Please help me with headlights - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 67Likes
post #1 of 93 (permalink) Old 02-13-2020, 06:11 PM Thread Starter
I have a 2013 Laramie with projector headlights and I would like to have bit better light out of them without spending a fortune. I know there are many threads about headlight upgrades and I have read a few but it is confusing to figure out what would work best for me.
I don't want to have to put my headlights in an oven and I don't even want to have to drill holes in them if I don't have too. I think HID's would probably work for me but maybe I'd be better off with something else??? I really don't want to spend more than $200 and I would like to do my foglights too so the color matches the headlights. I also don't want to be blinding oncoming traffic.
Can someone please dumb it down for me to help me decide what to do? I see there are many choices on Amazon but I have no idea what works and what doesn't. I don't want to buy something only to figure out it's junk.
Thanks in advance,
Rod
2013 2500 CTD Laramie 4x4 68rfe
sicumminsde is offline
post #2 of 93 (permalink) Old 02-13-2020, 07:04 PM
Rear Admiral Rickard Onmi
Loki223's Avatar
Alpha OBD will allow for HID or LED lights to be installed without needing canbus boxes
HIDs will require the dust shields to be drilled to allow for grommets for the ballasts to be mounted.
LEDs will not require modifications to the dust shields. HIDs will provide more light, but LEDs will be a simpler install, while still improving over stock
Fogs should not recieve HID lights, or probably not even LEDs in your price range. Leave them alone for now, maybe eventually upgrade to Morimoto LED Projectors ($200 right there)
any LED you choose will need verification that it fits in the housing, some heat sinks are to large and will not allow for the dust cover to mounted back on.
pwr2tow and nick00less like this.
2018 Ram 3500 Limited - Crew Cab Long Box 4x4 SRW Stock at the moment, but that will change
Make your puddle lights great again!
SUPPORT SITE VENDORS, THEY MAKE ALL THIS POSSIBLE
HELP ME UPDATE MY IMAGES, IF YOU SEE A BROKEN IMAGE LINK, SEND ME A PRIVATE MESSAGE SO I CAN UPDATE THE IMAGE TO A NEW HOSTING SITE
Loki223 is offline
The Following User Says Thank You to Loki223 For This Useful Post:
sicumminsde (02-13-2020)
post #3 of 93 (permalink) Old 02-13-2020, 07:40 PM
nick00less's Avatar
Innovited HID Kit
Innovited 55W AC Xenon HID Lights"All Bulb Sizes and Colors" with Digital Slim Ballast - 9012-5000K - Prue White - 2 Year Warranty
The wire that plugs into your low beam bulb will plug into the ballast on this kit. The other wire on the ballast will plug into the HID bulb. Install HID bulb. Stuff the ballast inside the headlamp. Screw dust shield back on. Plug headlight back in. Boom! Done! Tons of light for only $50
Thatís what Iím currently running. No harnesses. No anti flicker junk. Nada. The ballast simply ticks away inside the headlamp. No drilling of dust shield required. No mounting of ballast required. Nada. Easy peezy.
FYI I realize our dust shields are different. Yours are actually bigger. Itíll work, trust me.
pwr2tow, Dude_57, SRich12 and 1 others like this.
'18 6.7 S472-5 Blade 2018 Build
nick00less is offline
The Following 2 Users Say Thank You to nick00less For This Useful Post:
Dude_57 (02-13-2020), sicumminsde (02-13-2020)
post #4 of 93 (permalink) Old 02-13-2020, 08:16 PM
miami ram salt life's Avatar
Let me ask you, is there a certain way these get installed in the projector? Because to this day my beam pattern isn't very clean on the ground. It seems like there are shadows/empty spots.
2014 Cummins 4x4 Black Appearance / AFE dry filter intake / 22" light bar / LED lights all around / Thuren Leveling kit with track bar & fox shocks all around / Mishimoto Coolant Hoses / AMP Steps / 22x10 American Force on 35's
miami ram salt life is offline
post #5 of 93 (permalink) Old 02-13-2020, 08:19 PM
nick00less's Avatar
The filament on the bulb must ALWAYS face STRAIGHT down towards 6 o’clock.
pwr2tow, boshog, Dogpatch and 1 others like this.
The Following User Says Thank You to nick00less For This Useful Post:
miami ram salt life (02-13-2020)
post #6 of 93 (permalink) Old 02-13-2020, 09:06 PM
Loki223's Avatar
the one thing @nick00less didn't mention is he is already running Alpha OBD, which will be needed to run the HIDs without a canbus canceller or resistors, which can get hot. From everything i've read, the ballasts will get warm, but not hot. Many people use double sided tape without issues to mount them, so placing them inside the housing shouldn't be an issue
Loki223 is offline
The Following 2 Users Say Thank You to Loki223 For This Useful Post:
Dude_57 (02-13-2020), nick00less (02-13-2020)
post #7 of 93 (permalink) Old 02-13-2020, 10:26 PM
MSquare's Avatar
I'd like to add that you can order pre-drilled dust covers from Headlight Revolution, they are expensive......but an option to drilling the factory dust covers.
2015 2500, crew cab, auto, sb, stock Cummins, ARE Canopy, Cargo Glide, Vision X front and rear, Carli Backcountry System, XD 20" Wheels, Toyo ATII's 35/12.5/20, Duraflaps
MSquare is offline
post #8 of 93 (permalink) Old 02-13-2020, 11:19 PM Thread Starter
This is great info! I already have alfaOBD. I'm not computer illiterate but what setting in alfaobd should I look under to run the lights that nick00less has suggested. Thanks in advance.
pwr2tow likes this.
post #9 of 93 (permalink) Old 02-13-2020, 11:51 PM
nick00less's Avatar
Vehconfig-high intensity discharge
Enable-yes
pwr2tow and sicumminsde like this.
post #10 of 93 (permalink) Old 02-13-2020, 11:59 PM
You don’t need to drill covers. If you want HID you can look at some of my prior threads I created a like of where to buy covers that come pre-drilled. So if you decide to go back to stock you can.
Since it sounds like you want simple if just stick with LED. That’s going to be the easiest.
pwr2tow likes this.
Xokia is offline
post #11 of 93 (permalink) Old 02-14-2020, 01:52 AM
Cummins Freak
SRich12's Avatar
I agree with Nick except I like 6000K diamond white!!! Also maybe some Hakari LED's 6K for the highs.
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli Level/295 Toyo AT2's /Full Console swap w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is offline
The Following User Says Thank You to SRich12 For This Useful Post:
nick00less (02-16-2020)
post #12 of 93 (permalink) Old 02-14-2020, 02:00 AM
Enable-yes
Thank you Nick, I'm gonna try the Innovited kit for mine. Just recently got AlfaObd.
What do you recommend for fogs and high beams, if any?
2014 2500 Ram BAP Lonestar CCLB 4x4 6.7L CTD 68RFE
opichi is offline
