CP4 Thread - Page 16 - Dodge Cummins Diesel Forum
 149Likes
post #181 of 245 (permalink) Old 09-19-2019, 09:49 PM
cumminsturbofreak's Avatar
Originally Posted by steve05ram360 View Post
something like what they did with the TDI's?
https://www.germandieselmotorwerks.c...onversion-kit/
^That's after Warranty if nothing is fixed by Chrysler by then.
I'm talking about what has been made for the furds:
https://www.dieselpowerproducts.com/...werstroke.aspx
I have a broken 2019 truck.
2004.0 3500 2WD Allison 1000 6 speed Swap,4th Gen Interior, Smarty UDC Pro Tuned by Me
cumminsturbofreak is online now
post #182 of 245 (permalink) Old 09-19-2019, 10:50 PM
akhr's Avatar
Just came across this on tdr. Glad have a 4th gen g56. Hopefully the new rams won’t have the same issues but going to wait on getting into one. Also bummed out they ditched the g56 but wasn’t surprised. It was only a matter of time.
https://www.dieselarmy.com/news/gm-l...diesel-trucks/
akhr is online now
post #183 of 245 (permalink) Old 09-20-2019, 01:20 AM
Really, I have found that every generation of truck has their pronounced issues.
03-04 had valve seats dropping, 04.5-07.0 had melted pistons due to silent but deadly injectors, 07.5-12 had emissions problems galore, 2003-2005 had melted ignition switches+cracked dashes, 1994-2008 had front end death wobble/ steering issues, and 06-12 had the dreaded TIPM. And that’s just touching on the problems with those trucks...
Looks like 13-18 was relatively safe with only some early SCR issues and vibration issues...
Of course, now we got the cp4 on the 19. We are always just trading problem A for problem B if you think about it.
10%more likes this.
post #184 of 245 (permalink) Old 09-20-2019, 03:26 AM
akhr's Avatar
Of course, now we got the cp4 on the 19. We are always just trading problem A for problem B if you think about it. [IMG class=inlineimg]https://www.cumminsforum.com/forum/images/smilies/smilies-2008/confused013.gif[/IMG]
My 2nd 24v gen been pretty reliable. Has 250k on it. Converter got burnt up (my fault) around 160k. Had whole trans built, been towing about 26k lbs combined for the past 90k miles with no issues. Burning thru brakes was my biggest expense towing that weight. New truck has exhaust brake so haven’t had to do brakes yet. Clutch did fail on new truck at 24 k miles but a dual disk and single mass flywheel fixed that. So far no other issues, was disappointed in the new trucks performance before the tuner was installed.
akhr is online now
post #185 of 245 (permalink) Old 09-20-2019, 09:25 AM
TECH SPECIALIST
steve05ram360's Avatar
Nothing is going to be fixed by Chrysler, I guarantee it. This pump has been in use since 2010, at the least, maybe earlier and it continues to fail in the same way it has from day one.
o be clear, this kit will not prevent the CP4 injection pump from failing, but what it will do is prevent failure of the rest of the fuel system in the event that it does fail. When the CP4 fails, metal particles from the fractured pump are forced to be sent throughout all secondary parts of the fuel system to include the fuel rails and injectors, most notably the injectors.
Fords, Chevy, Rams, VW's... all have this pump and all fail in the same nasty manor, its just a matter of time.
I do like their solution...
What the Disaster Prevention Kit does is reroute the direction of fuel that is responsible for lubricating the rotating assembly back through the factory fuel filters. Because of this, in the event the pump does fail, the contaminated fuel will be forced through both filters, which will capture these particles, inevitably saving your injectors.
I would still advocate using 2 stroke oil (or fav lube of choice) in the fuel. I used it on a TDI I had years back that had this pump and monitored the ash level in the DPF, no ill effects in the 50k miles I ran it with 2SO before selling it.
