Po128 - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 1Likes
post #1 of 17 (permalink) Old 02-26-2020, 03:06 PM Thread Starter
pkwett94's Avatar
Po128
2018 2500 with 27,000 miles on it. I have noticed lately that it has not been getting up to normal op temp. Yesterday I had the CIL come on. Checked codes and PO128 came up, temp not getting to normal range. Going into the stealer on Friday. Anyone else have this and what was the issue.
Thanks.
2005 CC LB 2WD with shift kit and billet TC, other then that stock.
2018 Tradesman 4X4 CCSB
pkwett94 is offline
post #2 of 17 (permalink) Old 02-26-2020, 04:21 PM
Ltngdrvr's Avatar
Could be a stuck t-stat, what is the temp reading in the EVIC?
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is online now
post #3 of 17 (permalink) Old 02-26-2020, 06:43 PM Thread Starter
pkwett94's Avatar
Usually in the 165 range sometimes hitting 175 briefly. Tstat is my first thought also.
pkwett94 is offline
post #4 of 17 (permalink) Old 02-26-2020, 06:48 PM
Gr8bawana's Avatar
I believe the factory t-stat is a 190.
2017 4x4 2500
6.7 CTD 100% stock
33.700 miles
Gr8bawana is offline
post #5 of 17 (permalink) Old 02-26-2020, 06:59 PM
Ltngdrvr's Avatar
Yeah, that's way low, mine is always above 190.
Possible it is a bad temp sensor.
post #6 of 17 (permalink) Old 02-26-2020, 07:34 PM Thread Starter
pkwett94's Avatar
Up until now mine as always ran above 190 also.
pkwett94 is offline
post #7 of 17 (permalink) Old 02-28-2020, 06:27 AM Thread Starter
pkwett94's Avatar
The put a new Tstat in it. I pick it up today will see if it made a difference.
pkwett94 is offline
post #8 of 17 (permalink) Old 02-28-2020, 07:29 AM
7492's Avatar
Thanks.
Put the thermostat in first. I seriously doubt the sensor is bad, and even then change the thermostat first.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
2020 KW T370 PX9 380HP 1250lbft @ 1400 RTO14908LL
7492 is offline
post #9 of 17 (permalink) Old 02-28-2020, 03:51 PM Thread Starter
pkwett94's Avatar
The drive home was 195 degrees
Gr8bawana likes this.
pkwett94 is offline
post #10 of 17 (permalink) Old 02-28-2020, 04:01 PM
Ltngdrvr's Avatar
Well, that's right on the money, so it looks like it was just the t-stat.
I do hit them right occasionally.
post #11 of 17 (permalink) Old 02-29-2020, 08:36 AM Thread Starter
pkwett94's Avatar
Tstat was my first guess. All the electronics on these things came leave a person second guessing themselves though.
pkwett94 is offline
post #12 of 17 (permalink) Old 03-02-2020, 11:34 AM
6401nohl's Avatar
FWIW - Interesting - I had the same code and issues come up on my 2016 Jeep a few weeks ago. It was the thermostat being stuck open. The 2.4 engine has it buried and you can't replace just the stat. You have to replace the complete assembly, with sensor even. And it was a nightmare to replace. After some research, apparently on the 2.0/2.4 Jeep engines, it's a common failure in the 40 - 60k miles range...
2014 Granite Crystal Metallic 3500 - 6.7, 4x4, CC, SRW, 3:42, 68RFE, LB, Tradesman -140k miles and going.
2005 White 2500 - 5.9 HO, 4x2, CC, SRW, 3:42, 48RE, LB, SLT - 200,000 miles and going.
6401nohl is offline
