatar
Originally Posted by NIsaacs View Post
The reason the brake locks up, is there is probably a leak in the wheel seal or wheel brake cylinder and has gotten on the brake shoe. If there is, you will need to replace the shoes because you can't clean them enough to not lock up, and of course fix the leak.
Nick
I second this, I actually suggested that to him in another thread. Pretty common issue with drum brakes.
myother4x4isaCJ7 is offline
The Following User Says Thank You to myother4x4isaCJ7 For This Useful Post:
thrashingcows (06-02-2018)
