Dodge Cummins Diesel Forum - View Single Post - Rattle not in sync with the engine..driving me nuts, help!
post #9 of (permalink) Old 12-25-2015, 11:05 AM
7492
7492's Avatar
Originally Posted by N of 60 View Post
There is no timing to set on the pump per say.
No, you are wrong. There is an install procedure. The quickest place you might have access to is the FSM Dodge manual somebody on this forum created. The procedure is on page 7080. Cummins installs the pump in much same way when new. If the pump were install wrong, it would be the one in a million. The other choice would be that a previous owner having the pump off, and also did not know that there is a correct install procedure.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
2020 KW T370 PX9 380HP 1250lbft @ 1400 RTO14908LL
7492 is offline
