Greasing front drive shaft? - Dodge Cummins Diesel Forum
 57Likes
post #1 of 83 (permalink) Old 09-11-2019, 03:35 PM Thread Starter
I've watched several You Tube videos on how to grease the front drive shaft. None of them are on a 2019 model. It would appear that the u-joint has changed from previous years. The new joint no longer looks like a conventional u-joint. The owners manual still calls for you to lube it at each oil change, but I am at a loss of how or where to lube it. I do not see any serviceable fittings. Have any of you serviced this joint? Help! There is a conventional looking u-joint on the end connecting to the front differential, but it is not serviceable. The joint on the end connecting to the transfer case is the one in question.
2019 Laramie 2500 Crew
Sod Farmer is online now
post #2 of 83 (permalink) Old 09-11-2019, 03:46 PM
I'll take a look at mine when I get home, but I'm sure it's the same double-cardan joint that's been used for ages at the transfer case end. The intent is to grease the ball and cup portion of the cardan joint. The factory u-joints are typically sealed non-greasable joints.
You have to use a needle nozzle on your grease gun because a conventional zerk fitting won't clear the yokes/u-joints.
Sent from my SM-G950U using Tapatalk
ZRojas is online now
post #3 of 83 (permalink) Old 09-11-2019, 04:41 PM Thread Starter
Please do take a look. The joint is round and shielded. There are no knuckles. I've seen the needle fittings on other u-joints and this one doesn't appear to have any. Everything is smooth and rounded.
post #4 of 83 (permalink) Old 09-11-2019, 05:11 PM
I uploaded the pages from the service manual for lubricating the front drive line. It isn't any different than any other I have experienced since my 1977 Dodge Powerwagon. I will get back home Friday night from this work trip and physically look at my truck, but this is all I can give you right now.
The Following User Says Thank You to ZRojas For This Useful Post:
Sod Farmer (09-11-2019)
post #5 of 83 (permalink) Old 09-11-2019, 05:35 PM
KATOOM's Avatar
Starting in 2014 the Rams come with CAD front axles which means your driveshaft isnt spinning at road speed while in 2wd... There's no reason to grease them very often, it at all, unless you're using 4wd all the time.
KATOOM is offline
post #6 of 83 (permalink) Old 09-11-2019, 05:57 PM Thread Starter
My 2019 does not have a double-cardan joint on the rear of the front drive shaft. It looks completely different.
post #7 of 83 (permalink) Old 09-11-2019, 05:58 PM
Drle's Avatar
At oil changes. Still spins out grease, at least its not dry.
2015 SLT 3500 CC 68/3.42 SRW Ashtray Delete / EVIC Metric System Deletes 4X4 Bright White with tongue firmly in cheek
Drle is offline
post #8 of 83 (permalink) Old 09-11-2019, 06:04 PM
KATOOM's Avatar
There's no way for the grease to physically spin out. Especially since its not spinning while in 2wd. If spinning forces caused u-joints to run dry then they wouldnt last a day.
The only reason to add grease to u-joint caps is to push out any contaminants...if any. This is why non-greaseable u-joints are far superior to greaseable.
KATOOM is offline
post #9 of 83 (permalink) Old 09-11-2019, 06:16 PM
Drle's Avatar
Leave a blob on the inlet when the needle pulls out it will.
Me being lazy i guess.
Am finding that greasing at every oil change may be overkill...
Drle is offline
post #10 of 83 (permalink) Old 09-11-2019, 06:23 PM
the man in black's Avatar
The grease is for the ball and socket not the u joint. Curious if they actually changed the design for the 19s although most dealers say there has never been a grease point on the driveshaft.
Lins likes this.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is online now
post #11 of 83 (permalink) Old 09-11-2019, 06:49 PM
Jimmy N.'s Avatar
You made me go out and look. After a quick glance (it's raining), yes, it's not a typical CV-joint like on the earlier models.
Hard to tell since it's enclosed, but could be an Rzeppa style.
the man in black likes this.
Jimmy N. is offline
post #12 of 83 (permalink) Old 09-11-2019, 07:12 PM
I'm surprised of all people, you dont know the answer on whether it needs greased or not. Slacker
Jimmy N. and Sod Farmer like this.