DIESEL_DRIVER_3500 likes this.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 428k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #186 of 245 (permalink) Old 09-20-2019, 02:24 PM
USMC8511's Avatar
Well, my pump just failed at 1,700 miles. They said it was the fact I was using Amsoil 2t oil in the fuel. I've never had anything go bad using Amsoil. They said I should have used the Amsoil fuel treatment for diesels instead. I was also adding just a splash of Marvel Mystery oil. And, at my first fill up I put just a we bit of DEF for extra lubrication. After replacement I will add a bit of fairy dust as well. I just knew reading all these comments would cause a catastrophic failure. I just can't believe it, no really, I just don't believe it happened to me.
Pearl White, 19 Ram 3500 CC LWB Laramie Longhorn 4X4-because it's a truck, Bone Stock 6.7 HO, AISIN, 5th Wheel/GN Prep, Thuren 1.75" coils and Fox 2.0 all around, Duratrac 285/75r18
Last edited by USMC8511; 09-20-2019 at 02:26 PM. Reason: Hopefully you all realize I am totally joking!
USMC8511 is offline
post #187 of 245 (permalink) Old 09-20-2019, 02:43 PM
10%more's Avatar
Man I'm glad you had that qualifier at the bottom. I was born pretty stupid and near eight decades later still wonder when "smart" starts. It took clean to the DEF lubricant for my old brain to engage.
Friend has reported to me through another forum that he is aware of two CP4 failures in the 2019's. No substantiation on my part and I did not read the earlier posts on the topic here. A few have gone on the Ecodiesels but very few. One Ecodiesel just crossed the 600,000 mile mark (hard to believe but a transporter) with no pump issues.
I bought a 2019 and am aware of the possibility of having a survivor kit for the issue. If available the day after warranty runs out, I will have one.
USMC8511 and one2doo like this.
10%more is offline
post #188 of 245 (permalink) Old 09-20-2019, 06:50 PM
daemon's Avatar
I'm just going to slap some magnets on the CP4 and keep all those metal shavings in the pump. Problem solved.
2019 - 3500 Limited CCSB Aisin
daemon is offline
post #189 of 245 (permalink) Old 10-01-2019, 10:13 PM
S&S diesel performance is working on a CP3 conversion kit for the 2019+ platform....I may trade in my 2016 for a 2020+ if this does become available soon. Hard to dispute the proven track record of the CP3.....the CP4.2 is a deal breaker for me.
ID:	857605   Click image for larger version
89BLK5OH is offline
post #190 of 245 (permalink) Old 10-01-2019, 10:23 PM
Originally Posted by 89BLK5OH View Post
S&S diesel performance is working on a CP3 conversion kit for the 2019+ platform....I may trade in my 2016 for a 2020+ if this does become available soon. Hard to dispute the proven track record of the CP3.....the CP4 is a deal breaker for me.
Cancelled my order when I realized the 2019's used the CP4.2 pump. I will move forward as soon as a CP3 kit is available or Ram changes to something different.
RFairbairn likes this.
2004 3500 QC SB 4x4 SLT CTD HO 48RE 3.73 LS, Autometer Gauges (Pyro, Boost, Trans Temp), Mag Hytec DD Trans Pan and Rear End Cover
DIESEL_DRIVER_3500 is offline
post #191 of 245 (permalink) Old 10-02-2019, 12:31 AM
You see, the world will continue to spin after all.
post #192 of 245 (permalink) Old 10-07-2019, 09:58 PM
terb's Avatar
Just like a piston in the CP-4.........
cumminsturbofreak likes this.
2016 2500 Crew Cab Laramie 3.42 Auto
2014 2500 Crew Cab Laramie 3.42 Auto
2008 3500 SWR Quad Cab Laramie 4.10 Auto 5.7 Hemi "Whoops My Bad"
2006 2500 Quad Cab Big Horn 3.73 Auto..
2006 2500 Quad Cab Sport 3.73 Auto..
1998 2500 Club Cab Laramie 12V 3.55 Auto
terb is offline
