Battery question - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 04-15-2019, 12:44 PM Thread Starter
Battery question
For years i have needed 12v dc power in the bed of my trucks to run agitators in fish tanks in the bed and i have always essentially cannibalized a heavy duty extension cord and hooked it to my trucks battery positive and negative terminals and grounded the ground wire on a metal to metal bolt somewhere. Then run the cord to the bed of the truck to an outlet and mount it to a headache rack. This being my first deisel i am unsure which battery i need to use or if it matters. I went ahead and hooked it up to the drivers side and it seemed to work fine but im curious if the other battery would be better. Theres less stuff hooked up to the passenger side battery but theres also more hot parts on that side that i dont want the cord to be close to. Got ideas? Oh and ive had battery "professionals" tell me how im ruining the battery in my truck by doing this but trust me guys we.ve been doing it for years on many trucks and we have never once had a battery fail in an unusually short amount of time.
2018 ram 2500 tradesman 4x4 ctd short bed.
Headache rack
Toolbox
Abell34 is offline
post #2 of 13 (permalink) Old 04-15-2019, 01:08 PM
Ltngdrvr's Avatar
The truck's batteries are connected together in parallel, makes no difference which one you hook any accessories to.
But, as to 12v power in the bed, if you have the trailer prep, then there is a constant hot in the trailer plug that's already in the bed.
CCV reset/seatbelt chime disable
Ltngdrvr is offline
post #3 of 13 (permalink) Old 04-15-2019, 01:35 PM Thread Starter
I wish i had the trailer prep. But unfortunately i bought mine off the lot without it.
Headache rack
Toolbox
Abell34 is offline
post #4 of 13 (permalink) Old 04-15-2019, 02:12 PM
Ltngdrvr's Avatar
Well, all the trucks have the trailer plug in the bumper, you could tap into it there.
Ltngdrvr is offline
post #5 of 13 (permalink) Old 04-15-2019, 02:28 PM Thread Starter
True. May still do that thanks for the battery info.
Headache rack
Toolbox
Abell34 is offline
post #6 of 13 (permalink) Old 04-15-2019, 05:06 PM
I doubt thereís enough amperage in the trailer plug to run multiple aerators.
Jhenderson is offline
post #7 of 13 (permalink) Old 04-15-2019, 05:56 PM
Ltngdrvr's Avatar
Originally Posted by Jhenderson View Post
I doubt there’s enough amperage in the trailer plug to run multiple aerators.
It gets direct battery power, so should be as good as running a new wire to the battery. Has enough power to operate trailer brakes, hydraulic pumps that operate RV trailer slide outs, so should be enough.
Ltngdrvr is offline
post #8 of 13 (permalink) Old 04-15-2019, 06:45 PM
1st, those are each separate circuits from the 12 volt keyed circuit. 2nd the high amp trailer slide outs are powered by the trailer battery which is recharged from the keyed 12 volt circuit. Do you realize how long it takes for that light gage wire to transmit enough juice to recharge the trailer battery after the slides are all run in or out? 3rd we donít know how many amps the aerators draw.
post #9 of 13 (permalink) Old 04-15-2019, 07:45 PM Thread Starter
I also doubt that a tapped power source would be ideal. Hence the extension cord. Plus no wire splicing. It works fine as is. Ive wired them with and without fuses never had an issue i was just wondering if the batteries had different functions or as stated were just ran parralel for shared duty. Appreciate the knowledge
Headache rack
Toolbox
Abell34 is offline
post #10 of 13 (permalink) Old 04-15-2019, 07:47 PM
iTrader Score: 15 reviews
Maybe, maybe NOT....
The only way to tell for sure is by knowing what the amp load the OP wants to run off that circuit and then determine if the trailer plug charge wire is large enough to SAFELY handle that current.
Also importantly, given the sensitivity and complexity of the newer can bus elcrcial systems, IMO it would be best to run a separate fused wire from the batteries just to keep the oem trailer wiring safe from auxiliary loads so that just in case something happens to the added circuit/equipment, the trucks wiring remains safely functioning and undisturbed.
Just my .02
2005 SLT 4x4 QC LB G56, GDP horn, HDCAI, SBC ConOFE,
seafish is offline
post #11 of 13 (permalink) Old 04-15-2019, 08:07 PM
Ltngdrvr's Avatar
I run trailer slide outs often with no battery in the trailer, just plugged into the truck socket.
Ltngdrvr is offline
post #12 of 13 (permalink) Old 04-15-2019, 08:15 PM
"It works fine" is definitely different then adding electrical accessories and/or wiring safely with the understanding that when something with one of your air pumps/agitators DOES go wrong (dead short), you don't bunt your truck down with it.
That being said, of course it is your truck and your money so you should do as you wish.
seafish is offline
Similar Threads
Who has replaced 1 failed battery and how did it go. cjgoode 2013+ General Discussion 85 01-20-2018 03:14 PM
Question on connecting slow battery charger RayK 2013+ General Discussion 7 02-14-2016 03:18 PM
Battery charging question? maxwellxx 3rd Gen. Non-Powertrain 5 01-01-2016 11:12 AM
Battery Charge Question kingjohn1027 98.5-02 Powertrain 10 11-12-2011 06:46 PM
Battery Question DODGEOUTLAW 3rd Gen. Non-Powertrain 5 11-09-2011 05:25 PM
