Condensation in Headlights...with pics - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
post #1 of 12 (permalink) Old 11-16-2013, 12:01 AM Thread Starter
Don't slap my wrist guys...I did a little looking around on the issue. Seems we just have to live with it. Never found any good pics, and didn't find much under 2013 discussion (searching via my phone) so I thought I would post here. Both my headlights have pretty extensive condensation.
Same for you guys?
ID:	133289   Click image for larger version
ID:	133297   Click image for larger version
ID:	133305   Click image for larger version
2015 3500 SRW Longhorn, CTD, 4x4 (I'm done buying)!
2014 2500 Laramie Crew, 6.4 Hemi, 4x4 (traded)
2013 2500 Longhorn, CTD, 4x4 (traded)
HorseMan-AR is offline
post #2 of 12 (permalink) Old 11-16-2013, 02:14 AM
Trey02's Avatar
Yeah i was wandering the same thing. I just got my 2013 2500 and I was thinking about confronting the dealership with it. I have only noticed it a couple times but I have only owned the truck a week.
2013 Laramie 2500 Maximum Steel 2"leveled 4x4 68 rfe trans..
2004 SLT 3500 Timberline Green Stock...(tow truck)
Trey02 is offline
post #3 of 12 (permalink) Old 11-16-2013, 02:44 AM
ds145's Avatar
My 2010 charger srt8 did the same thing. Bad when it rained. Went away in the summer. My 2013 3500 has been fine so far.
2013 Ram 3500 Laramie SRW 68rfe
ds145 is offline
post #4 of 12 (permalink) Old 11-16-2013, 02:58 AM
GRam's Avatar
Had it in my '11, and now in my '13. thought it was because of something done when I had the HID's installed. Would seem to not be the case...
Not end of the world, but a bit of a pita.
2013 RAM 2500 Limited
2013 CVO Road Glide
2011 AMG C63
GRam is offline
post #5 of 12 (permalink) Old 11-16-2013, 07:14 AM
cutoutcummins's Avatar
Best diy fix if you don't want to get the dealership involved. Pull the headlights check the 4 or 5 bolts on the back of the housing than take some clear silicone and run it around where the clear lense and black housing meet. That should solve the problem
Sent from AutoGuide.com App
2018 Ram 2500 6.4L hemi. 2" RCX Level and 1.5" Supreme Suspension Rear Spacers. 35x12.5x18 Federal Cougaria MT'S, 275/65R20 Cooper Discoverer AT3 XLT AT on Stock Black 20's
cutoutcummins is offline
The Following 3 Users Say Thank You to cutoutcummins For This Useful Post:
HorseMan-AR (11-16-2013), NickBeek (12-02-2018), Trey02 (11-16-2013)
post #6 of 12 (permalink) Old 11-16-2013, 08:24 AM
dieselwelder's Avatar
Location: Springhill, Fl.... Traveling welding contractor
Mine has this issue too.... I'm changing out my headlights next week. bought some aftermarket Xenon headlights.
2016 Laramie Longhorn 3500 CCLB 4x4. Aisin. 385/900! 3.73 B&W Companion.
dieselwelder is offline
post #7 of 12 (permalink) Old 11-16-2013, 11:26 AM
I can't recall if it was in the '14 Durango manual or the 1500/2500/3500 manual that I was reading but condensation in the headlight housing is mentioned. It is considered "normal". I think that if you turn your headlights on it will go away.
Olli
Olli is offline
post #8 of 12 (permalink) Old 11-16-2013, 11:31 AM
If these headlights are of the type where the housing is separate from a twist or snap in style bulb, there will ALWAYS be the potential for condensation! The only way around it is a vacuum sealed bulb chamber, which in the end is only as good as the seal. It is near impossible to eliminate that bit of moisture from occurring. Leave the lights on for ten or twenty minutes though, and it will probably dissipate. However, shut them off on a relatively cold night, and it will probably re condense in there.
Dzlpete is offline
post #9 of 12 (permalink) Old 11-16-2013, 12:15 PM
They technically are but the projector style have a sealed cover that has to be removed to access the lights
post #10 of 12 (permalink) Old 11-27-2013, 11:27 AM
vb712's Avatar
My 2012 both headlights get condensation in them when its nasty weather. I have tried everything to solve it and nothing has worked. Drives me crazy but I guess we all just have to live with it.
'12 Mineral Grey HO CCSB, Deleted. Studded. EFI Live by Anarchy 13 sec club 💨
vb712 is offline
post #11 of 12 (permalink) Old 11-27-2013, 12:05 PM
firebird's Avatar
In 9000 miles, I have not experienced this. I would not be pleased with moisture in these expensive lights.
2018 Ram 2500 Laramie 4x4, 6.4 Hemi
firebird is offline
post #12 of 12 (permalink) Old 11-27-2013, 04:36 PM
oudive's Avatar
iTrader Score: 5 reviews
I used clear nail polish about two or three coats around the headlight seam and that worked perfect for me when I had similar issues after modding my 2nd Gen headlights to fit projectors.
2013 Lone Star- 3500 CC / DRW / AISIN / 4.10 / Renegade Front Bumper / Hellwig Bags w/wireless AirLift
oudive is offline
The Following User Says Thank You to oudive For This Useful Post:
jsnolan99 (03-11-2016)
