Dodge Cummins Diesel Forum - View Single Post - Build your own head studs..
post #5 of (permalink) Old 04-14-2016, 02:57 PM
colin91
Armchair Mechanic
colin91's Avatar
Originally Posted by Cat-Black View Post
Are ARP studs threaded fully or no?
And no I can't match their quality per say but makes me wonder if their threads are roll formed or cut, makes a big difference.
Either way I guess my made up studs would be a step above bolts....
They are not threaded fully and have coarse thread on the block end and fine thread for the 12pt nuts.
1996 2500 ECLB, NV4500, 4X4
Engine: 24 Valve P-Pump Swapped, Crowler Springs, Adj. Timing Gear @ 20*, Haisley L19 studs, DAP 3 Piece Mani, Fluidampr, Southbend DD3250, 5" Exhaust+FTE Resonator
Air: HE351VE w/ Banshee Controller
Fuel: 215HP P7100, Infinite Performance 6x11 VCO, Scheid Conversion Lines, PDD 055s, AirDog II 165, Dual Feed, #0 plate, 4K GSK
Suspension: Thuren 3" Coils, Thuren Sway Bar, DOR Track Bar, DOR Shackle Flip, DOR Extreme Bent Long Arms, Synergy Steering, Fox 2.0 IFPs, Yukon Hub Conversion, Dynatrac BJs, 37x12.5x17 Toyo M/T's on H2s
colin91 is offline
