5.0 Cummins from the Titan - Dodge Cummins Diesel Forum
 3Likes
  • 2 Post By ironpony
  • 1 Post By MT Dodge Cummins Lifer
post #1 of 7 (permalink) Old 09-08-2019, 10:47 PM Thread Starter
Marct's Avatar
Now that Nissan is dropping the 5.0L from the Titan, it would be great if Ram would pick it up as a less expensive diesel for the 2500 with a 14-15000 lbs towing capacity and better fuel mileage.
Would this sell? I for one would be very interested.
2019 2500 Laramie 6.7L Cummins
2013 2500 Laramie 6.7L Cummins - SOLD
Marct is offline
post #2 of 7 (permalink) Old 09-08-2019, 10:54 PM
AR15's Avatar
I believe 10,990 to 12,640 lbs was the towing capacity in a Titan how could it be 15,000 in a Ram? Not arguing just confused.
Black 2008, DRW, 4x4, QC, automatic, 4:10's.
Dark gray 05, 2500, 4X4, QC, 5 speed automatic, LLY, Duramax.
AR15 is offline
post #3 of 7 (permalink) Old 09-08-2019, 10:58 PM
ironpony's Avatar
That was from a chassis suspension stand point, they were a heavy half ton not a 3/4 ton.
Also the motor never really performed to its potential MPG wise.
The 6.7 is comparable/better MPG and has double the power range.
N of 60 and Gr8bawana like this.
2002 2500 Quadcab LB 4X4 NV5600 HO stock
2012 3500 SRW Crewcab LWB 4X4 Auto 6.7 HO stock
ironpony is offline
The Following User Says Thank You to ironpony For This Useful Post:
N of 60 (09-08-2019)
post #4 of 7 (permalink) Old 09-08-2019, 11:24 PM
N of 60's Avatar
There is nothing special about that motor for power or efficiency. Let alone unable to start in normal winter conditions. Several parked CTD Nissan’s in driveways here all winter long.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.High tech old school and finally lovin it.
N of 60 is offline
post #5 of 7 (permalink) Old 09-08-2019, 11:55 PM
Owned one of the ealier ones and wouldn't have purchased it other than it was over 10,000 less than a similar equipped Ram at the time. As was previous mentioned it was under powered (310 hp 555 ft lbs. torque), got worse mileage than my 18 Ram 2500, and had cold start issues and wouldn't start without being plugged in below -5 degrees. Even worse when both manufacturer and dealers have no working knowledge of diesels. Overall it"s nothing special and I wouldn't see any reason for Ram to pick it up as the 6.7 is all around a better motor.
Gr8bawana likes this.
MT Dodge Cummins Lifer is offline
post #6 of 7 (permalink) Old 09-09-2019, 12:19 AM
El Pozzinator's Avatar
The ISV5.0 is a bus engine. Been in service for well over a dozen years in bus trim. Problems have arisen with packaging constraints in the Titan added to nissan’s NVH requirements, lack of an exhaust brake, and overbearing EGR / SCR which the engine wasn’t designed for. Sorta like trying to make a marathoner breathe thru a twisty straw...
I think it’d really wake the heck up with a better turbo and tuning, but i think a lot of people weren’t willing to gamble with the price they wanted for the darn things.
I was all in if I could get my hands on the Platinum Reserve tester the Nissan corporate folks were driving for ~$30k, but $50-60k+, in a manufacturer with under 15% market share and zero domestic diesel experience, is a BIG ask.
08 Resistol. Anarchy EFI, 5" TBE, grid delete, fleabay elbow, Sinister coolant filter, Carbonite DP sensor, CSS -4" springs, reverse level, CalTracs, Amsoil bypass filter, Revmax VB/TCM, Mishimoto stock replacement radiator.
El Pozzinator is offline
post #7 of 7 (permalink) Old 09-11-2019, 05:45 PM Thread Starter
Marct's Avatar
All good points, thanks for the replies.
Marct is offline
