2018 Dodge 2500 pitman - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 8Likes
post #1 of 18 (permalink) Old 02-26-2020, 03:18 PM Thread Starter
Hey Guys,
Have a 2018 Dodge Ram 2500 converted to RH drive for our NZ roads.
Imported a 5" lift kit from rough country few years back and never installed it due to the pitman arm having a LH drive lean on it.
Decided to get off my behind and try and find a solution as no one in NZ has the capability to forge what is needed.
Is there a RH drive alternative or even bare minimum of a straight end?
Have photos of current arm wrong angle but some reason wont let me attach.... .
Also came across a thread from years ago where someone had posted a picture of the arm required (although fuzzy pic so cant rear part number) but cant get in touch with them.
Thanks in Advance!!
shiftie7 is offline
post #2 of 18 (permalink) Old 02-26-2020, 03:24 PM
tsconver's Avatar
Can't help you on the Pittman arm but you can't post pictures until you get a few more posts I do believe. GL.
73 K4CTD
2018 2500 CC SB Laramie - stock for now
2005 2500 QC SB, Rebuilt at 330K miles, Sold
tsconver is offline
The Following User Says Thank You to tsconver For This Useful Post:
shiftie7 (02-26-2020)
post #3 of 18 (permalink) Old 02-26-2020, 03:27 PM
Walker111's Avatar
Its been a while since I looked at mine, but I thought other than the downhill slope to it, they were flat.
Electrojake likes this.
16 CTD 2500 Bright White Crew Cab
Walker111 is offline
post #4 of 18 (permalink) Old 02-26-2020, 03:29 PM Thread Starter
Flat would be a start but this arm has a picture of an Eagle on it with numbers I300 DS2009A
has a good been on the end i believe to help with bump steer?? could be wrong
shiftie7 is offline
post #5 of 18 (permalink) Old 02-26-2020, 03:32 PM Thread Starter
How many posts till i can put up some pictures? would be helpful of course
shiftie7 is offline
post #6 of 18 (permalink) Old 02-26-2020, 03:44 PM
K9Kodi's Avatar
will a standard drop pittman arm work, or is the keyed pittman arm for the left hand drive put it too far out of alignment for right hand drive?
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is online now
post #7 of 18 (permalink) Old 02-26-2020, 04:02 PM Thread Starter
With the size of the lift the arm gets bound up from tie rod angle.
Lift kit comes with a dropper pit man arm to essentially lower the rod to the original working angle but this one has a bent where tie rod end bolts through
shiftie7 is offline
post #8 of 18 (permalink) Old 02-26-2020, 04:16 PM
K9Kodi's Avatar
are you putting drag link on top or bottom of pittman arm?
post #9 of 18 (permalink) Old 02-26-2020, 04:54 PM
nova3930's Avatar
There's your problem. Just quite being upside down
HeavyTwo and Jimmy N. like this.
2015 Ram 2500 Crew Cab - Calibrated Power Emission Intact Tune -AlphaRex / Morimoto / Hikari Ultra Headlights -Fox IFP Steering Damper
nova3930 is offline
post #10 of 18 (permalink) Old 02-26-2020, 05:00 PM
Lins's Avatar
Be nice now, I like Aussies
nova3930, HeavyTwo and Jimmy N. like this.
Lins is offline
post #11 of 18 (permalink) Old 02-26-2020, 07:22 PM Thread Starter
Haha love ya work
shiftie7 is offline
post #12 of 18 (permalink) Old 02-26-2020, 07:25 PM Thread Starter
Tried both but imagine pitman arm having drag link heading to RH side as factory so arm has a RH bend on end.
Pitman arm now on RH side so pitman heading to LH side but arm still designed for RH
shiftie7 is offline
