DPF active regen - Dodge Cummins Diesel Forum
 9Likes
post #1 of 20 (permalink) Old 02-01-2019, 11:01 PM Thread Starter
MRBcummins's Avatar
DPF active regen
Was wondering how often folks are seeing active dpf regens. I have 6k miles on my 18 and saw my first regen at about 3k and am seeing active regens about every 1200 miles since. Using stanadyne performance as I have on my other oil burners (non dpf) CTS II monitor indicates regens and monitors all othe vitals I care to watch.
MRBcummins is offline
post #2 of 20 (permalink) Old 02-02-2019, 08:08 AM
Right now I'm at about 900 miles between regens. (2016 with 37k on the truck)
2016 Ram 2500 Big Horn Mega cab, 285/75-18 (35's) Nitto Ridge Grapplers. Fuel Hostage III 18x9 +18 BS Wheels. Bilstein 2.3″ Front Lift, 1" rear spacer.
mtnrider is online now
post #3 of 20 (permalink) Old 02-02-2019, 08:48 AM
IIIIIIIIIIIIIIIIIIIIIIIII
Walker111's Avatar
That's roundabout where I am. I've noticed it gets shorter as time/miles goes.
16 CTD 2500 Bright White Crew Cab
Walker111 is online now
post #4 of 20 (permalink) Old 02-02-2019, 09:03 AM
hillbilli's Avatar
Thats about the average from what i have seen on the 6.7's. Just be glad you dont have an 3.0 Ecodiesel, Ive seen regens as low as 40 miles on stock programming, normally 75-300.
2011 CC non-HO
2014/2015 Ecodiesel GDE Tuned--Sold & 2007 5.9 MEGAcab w/Edge Evolution--Sold
USAF
hillbilli is offline
post #5 of 20 (permalink) Old 02-02-2019, 09:17 AM
RammerJam's Avatar
I've never seen an 'active regen'.
I get the funny smell every now and then when I get out of the truck, which I assume is a regen I interrupted.
I just bought some opti-lube Summer Formula that treats 640 gallons per quart. Price is right.
I understand that winter operation is a lot different, however.
I saw a test somewhere that said opti-lube was top notch and costs about a tenth of what the boutique brands cost.
Most of the long-term Cummins guys in here aren't all that wild about additives, I've noticed. And I don't plan on using a lot of it.
Ricky_Bobby likes this.
2017 4X4 SLT Ram Big Horn 2500 SB Cummins
RammerJam is offline
post #6 of 20 (permalink) Old 02-04-2019, 12:17 PM
^I'm big on additives - and even bigger on the HFRR score test, which Opti-Lube actually has independent data for - figure about $1-2 a tank is worth more to me to treat the fuel and for the peace of mind - I'll put my flame suit on before all the haters come in "DERR ALL I PUT IS DEEZUL IN MY TANK I HAVE 500K MILES ITS SNAKE OIL"
Use what you like, and use it often - for your Florida climate, the Summer+ should be all you need, it gets a good HFRR wear rating. I personally use a combo of their XL Lubricant, with Hot Shot Secret EDT - With our mild winters I haven't used any anti-gel yet especially since our vehicles are garage kept -
If you don't need the anti-gel, the Summer formula is the best value by far - enjoy! I notice my engines running quieter, smoother, cleaner, and I don't complain about the mileage either -
Jimmy N. likes this.
2018 2500 Big Horn - 6.7L 68RFE - CC 6'4" - SPORT
Ricky_Bobby is online now
post #7 of 20 (permalink) Old 02-04-2019, 12:23 PM
RammerJam's Avatar
There are documented cases and testimonials by mechanics that over-use of additives can actually do some pretty serious harm to your diesel.
Just passing it along
N of 60 and Jimmy N. like this.
post #8 of 20 (permalink) Old 02-04-2019, 01:37 PM
I appreciate you passing it along - I don't overdose and always follow the additive manufacturers directions (some of these are serious chemicals and should only be used in dose rates per directions) - Must use common sense IE dont use Power Service 911 when you don't need it - and don't run a full bottle of Cetane booster when 4 oz will do - Have been using a good diesel additive on 3 diesel vehicles now (most recent my 6.7L) and used properly none of my vehicles have any negative effects -
post #9 of 20 (permalink) Old 02-05-2019, 07:26 PM
Too Tall's Avatar
Many variables. None when towing. As often as every 75 miles under some city driving conditions. Monitor your DPF pressure. If regen about .05 psi, it's normal. Don't use additives as per manual.
USMC 1968 - 1970. 2014 2500 4 x 4 3.42 maximum Steel
Too Tall is offline
post #10 of 20 (permalink) Old 05-14-2019, 06:34 PM
jdjonesiii's Avatar
Watch this video.. Interesting. I am going to try the double dose of the Hot Shot Secret EDT. I presently use Diesel Kleen and am satisfied with this. However, as my vehicle gets older and more mile it seems like the Hot Shot has an advantage. Oh by the way. The Diesel Kleen really has smoothed out the Cummins. I use the double dose as per the directions bringing my CETANE up to 46 from 40. Cummins recommends the Diesel Kleen.
https://www.cumminsfiltration.com/si...20Bulletin.pdf
Too Tall and RollingAlong like this.
John Jones
Aiken, SC 29803
803 998 7424 cell
jdjonesiii is offline
post #11 of 20 (permalink) Old 05-15-2019, 10:39 PM
RollingAlong's Avatar
Originally Posted by jdjonesiii View Post
https://www.youtube.com/watch?v=hb51NVRPf9M&t=840s
I have used this product for almost a year now and have no complaints.
2016 Ram Outdoorsmen 6.7 Cummins 4X4 3.73
2016 27ft Jayco White Hawk TT - Hotel On Wheels
RollingAlong is offline
post #12 of 20 (permalink) Old 05-16-2019, 10:07 AM
Hot Shots Secret Diesel Extreme and EDT......Problem solved
2018 Ram 2500 CTD 4X4 CCSB Lone Star Silver Edition
Wowegner is offline
Similar Threads
DPF regen two days apart Rifleman1775 2013+ General Discussion 22 05-15-2017 12:49 PM
What does the DPF Regen mean to the driver? dieselpower56 2010-2012 General Discussion 6 01-01-2017 07:44 PM
regen and heat? K9Kodi 2013+ General Discussion 18 10-23-2015 08:36 PM
Regen without DPF present...? C Murda 07.5 - 09 3rd Gen 6.7L Powertrain 1 10-05-2015 07:10 PM
DPF Full and truck will not regen Dans58 07.5 - 09 3rd Gen 6.7L Powertrain 23 12-18-2011 11:44 AM
