Hood Vibration - Dodge Cummins Diesel Forum
 2Likes
post #1 of 14 (permalink) Old 06-12-2019, 02:49 AM Thread Starter
Zackolas's Avatar
Hood Vibration
I just took a 3000 mile round trip from southern California to Colorado in my new 3500. When I was driving back there were some pretty high winds and it looked as though my hood was unlatched. I was kinda of shocked by how much it moved with the wind considering it was fully latched. Has any one else experienced this yet? Mind you I was going 85MPH on some of the more desolate stretches of Utah. I never noticed this on my 16 2500.
Zackolas is offline
post #2 of 14 (permalink) Old 06-12-2019, 07:19 AM
whododat1's Avatar
I have a 19 1500 and there was a recall/tsb for the hood pins. Not sure what was done but maybe it will apply to the 2500's at some point. I would ask the dealer if there are any tsb's/ recalls for the 2500's yet. I just received notice for another recall on my 1500.
whododat1 is offline
post #3 of 14 (permalink) Old 06-12-2019, 09:52 AM
Dksimmon's Avatar
Ive noticed a vibration issue during high winds aswell. I pulled over to the side just to make sure and everything looked ok. I figured the hood has a little bit more flex since its aluminum
Dksimmon is offline
post #4 of 14 (permalink) Old 06-12-2019, 10:10 AM
Don_T's Avatar
I havenít noticed any of this on my Ď19 yet. Talk about hoods flapping in the wind, get a Jeep up to 80 and it is flapping like a flag in the wind.
Jimmy N. likes this.
2019 Ram 3500 Crew Cab Long Bed
Don_T is offline
post #5 of 14 (permalink) Old 06-12-2019, 11:35 AM Thread Starter
Zackolas's Avatar
I agree, granted I was going pretty fast but I was shocked with the amount of movement. Luckily it only happen in high winds and fast highway speeds.
Zackolas is offline
post #6 of 14 (permalink) Old 06-12-2019, 01:01 PM
Mine seems to move up/down a little bit going 80mph into a headwind as well.
OkieDan is offline
post #7 of 14 (permalink) Old 06-13-2019, 05:34 AM
Purplehayes's Avatar
Living in central Wyoming we get bad winds. When I drove my truck home from Idaho I noticed a slight shake as well. I pulled over to get fuel and popped the hood, the two stops on either side were not at the same height so I threaded the one that was lower to the same height as the one sitting higher. Seemed to help. Put more tension on the closing mechanism keeping it tight.
Purplehayes is offline
post #8 of 14 (permalink) Old 06-13-2019, 08:50 AM
US ARMY Retired
Cummins0867's Avatar
Mine does it too at higher speed and high winds. Also my Laramie has a red light on the dash if the hood is not closed all the way the light comes on as a reminder that the hood is open and not fully latched.
'19 Laramie 3500 CCSW SRW 4X4, Aisin 3:73's
SOLD: '17 Laramie 2500 CCSW 4X4 3.42's
SOLD: '11 Laramie 3500 CCSW SRW 4X4 3:73's
SOLD: '08 Laramie 2500 CCSW 4X4 3:73's "2Timothy1:7"
Cummins0867 is offline
post #9 of 14 (permalink) Old 06-14-2019, 07:55 AM
Mine too. Noticed immediately off lot from dealer and pulled over to check hood. It seemed tight so I chalked it up to the hood being so light.
A.Texas.Yankee is offline
post #10 of 14 (permalink) Old 06-14-2019, 08:06 AM
Does the hood rest on "pads" that can be adjusted to put some tension on the hood?
2012 RAM 6.7L HO CTD 3500 CCLB 4x4, stock 170,000, Supernova v4
xxwabbit is offline
post #11 of 14 (permalink) Old 06-14-2019, 05:59 PM
Yes it does. I mentioned adjusting them above. That seemed to help mine.
xxwabbit likes this.
post #12 of 14 (permalink) Old 06-15-2019, 08:20 PM
99dodge's Avatar
It's the light weight aluminum hood. If you go to the edge of the hood you will be able to put you fingers under it and lift the hood. You couldn't do that on a steel hood, or at least it would be more difficult. You can try to adjust the hood bump stops, it will help but won't eliminate it.
I had a 2017 F350 with the aluminum body and the hood would bounce like crazy at speeds greater than 70 MPH. I also adjusted the hood bump stops, it helped but the bouncing was still there whenever a big semi passed me. I hated it and returned to Ram. I purposely bought the 2018 model because I wanted a steel hood.
2018 Ram 2500 Limited Tungsten Edition, CTD
2017 Ford F-350 King Ranch CCSB, PSD
2016 Ram 2500 Longhorn CCSB. CTD
2011 Ram 2500 CCSB Big Horn, CTD
1999 Dodge Ram 2500, CTD
1988 Chevy 2500
1979 Chevy K10 Scottsdale
1975 GMC half ton
99dodge is offline
