I give up / Morimoto LED Fog Light Kit - Page 5 - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 26Likes
post #49 of 59 (permalink) Old 02-01-2020, 11:08 AM
Jimmy N.'s Avatar
Originally Posted by Suny View Post
as we all love pics - here some references
1 Yellow OEM Fogs only ( Alla Lighting H10 LED Fog Lighghts 3000K Amber Yellow)
Mike, looking at those photos it's painfully obvious that your fog lights don't work as fog lights.
They put light higher than the low beams do, despite being mounted much lower.
It's not just an adjustment issue, unfortunately, as the OE fog lights have such a bad beam pattern that they really can't be adjusted correctly. They're best used as DRL, I think.
Jimmy N. is offline
post #50 of 59 (permalink) Old 02-01-2020, 11:58 AM
"I'll go all in."
CumminTryMe's Avatar
iTrader Score: 14 reviews
That yellow light would annoy the piss out of me.
"Don't let off, just stand on it! We've got parts!"
Combat Wounded Marine - Some Assembly Required
2012 2500 Crew Cab Long Box Limited
CumminTryMe is offline
post #51 of 59 (permalink) Old 02-01-2020, 12:06 PM
Cummins Dude
Dogpatch's Avatar
Originally Posted by Loki223 View Post
Just to make sure, you are referring to these?
Dodge Ram: XB LED - Fog Lights from Morimoto HID
The LED Projector fog lights? Or are you referring to an LED Bulb inside of a fog light housing?
I ran the X8 Projector fog lights on my 12 for several years, no resistors, no issues.
When i upgraded to my 18, i continued the plug and play approach, Just plugged them in. No issues, no resistors, no canbus cancelers, nothing. When i adjust settings for HID headlights the only fog light setting i changed was to disable the fog light drop out. I have had zero issues with the X8 Projector LED fogs
My Suggestion, with them haven worked for several years, is to check your grounds and your connectors. Sometimes the connectors might get loose, which can cause intermittent issues. Make sure your pins are fully seated and making proper contact. Especially since when you bench test the lights they work
The way the canbus system works, is at startup it will check the lights for any lights out. If it detects any issues, it will turn off power to that light, so the reason your factory light might not have worked at first is because it detected an issue, turned off power, then after a power cycle it checked again, and did not find an issue so it kept power on. I would lean towards the issue being more with the Morimoto light, or with the connector. Also, the morimoto staff is very knowledgeable and helpful. giving them a call might throw out an idea on something to check that none of us might think of that could solve the issue. If anyone else has ran into your issue, the manufacturer would be a fantastic place to start for assistance in troubleshooting.
Like you, on my 2015, the finickiest MF’ing truck on the planet when it comes to lighting, I just swapped the OEM fogs with the Morimoto XB LEDs. Didn’t have to OBD nothing in the computer. Plug and play with original harnesses. Couldn’t believe it was that simple. No issues for over a year now.
Here’s a couple of pics of the even low Broadcast pattern, light set up and Fog lights only pattern on the road.
Note, I’ve since changed out my HID bulbs to 5500k so they are whiter than in the photo.
ID:	866407   Click image for larger version
ID:	866419   Click image for larger version
Opie011, Loki223, Jimmy N. and 1 others like this.
2015 Ram 3500 Laramie CCSB SRW 4x4 6.7L CTD 370hp-800tq 68RFE 3:42's HID's XB LED Fogs BD TSB Amp Steps Air Bags 5er Prep Anderson Ultimate Hitch
Dogpatch is offline
post #52 of 59 (permalink) Old 02-15-2020, 07:58 PM
I think I'm going to have to order these morimoto xb fogs as one of my LED bulbs finally went dead. Hopefully they're going to have a sale soon 🤞
2014 2500 CCSB Big Horn Granite Crystal Metallic| Amp Steps| Thuren Coils & Fox's| 18x9 Rhino Warlords| 285/75/18 Nitto Ridge Grapplers| BD TSB| Airlift 5000 with Wireless One
Opie011 is online now
post #53 of 59 (permalink) Old 02-15-2020, 08:14 PM
Cummins Dude
Dogpatch's Avatar
I like mine.
ID:	867487   Click image for larger version
ID:	867489   Click image for larger version
Opie011 likes this.
Dogpatch is offline
post #54 of 59 (permalink) Old 02-15-2020, 08:21 PM
Jimmy N.'s Avatar
I could sell you a very lightly used set. I'm looking for something better.
Jimmy N. is offline
post #55 of 59 (permalink) Old 02-15-2020, 08:43 PM
PM me a price if you dont mind.
What do you not like about them?
post #56 of 59 (permalink) Old 02-15-2020, 09:32 PM
Jimmy N.'s Avatar
I'll have to look up what I ended up paying for them, Opie.
Anyway, they have maybe 5 minutes of usage on them.
What I didn't like was the light output when used in conjunction with good LEDs in the quads.
Oops, and I just realized that I had the ones for the 1500 in mind. They won't fit your 2500.
Once I have the 3500's headlight situation figured out, I can let go of the XBs for that one.
Jimmy N. is offline
post #57 of 59 (permalink) Old 02-15-2020, 09:48 PM
No worries.
I have the HR V4s for my lows in my quad lamps and hoping these XB wont disappoint.
post #58 of 59 (permalink) Old 02-15-2020, 09:53 PM
Jimmy N.'s Avatar
Uh, oh. That's exactly what I'm running, too.
Had I installed the XBs with OE bulbs in the headlights I may have been somewhat impressed, but...
Jimmy N. is offline
post #59 of 59 (permalink) Old 02-15-2020, 10:17 PM
Dang it...lol
Guess I'll keep researching!
