exhaust brake, tow haul, and traction control - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 1Likes
  • 1 Post By Ltngdrvr
post #1 of 10 (permalink) Old 01-24-2020, 01:21 PM Thread Starter
DEAD, I checked fuses. Is there something that may of gotten turned off in my vehicle information screen? When you push any of these buttons nothing comes on. 2014 ram 2500 ctd. Thanks...
Berkly1 is offline
post #2 of 10 (permalink) Old 01-24-2020, 01:46 PM
Ltngdrvr's Avatar
None of the switches in the center stack switch module work then?
Have you had the center stack cover off? Switch module harness disconnected?
URDiesel likes this.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
post #3 of 10 (permalink) Old 01-24-2020, 06:40 PM
Trowel2013's Avatar
IIRC, there was a thread a couple years ago about this phenomenon. I think it was caused by one of the batteries going bad. Get your batteries tested..... separately. Start with that.
Sent from my iPad using Tapatalk
2013-2500 Laramie 4x4-CC-Long Box-Auto-3:42
Trowel2013 is offline
post #4 of 10 (permalink) Old 01-24-2020, 06:58 PM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
My 2013 RAM 3500 did this exact thing during a cold snap. I removed the trim bezel, disconnected and reconnected the harness to that set of switches, and the problem was solved in my case.
2018 RAM 4500 Chassis Tradesman Crew Cab 60 C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Firestone FD690s, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 196,704 miles and 3,437 hours as of January 27th, 2020 (Average Miles Per Hour = 57.2)
gsbrockman is offline
post #5 of 10 (permalink) Old 01-25-2020, 12:07 AM Thread Starter
I wonder if it was like was said a bad or dead battery. This trick should really get used more. 2014 with 35000 on it
Anyhow after driving for a spell it all started to work again. Maybe dead battery
Berkly1 is offline
post #6 of 10 (permalink) Old 01-25-2020, 12:08 AM Thread Starter
Truck. Not trick. Lol
Berkly1 is offline
post #7 of 10 (permalink) Old 01-25-2020, 12:19 AM
Buyer of stuff..with OPM
Ram4Sam's Avatar
This will sound a bit goofy but......next time it does this, lock and unlock the doors with the switch on the driver door and see if the buttons start working, mine would......my 2014 truck did this quite a bit, the dealer spent a year and numerous repair attempts trying to fix this problem, threw a ton of parts at the truck, and never fixed it....
I ended up getting a new truck through the arbitration process.
Sam
2016 3500 Laramie SRW 4x4 CC LB ,Aisin,white w/brn-beige,B&W TOB/companion built 9/2015
Owned and gone, 1991 d250... 2001.5 2500qc...2014 3500 FCA buyback
Drivin' a Dodge Cummins since 1991.......
2008 Thor jazz 2870UK 5er....and 3 dogs.....
Ram4Sam is offline
post #8 of 10 (permalink) Old 01-26-2020, 01:27 AM
kevinc2004's Avatar
I had something simular on a 2012 truck. Traced down to a bent pin in that large power plug just above the engine at the fire wall. Never had another problem with it!
2017 Laramie Longhorn, 3500 CCLB, DRW, AS69RC, 4.10 geared, Air Suspension. 2015 Dynamax Triology 38RL
kevinc2004 is offline
post #9 of 10 (permalink) Old 01-26-2020, 04:05 AM
Had it happen a few times, but usually the next start everything was good. Hasn't happened in a long time. I did replace my batteries about 6 months ago though.
07 2500 CTD 4x4 Way to stock.....
Sold 2004.5 3500 4x4 CTD Laramie 6 spd std A few mods
Mocho is offline
post #10 of 10 (permalink) Old 01-26-2020, 12:14 PM Thread Starter
I tried to find the thread u are referring too. Could you give me some help
Berkly1 is offline
