Truck 1” higher on driver side - Dodge Cummins Diesel Forum
 13Likes
post #1 of 28 (permalink) Old 05-13-2019, 06:38 PM Thread Starter
lilbxl's Avatar
After replacing the drag link and an alignment, I just noticed the truck is 1” higher on the passenger side. I’m guessing this has to do with the alignment. Besides annoying the heck out of me, are there any wear issues I should be concerned with as I can’t get back right away to correct this issue?
'14 2500 Tradesman 4WD, 68RFE, all stock.
lilbxl is offline
post #2 of 28 (permalink) Old 05-13-2019, 06:42 PM
K9Kodi's Avatar
Take a look at your alignment cams. I’m willing to bet they are way off from one another.
Don_T, SRich12 and elkhunter6.jw like this.
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is online now
post #3 of 28 (permalink) Old 05-13-2019, 08:07 PM
7492's Avatar
Originally Posted by K9Kodi View Post
Take a look at your alignment cams. Iím willing to bet they are way off from one another.
You know , funny thing. I assume you are talking abut the caster adjustment. I noticed the other day while servicing mine, the two adjustments are very different. Yet my truck good. Only 18K on it, I think I'll leave the sleeping lay.
Cummins0867 likes this.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
09 Freightliner M2 33k GVW ISC 360/1050 RFO9210
7492 is offline
post #4 of 28 (permalink) Old 05-13-2019, 08:13 PM
K9Kodi's Avatar
Well stand by but I’ll be corrected if I’m wrong but I think to be identical in adjustment they need to be mirroring? Because they adjust opposite arms from opposite sides. My truck was leaning or rather sitting tall. It did bother me cause co workers pointed it out daily. I loosened the adjusted and it was under tension, adjusted it slightly and the other side to compensate, no issues with tire wear or steering and it sits level
post #5 of 28 (permalink) Old 05-13-2019, 10:36 PM
I had lean after an alignment,I printed out the Thuren and CJC info and had them do it again.
• Cross caster in these trucks can induce lean. If your truck is leaning when parked on a level surface, check to make sure your adjusters are pointing in the same direction.
• If you are running a quality lift coil, and it’s installed properly (I see them installed upside down or on the wrong side frequently), but you have a lot of coil bow, you probably need to rock those caster adjusters to the rear a bit.
• Pointing the adjuster toward the rear of the truck increases caster.
http://www.cjcoffroad.com/Articles.asp?ID=258
2013+ newer radius arm truck caster notes....
The adjustment cams are backwards on these trucks, compared to the solid axle Rams from the last 20 years. The cam bolt is actually inside and moving the axle itself, while the cam washers are located by the arms, unlike previous generations. This means moving the arrow on the cam to the rear of the truck, is increasing caster degree.
There is plenty of caster adjustment on these trucks to work with up to about 3.5" of lift, even with stock arms and no radius arm pivot drops.
It is VERY important on these trucks that you don't adjust the driver and passenger side cams too far out of balance. In other words, make sure there is not much manual cross caster. If one cam is for example pointed straight down, the opposite side cam should be no more than one mark forward or back. I have seen alignment shops do some crazy things here. If you do put them far out of balance, you can get some drastic lean in the suspension. Reason being, radius arms make the front axle act like one big swaybar. With the caster cams far out of balance, it gives a similar effect as having different length swaybar links, which would force a chassis lean. If you do need a little caster bias fine tuning, which is pretty normal, loosen the upper radius arm bolts at the axle also, then re-tighten once the handling is good. This will let the axle center up as best as it can, by using slop in the hardware to help the chassis find neutral.
With our 2.5" coils, the approximate good handling cam indicator position, is about the first mark to the rear of the truck.
https://www.thurenfabrication.com/te...-handling.html
14 2500/68rfe 4X4 CC SWB Tradesman 315/70/18 Toyo MT's
ARE DCU
2500/6 is offline
post #6 of 28 (permalink) Old 05-13-2019, 10:54 PM Thread Starter
lilbxl's Avatar
The passenger side cam is straight down and the drivers side is about 2 marks towards the front of the truck from the straight down position.
lilbxl is offline
post #7 of 28 (permalink) Old 05-13-2019, 11:00 PM
Lins's Avatar
2 marks isn’t terrible, usually they’re close to one or less. The leaning trucks seems to be from one cam facing forward and one backward.
Lins is online now
post #8 of 28 (permalink) Old 05-13-2019, 11:14 PM Thread Starter
lilbxl's Avatar
So Is there a way to know which side to adjust with out bringing the truck back to the shop? And can this be done at home?
lilbxl is offline
post #9 of 28 (permalink) Old 05-14-2019, 02:13 AM
Cummins Freak
SRich12's Avatar
Set the one that is 2 marks forward to straight down or 12:00. Can be done in your driveway with 24 MM and 27MM/28MM???? wrenches or sockets!!!
2018 Ram 2500 SLT Bighorn 4X4 White /295 Toyo AT2's /Full Console swop/w shifter / B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie Cummins, 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / B&W Turnover Ball / Center Console Swap w shifter SOLD!!!
SRich12 is offline
post #10 of 28 (permalink) Old 05-14-2019, 06:43 AM Thread Starter
lilbxl's Avatar
Can anyone describe to me how to do this?
lilbxl is offline
post #11 of 28 (permalink) Old 05-14-2019, 07:45 AM
K9Kodi's Avatar
Yes, loosen the nut, do not take it off. Only need a little bit of reversal on the nut. The head of the bolt is keyed into the adjusting washer so as you turn the bolt it adjusts the key. Put a big ol crows foot on the bolt, get the adjuster where you want it, hold it there and tighten the ens out of the nut. I would mark the spot it was at first Incase you need to reverse what you did
post #12 of 28 (permalink) Old 05-14-2019, 07:53 AM
K9Kodi's Avatar
This actually a pretty cool stupid video on caster for those who don’t understand
https://m.youtube.com/watch?v=t76BVhtBMnE
Similar Threads
2.5" Level spacers look different from driver to passenger side. yamaharider529 2013+ General Discussion 8 06-12-2016 12:29 AM
Turn signal help: driver side rear doesn't work. sayn3ver 89-93 Non-Powertrain 1 12-17-2014 10:23 PM
Help... Driver side Rear Tire locked up... JC1390 89-93 Non-Powertrain 19 05-22-2013 04:32 PM
driver side power mirror jneil 98.5-02 Non-Powertrain 2 04-30-2013 05:40 PM
Need help fast with bad wobble. 347strokin 4th Gen Non-Powertrain 14 12-10-2012 02:30 AM
