Rear Differential Fluid Drain...Need Help - Page 5 - Dodge Cummins Diesel Forum
 42Likes
post #49 of 66 (permalink) Old 03-02-2019, 05:23 AM
towpro's Avatar
I think he pulled all the bolts, than pryed cover off and it dumped and made a mess. By leaving a couple bolts in you can control how fast it dumps when you break the seal
Jimmy N. likes this.
2018 Laramie Aisin 2wd 3:73
2016 Arctic Fox 990 Truck Camper
2018 Beta RR300 2015 KTM EXC 690R
towpro is offline
post #50 of 66 (permalink) Old 03-02-2019, 09:56 AM
Jimmy N.'s Avatar
Originally Posted by tankerpilot01 View Post
Safe to assume this applies to rear diff only (changing fluid at 500-1000 miles) Iíve never followed this procedure for the front diffs...double checking Iím not wrong with that technique!
Yep, the front doesn't do any work, normally. In theory I suppose that the original fluid would outlast the vehicle in most cases, but there has been several reports of milky looking fluid.
I'm guessing that due to the CAD, the spider gears spinning madly in there creates enough heat to help form condensation, but not enough to burn it off.
tankerpilot01 likes this.
'14 1500 V6, '17 3500 C&C, plus a '17 2500 in the household.
Jimmy N. is online now
The Following User Says Thank You to Jimmy N. For This Useful Post:
tankerpilot01 (03-02-2019)
post #51 of 66 (permalink) Old 04-20-2019, 12:44 PM
tankerpilot01's Avatar
So why in the hell did Ram use these? Of course I donít have the right tool for these fasteners.
Anybody know the size of these? Why couldnít they use a normal bolt? . I realize this when I get under truck to drain the fluid...s#%&
Rat
2018 3500 Limited Tungsten 4x4 Dually-True Blue Pearl - CC - 8'
tankerpilot01 is online now
post #52 of 66 (permalink) Old 04-20-2019, 02:14 PM
Jimmy N.'s Avatar
Torx fasteners are very common these days. You might as well get the correct sockets and bits, because you'll find many more Torx.
And it's not a Ram thing, by the way, but automotive in general.
post #53 of 66 (permalink) Old 04-20-2019, 06:33 PM
IIIIIIIIIIIIIIIIIIIIIIIII
Walker111's Avatar
You’ll need female/inverted/reverse torx bits for them.
https://m.sears.com/search=female%20torx%20socket
URDiesel likes this.
16 CTD 2500 Bright White Crew Cab
Walker111 is offline
The Following User Says Thank You to Walker111 For This Useful Post:
tankerpilot01 (04-20-2019)
post #54 of 66 (permalink) Old 04-20-2019, 06:36 PM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
https://www.cumminsforum.com/forum/2...id-change.html
2018 RAM 4500 Chassis Tradesman Crew Cab 60Ē C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Continental HDRís, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 133,388 miles and 2,339 hours as of May 13th, 2019 (Average Miles Per Hour = 57.0)
gsbrockman is offline
post #55 of 66 (permalink) Old 04-20-2019, 06:45 PM
Jimmy N.'s Avatar
Speaking of diffs, after the sixth cleaning of the magnetic plug in about 5,000 miles, now the debris caught on it is looking more like it should. In other words, not all that much.
Then again, until I pull the cover there's no telling how much the extra magnet I put down low on the cover has captured.
post #56 of 66 (permalink) Old 04-20-2019, 07:02 PM
Buyer of stuff..with OPM
Ram4Sam's Avatar
This reminds me of my younger days, in college, working at a dairy.......they gave the cows a small magnet to swallow, which stayed in their belly, to catch and hold any strays bits of wire from the hay bales.......
Sam
2016 3500 Laramie SRW 4x4 CC LB ,Aisin,white w/brn-beige,B&W TOB/companion built 9/2015
Owned and gone, 1991 d250
... 2001.5 2500qc
...2014 3500 FCA buyback
Drivin' a Dodge Cummins since 1991.......
2008 Thor jazz 2870UK 5er....and 4 dogs.....
Ram4Sam is offline
post #57 of 66 (permalink) Old 04-20-2019, 07:08 PM
lzhome's Avatar
I'm betting some of you won't agree but here is my video on the rear differential.
https://youtu.be/KDn8pQRARfI
2016 Ram 3500 4x4 Laramie CCSB 6.7L CTD
Andersen Ultimate Hitch, Timbrens, Fold-a-Cover, Aux Tank, Mag-Hytec, BlueDriver
lzhome is offline
post #58 of 66 (permalink) Old 04-20-2019, 08:55 PM
So Iíll change it before my trip. Then again prior to ďnormalĒ after doing some towing. As I think under severe duty amsoil says 50K with their severe gear 75W90. Not sure Iím comfortable if a lot of they was towing...to go 50K!
Changed rear diff today. Around 850 miles. Ready to tow around 7K to OK (750 miles) in a couple weeks.
Looks good as far as I can tell....assume to look for wear/nicks/cracks, etc. a little bit on magnet but not much. Just really fine particles...almost like dust.
Rat
post #59 of 66 (permalink) Old 04-21-2019, 04:00 PM
Jumpinjoe's Avatar
Iím sure this has been posted but Iím to lazy to look for it so here is my question, do the rams come with synthetic fluid in the diffs from the factory? Thanks for the replies
Jumpinjoe is offline
post #60 of 66 (permalink) Old 04-21-2019, 04:16 PM
BrianF's Avatar
Appears to be 75w85 synthetic. Doubt its group 4 or 5, probably group 3 but made by who knows.
2017 Ram 3500 Megacab, SLT, True Blue, SRW, CTD, AS69RC. Ubique
BrianF is online now
Similar Threads
Performing a Drain & Fill on the Aisin AS69RC Transmission gsbrockman 2013+ General Discussion 116 12-08-2018 10:38 PM
11.8 / 300mm AAM Rear Axle Fluid Change gsbrockman 2013+ General Discussion 123 02-10-2017 05:05 AM
Looking for advice for friend w/ 06 Fireman02 3rd Gen. Powertrain 63 12-05-2016 12:02 AM
2001 2500: Another bad automatic transmission defdes 911 Urgent Situations 5 01-31-2015 07:41 PM
What broke on your truck and when? cummins939 3rd Gen. Powertrain 46 03-12-2013 09:13 PM
