Exhaust Filter % in DIC - Dodge Cummins Diesel Forum
 2Likes
post #1 of 16 (permalink) Old 06-23-2019, 08:52 PM Thread Starter
Purplehayes's Avatar
Does anyone else's exhaust filter guage (0-100%) stay at 0 all the time even though I have been though a few regens. Wondering if the bar should be moving as the filter gets full or if I am missing something. Thanks
Purplehayes is offline
post #2 of 16 (permalink) Old 06-23-2019, 10:03 PM
US ARMY Retired
Cummins0867's Avatar
Mine has been at zero and I had a couple of regens the way you mention...until the other day it said about 1/3 full and went into a regen for about 25-30 highway miles and then it completed and went back to zero.
'19 Laramie 3500 CCSW SRW 4X4, Aisin 3:73's
SOLD: '17 Laramie 2500 CCSW 4X4 3.42's
SOLD: '11 Laramie 3500 CCSW SRW 4X4 3:73's
SOLD: '08 Laramie 2500 CCSW 4X4 3:73's "2Timothy1:7"
Cummins0867 is offline
post #3 of 16 (permalink) Old 06-23-2019, 11:00 PM
the man in black's Avatar
Why on earth would they add that gauge? Now people are going to be freaking out over. Wonder if it's actually linked to anything or fake like the oil pressure/temp.
gsbrockman likes this.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #4 of 16 (permalink) Old 06-24-2019, 08:52 PM Thread Starter
Why would you say that the oil pressure and temp guages are fake? Maybe the analog ones but not the digital ones. And why wouldnt you want more information than you need on your vehicle?
post #5 of 16 (permalink) Old 06-24-2019, 08:53 PM Thread Starter
I see. I will have to pay more attention. I usually just leave it on the temperatures page. Thanks
Cummins0867 likes this.
post #6 of 16 (permalink) Old 06-24-2019, 10:24 PM
The oil temp and pressure gauges in these trucks are fake. Unless you have aftermarket. The stock ones are 100% fake.
post #7 of 16 (permalink) Old 06-25-2019, 01:03 AM Thread Starter
so you dont believe that the oil pressure cold is around 50 psi and it drops to 35-45 depending on run condition when it gets warmer. I had a '17 duramax that was about the same, acted the same and was confirmed with and edge insight. Why would they make the guages fake?
post #8 of 16 (permalink) Old 06-25-2019, 01:35 AM
akhr's Avatar
Yes the oil pressure gauge is fake. It doesn’t read oil pressure just uses the oil pressure switch (over 5 psi) and computer algorithm. Chrysler is to cheap to install a real pressure sensor. This has been discussed and proven already. Don’t know about the oil temp. Also unless you installed a real pressure gauge edge insight is using what the computer is saying.
akhr is online now
post #9 of 16 (permalink) Old 06-25-2019, 09:09 AM
Cold pressure can be 75psi plus idle can be 20ish psi. As stated the oil pressure is actually just a switch and the ecm then gives you a number based on whatever it wants. My truck will hold 51psi from 1600rpm to 3000rpm. I believe the duramax has an actual pressure sender at least they used to.
post #10 of 16 (permalink) Old 06-25-2019, 10:08 AM
MC_Diesel's Avatar
I've experienced the same situation on mine. I've only got about 1,400 miles on my truck, but I've noticed that the exhaust filter gauge is always at 0%. I saw it once register about 30% and it went into regen shortly thereafter and back to 0%. I don't think this gauge is at all accurate.
2019 3500 SRW Mega Limited HO Cummins/Aisin
Sold: 2013 2500 Mega Laramie Longhorn
MC_Diesel is offline
post #11 of 16 (permalink) Old 06-25-2019, 08:38 PM Thread Starter
I see. Well I was under the wrong understanding but it makes sense. I guess it is just a good indicator of something goes wrong.
post #12 of 16 (permalink) Old 06-25-2019, 08:40 PM Thread Starter
Originally Posted by akhr View Post
Yes the oil pressure gauge is fake. It doesnít read oil pressure just uses the oil pressure switch (over 5 psi) and computer algorithm. Chrysler is to cheap to install a real pressure sensor. This has been discussed and proven already. Donít know about the oil temp. Also unless you installed a real pressure gauge edge insight is using what the computer is saying.
I see! Thanks for the information!
