Dodge Cummins Diesel Forum - View Single Post - How to remove rear brake drum on '92 Dodge D250 3/4 ton
post #4 of (permalink) Old 06-02-2018, 07:19 AM
Jim L
Make sure you hold back the adjusters and back them off all of the way or you might never get the drum off if the shoes touch the drum.
Be careful you do not damaged the seals when lift the drum back on to the axle tube,
You will see once you have it apart.
Jim
Jim L is offline
