Door Locks After BTSI Recall - Dodge Cummins Diesel Forum
 1Likes
post #1 of 15 (permalink) Old 06-19-2018, 11:34 PM Thread Starter
I took my truck to have the brake transmission shift interlock recall performed, which required a flash to the BCM. When I got it back, I noticed a few things. All my vehicle settings were changed, such as, headlight delay, sound horn when lock, etc. After I got them all back the way I like, I noticed one more thing. Since I took delivery of my truck brand new (2017 2500 tradesman), all the door locks and tailgate lock would unlock simultaneously when I press the unlock button on the fob. Now when I press the unlock button, only the driver door unlocks, then I press it again and the rest of the doors and tailgate unlock. I canít find a setting on the radio for this feature, and I donít know if it was ever a setting to change since I never messed with it. So, my questions are, to those that havenít had the recall done, do your doors unlock like mine used to? Is there a setting in the radio to change this feature?
Jimmy07 is offline
post #2 of 15 (permalink) Old 06-19-2018, 11:43 PM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
Which radio do you have....3.0 or 5.0 ?
2018 RAM 4500 Chassis Tradesman Crew Cab 60Ē C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Continental HDRís, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 123,149 miles and 2,159 hours as of April 12th, 2019 (Average Miles Per Hour = 57.0)
gsbrockman is offline
post #3 of 15 (permalink) Old 06-19-2018, 11:53 PM Thread Starter
Aftermarket running with idatalink maestro, which retains all the vehicle settings that the 5.0 and 8.4 have.
Jimmy07 is offline
post #4 of 15 (permalink) Old 06-20-2018, 12:29 AM
Ltngdrvr's Avatar
Default door lock setting is two taps to unlock all.
The setting is in the settings in the radio, since you have an aftermarket radio, you'll just have to keep digging through the menus to find it, but I'm sure it's there.
URDiesel likes this.
CCV reset/seatbelt chime disable
Ltngdrvr is online now
post #5 of 15 (permalink) Old 06-20-2018, 12:32 AM
Flatbed07's Avatar
My truck reset several things but not everything when I had the recall done. I have the 5.0 and the setting is somewhere in there.
2016 3500 4x4 68rfe
2007.5 3500 c&c 4x4 g56 - sold
Flatbed07 is offline
post #6 of 15 (permalink) Old 06-20-2018, 05:54 AM
blueram01's Avatar
It is a setting accessible though the radio. Mine did the same thing. Everything changed to factory defaults.
SteveB 2015 3500 DRW Tradesman CC
2001.5 3500 2WD QC, ETH/DEE,SOLD-8/2015
1996 1500 4X4 RC/SB 318/AT SOLD-8/2010
blueram01 is offline
post #7 of 15 (permalink) Old 06-20-2018, 07:11 AM Thread Starter
Thanks guys. At least I know itís a setting in the factory radios now, so I can have Maestro make a firmware that will add it.
Jimmy07 is offline
post #8 of 15 (permalink) Old 06-20-2018, 08:00 AM
ironpony's Avatar
yup it is in there, I changed mine to 2 clicks...........
2002 2500 Quadcab LB 4X4 NV5600 HO stock
2012 3500 SRW Crewcab LWB 4X4 Auto 6.7 HO stock
ironpony is offline
post #9 of 15 (permalink) Old 03-25-2019, 11:33 AM
I want to replace those locks, hiring locksmith for that work is a good idea or not ?
DemetriaGuynes is offline
post #10 of 15 (permalink) Old 03-25-2019, 11:38 AM
Ltngdrvr's Avatar
Replace which locks?
post #11 of 15 (permalink) Old 03-25-2019, 11:57 AM
Really. I had no idea. Mine has always locked/unlocked everything with 1 tap, which suits me fine, and that's persisted through the various recalls and flashes. I assume it was changed by the rancher who had the truck for the first 1100 miles. Thanks for the info ... in case it ever resets.
2016 3500 LL CC LB 4x4 CTD DRW Delmonico red. BDS 3" truss radius arms & 3" coils w/double Bilsteins. Synergy drag link & tie rod. Dual stabilizers.
Carli track bar. Carli torsion anti-sway. Synergy steering box stabilizer. Rear 2" blocks. Weldcraft 17x8 custom steel duallies w/Mickey Thompson 295/70-17 ATXP3s.
AEV axle covers. AEV vented hood. Luverne polished stainless steel boards. Bakflip MX4 hard cover. Bushwacker max coverage flares.
B-pillar vinyl delete. Mopar door chrome. Areion semi-truck flap mounts. Steelcraft polished stainless light guards.
EricPeterson is offline
post #12 of 15 (permalink) Old 03-25-2019, 01:10 PM
lineman1234's Avatar
I have the 2015 tradesman and it has always had, and still does have the one push unlock all. ( I have had it since new) Even after updates when it was stock. Dealer installed factory remote start and it came with 2 new fobs and they flashed the computer to tell it, it had auto start and still one push. Same thing after delete, one push unlocks all.
Good luck.
2015 2 door 4x4 tradesman.
Travel full time.
Retired lineman.
lineman1234 is offline
