That Rattle though! - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 4Likes
post #1 of 23 (permalink) Old 02-18-2020, 08:09 AM Thread Starter
That Rattle though!
I have researched this for some time now, but never asked about it, but was curious what the general consensus is. My truck has a slight rattle, almost like spark knock when light on the throttle between 1700ish to 2200ish rpms..Seems more throttle makes it disappear. More load makes it disappear. Seems something with timing. Its not super loud like somethings gonna fly apart or anything but loud enought to barely notice it there.. Its not there 100% of the time eiither. Been like that since new and having never owned a diesel before I assumed it normal. With 18K onit now, its no worse or better and performance has not changed.
On research I have found several reports of the same thing and read everything from "it's a cummins its noisy" and " mine has done that for 200K miles" To " OMG its ready to explode" Thoughts?
Gotta say the noise does not bother me, I rather like, it if its not destroying something!
2018 3500 cc lb 4x4 g56
ronheater70 is offline
post #2 of 23 (permalink) Old 02-18-2020, 08:27 AM
Don82146's Avatar
OMG its ready to explode!!!!!!!!! LOL
What you need to do is go find an old truck with a 1693 CAT and fire it up!! Hence, the term “Rattlin’ Cat”!
Of course, nne of us can hear your engine run, so everything is just a guess; but I would say it is just a “hummin’ Cummins”!
Desert Don, in the Grand Canyon State
2018 3500 DRW, 2013 Raptor @ 41’ long and 18000 GVW.......and too many toys!!
Don82146 is offline
post #3 of 23 (permalink) Old 02-18-2020, 08:33 AM
Ltngdrvr's Avatar
You say the noise doesn't bother you and yet here you are asking about it.
Turn the radio up, noise fixed!
CHL2T likes this.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
post #4 of 23 (permalink) Old 02-18-2020, 09:48 AM
upflying's Avatar
Mine makes the exact same part-throttle rattle.
Figure it is the nature of the beast.
2018 Ram 2500 Tradesman, CC/SB/4X4/CTD/68RFE, stock, white, no bells and whistles.
Kelderman rear air springs, ARE cap, Bedrug, Carhartt seat covers, Huskyliner floor mats, Huskyliner mud flaps, Lund side steps, Tradesman emblem on tailgate
upflying is offline
post #5 of 23 (permalink) Old 02-18-2020, 10:02 AM
Some have tried adjusting the valve lash to reduce the clatter, but I've only heard mixed results.
You could take it into a reputable shop and have them listen to it.
But I'd be more concerned about a NEW noise, not the clatter it's had since new.
2016 2500 4x4 Reg Cab SLT, Lux, Snow Chief
Synergy Drag Link, 2507# payload
brulaz is offline
post #6 of 23 (permalink) Old 02-18-2020, 10:35 AM Thread Starter
Yes, I actually like the sound, almost old schoolish, like said though, I only like it if its not self destructing!
post #7 of 23 (permalink) Old 02-18-2020, 10:36 AM Thread Starter
Thats my thoughts as well, I'm not really worried per se, just curious as to exactly what makes it do its thing.
post #8 of 23 (permalink) Old 02-18-2020, 10:39 AM Thread Starter
Funny you mention that because I had read that as well, also with mixed results. The kicker being, I dont know of any reputable diesel shops here. I mean we have a few, but how good are they, I dunno.
post #9 of 23 (permalink) Old 02-18-2020, 10:57 AM
TECH SPECIALIST
steve05ram360's Avatar
Adjusting the valves wont make the rattle go away, its timing rattle. OP could add an additive that will advance timing which will most likely get rid of it. Over in the 5.9 world (on my truck cause it is de-tuned significantly for FE reasons, 21+ mpg all year long) we use dex/merc atf with tw-c3 2 stroke oil (2SO). You can try the 2SO at a high ratio and should not have any exhaust issues (yes, I did it already & ran ~50k on a dpf equipped diesel using 8oz 2SO to 13gal fuel with zero issues)
I dont recommend power service diesel, find something else like Howes or Stanadyne (sp?)
Lins likes this.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 432k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #10 of 23 (permalink) Old 02-18-2020, 11:06 AM
Downs807's Avatar
Likely fuel rail rattle that you are hearing. But that’s just my guess. Normal sound for these engines.
2018 Laramire Mega, Anarchy Tuned
Downs807 is offline
post #11 of 23 (permalink) Old 02-18-2020, 11:07 AM
nova3930's Avatar
It's a diesel, it's gonna rattle a little.
I've found mine generally "likes", and rattles less, with a little higher cetane than you get at most pumps. I don't use it all the time but when I want cetane boost I use the PS Diesel Kleen in the gray jug, just because it's readily available....
2015 Ram 2500 Crew Cab - Calibrated Power Emission Intact Tune -AlphaRex / Morimoto / Hikari Ultra Headlights -Fox IFP Steering Damper
nova3930 is offline
post #12 of 23 (permalink) Old 02-18-2020, 11:30 AM
TECH SPECIALIST
Rattle is bad, its the force the combustion is exerting on the crank in the wrong direction. Will it kill your motor, not likely with a stock tune but it does rob mpg. It is done that way for emissions... something to do with NOX reduction.
