Dodge Cummins Diesel Forum - View Single Post - nv4500 problems
Thread: nv4500 problems
post #13 of (permalink) Old 09-29-2017, 09:35 PM
colin91
Armchair Mechanic
colin91's Avatar
Most dodge dealers keep the synotorque in stock. Just give them the molar number I posted earlier and they can get it either way. It's expensive but worth the pain of replacing syncros if you use the wrong stuff. I've seen the aftermath of having amsoil in these transmissions for a relatively short amount of time. Not worth the lower cost or availability of other "equivalent" oils
1996 2500 ECLB, NV4500, 4X4
Engine: 24 Valve P-Pump Swapped, Crowler Springs, Adj. Timing Gear @ 20*, Haisley L19 studs, DAP 3 Piece Mani, Fluidampr, Southbend DD3250, 5" Exhaust+FTE Resonator
Air: HE351VE w/ Banshee Controller
Fuel: 215HP P7100, Infinite Performance 6x11 VCO, Scheid Conversion Lines, PDD 055s, AirDog II 165, Dual Feed, #0 plate, 4K GSK
Suspension: Thuren 3" Coils, Thuren Sway Bar, DOR Track Bar, DOR Shackle Flip, DOR Extreme Bent Long Arms, Synergy Steering, Fox 2.0 IFPs, Yukon Hub Conversion, Dynatrac BJs, 37x12.5x17 Toyo M/T's on H2s
colin91 is offline
