Water Leaking into CAB. - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
post #1 of 26 (permalink) Old 02-09-2014, 07:38 PM Thread Starter
Angry Water Leaking into CAB.
I live in NorCal and we havent had much of any rain since I bought this truck in Oct. Within the last week we have finally started to get some decent rain. Went to go down town this morning and the back seat, driver side is soaking wet, and there is about an inch of water in the under seat storage compartment. Further inspection revealed water was leaking through the body, Im assuming through a crack in the metal. Interestingly enough, when I bought my 2011 a couple of years ago from Dave Smith, the same thing happened when I went to take delivery, and they had to find a different truck. This is a 2013 with only 7000 miles on it and my backseat is now ruined. The headliner is soaked, seat is soaked, about an inch of standing water in the underseat storage. To say Im upset is a huge understatement. I bought this truck from the dealership in Medford, but Im hoping the one here in Eureka will assist with this issue, even though I didnt buy from them. Any thoughts or advise on this before I delve into this on Monday?
warmstrong is offline
post #2 of 26 (permalink) Old 02-09-2014, 07:42 PM
100K Club
blackhawk783's Avatar
It's under warranty so any dealer in the USA will handle it. Good luck, keep us informed.
Steve
2013 Ram 2500 6.7 Cummins
1989 Ram D250 5.9 Cummins
blackhawk783 is offline
post #3 of 26 (permalink) Old 02-09-2014, 08:31 PM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
I'm willing to bet you'll find the source of the leak to be around the CHMSL (3rd brake light) at the top of the cab.
2018 RAM 4500 Chassis Tradesman Crew Cab 60Ē C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Firestone FD690ís, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 196,704 miles and 3,437 hours as of January 27th, 2020 (Average Miles Per Hour = 57.2)
gsbrockman is offline
The Following 3 Users Say Thank You to gsbrockman For This Useful Post:
6401nohl (02-10-2014), 67guzzler (02-09-2014), j4henry (04-02-2014)
post #4 of 26 (permalink) Old 02-09-2014, 08:31 PM
Do you have a sunroof?
2013 2500 crew 4x4 3.42 Lonestar
sking is offline
post #5 of 26 (permalink) Old 02-09-2014, 08:35 PM Thread Starter
I dont have a sunroof. It looks to be coming in somewhere where the weather stripping is on the top of the truck where the body joins together. There is no water anywhere near the middle, just directly underneath that joint. It would be great if it was the 3rd brake light, as that would be much easier to fix. I hope to be able to take it into the dealership on Monday. Its supposed to rain all week, so this is only going to get worse.
post #6 of 26 (permalink) Old 02-09-2014, 08:41 PM
I had hoped the seam issue was resolved.
sking is offline
post #7 of 26 (permalink) Old 02-09-2014, 08:45 PM
RisingEagle's Avatar
on my 2009 ram 1500, I had two leaks in the back areas you are talking about - it was coming in where the black weatherstripping on top of the truck meets the back window seal. On both the driver's side, and the passenger side.
It took a couple years to start leaking, but when it did - it flooded in. Basically, where that black weatherstripping meets the back window there is a little 'gap' in the seal around the window, and over time the top weatherstrip had peeled away from the window seal leaving a hole. So water was running off the roof of the truck, along that strip, and right down into the cab.
I went and bought a tube of silicone sealant, peeled the top weatherstrip up a bit near the window, squirted a glob in there and pushed the weatherstrip back down. It cured in about an hour, and I haven't had any problems since.
There are a ton of threads on this issue over on ramforumz, which is where I actually found the solution. I'll see if I can't find a couple and post links here.
With it being a 2013 though - I agree with the others here, take it in and have THEM fix it. if it is the weatherstripping issue it will be a relatively simple repair - but I would definitely have them investigate in case it's something a lot more serious.
2014 3500 Laramie Longhorn 4x4, CTD, SRW
RisingEagle is offline
post #8 of 26 (permalink) Old 02-09-2014, 08:54 PM
67guzzler's Avatar
Like gsbrockman said above -- the 3rd brake light, chmslelssa light or whatever it's called is known to leak. Check that first. The seal may not have set right at the factory. You can unscrew it yourself and check the seal in about 1 minute.
-Guzzler
2017 2500 Crew 4x4 Laramie 6.4L HEMI 66RFE w/4.10
PRIOR: 1994, 1996, 2004, 2005.5, 2010 and 2013 2500's. ALL Cummins.
If someone is nice enough to post a truck-related pic,
I'm more than happy to click a "Like or Thanks."
67guzzler is offline
post #9 of 26 (permalink) Old 02-09-2014, 09:25 PM Thread Starter
Only problem is, I have a Leer canopy on my truck, so getting to the 3rd brake light will be somewhat difficult to do. Im planning on taking it into the dealership tomorrow and let them figure it out. Hopefully it will be minor. The last time I had this issue with the truck I almost bought, it turned out to be a crack in the body that was not fixable according to Dave Smith. I really hoping that is not the case this time.
post #10 of 26 (permalink) Old 02-09-2014, 11:26 PM
2013RAM's Avatar
Good luck with the fix, I have seen third brake lights leak and run to the side of cab and look like it was leaking from a different area.
2013 Laramie Crew Cab 4x4 Maximum Steel two tone manual transmission Dealer installed Ram leveling kit
2013RAM is offline
post #11 of 26 (permalink) Old 02-09-2014, 11:56 PM
My third brake had some minor leakage. One of the first things I checked when I bought her. Had not leaked into cab yet. Cleaned it and put some RTV sealant on top of factory seal. Worked great.
ID:	180114   Click image for larger version
2015 3500 SRW Longhorn, CTD, 4x4 (I'm done buying)!
2014 2500 Laramie Crew, 6.4 Hemi, 4x4 (traded)
2013 2500 Longhorn, CTD, 4x4 (traded)
HorseMan-AR is offline
post #12 of 26 (permalink) Old 02-10-2014, 11:23 AM
6401nohl's Avatar
Absolutely. Just took mine in for the same issue. They replaced the Gasket and all seems to be A-OK now.
2014 Granite Crystal Metallic 3500 - 6.7, 4x4, CC, SRW, 3:42, 68RFE, LB, Tradesman -140k miles and going.
2005 White 2500 - 5.9 HO, 4x2, CC, SRW, 3:42, 48RE, LB, SLT - 200,000 miles and going.
6401nohl is offline
