wiring in chargers - Dodge Cummins Diesel Forum
 3Likes
post #1 of 17 (permalink) Old 01-21-2020, 08:23 PM Thread Starter
wiring in chargers
anyone ever done a power inverter with a couple AC plugs somewhere to wire in a charger (Ex: flashlight charging base) to their trucks that turn off without the key in?
Sent from my SM-N975U using Tapatalk
stx.dead.I is offline
post #2 of 17 (permalink) Old 01-21-2020, 09:24 PM
Ltngdrvr's Avatar
You mean like the factory optional one?
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
post #3 of 17 (permalink) Old 01-21-2020, 10:08 PM
When I got my truck it had the factory one. I thought great, now I can charge my batteries for my tools in the truck.
Turns out the plug is not rated very high, so I never used it.
2017 Laramie CCLB 4x4
Tim'sDiesel is offline
post #4 of 17 (permalink) Old 01-21-2020, 11:12 PM
Ltngdrvr's Avatar
Heck, I have a triple plug adapter in mine, have my wall plug phone charger and my phone signal booster both plugged in, but I guess those are still low enough draw not to overload it.
I think it is a 150 watt maybe???
Ltngdrvr is offline
post #5 of 17 (permalink) Old 01-22-2020, 12:17 AM
HeavyTwo's Avatar
I have not seen an OEM charger, any link? I'd like to see it.
I'd like to buy an inductive type charger. No cords, just park with bumper next to inductive coil. You can hang the coil, so as you park, the coil behind the grille bumps on to the one hanging at your parking spot.
Kinda like smartphone wireless charging, but for cars/trucks.
Maybe even a cordless block heater too. It might be harder, as it needs more power.
2014 RAM HD. Cummins 6.7 364.5SXE Turbo. EZLynk Tuned. Straight piped. Air-Ride.
HeavyTwo is offline
post #6 of 17 (permalink) Old 01-22-2020, 01:10 AM
Ltngdrvr's Avatar
OEM charger???
Nobody said anything about an OEM charger, we were talking about the OEM inverter, that you might plug a charger into.
Ltngdrvr is offline
post #7 of 17 (permalink) Old 01-22-2020, 01:56 AM
You can get ones that plug into the power outlet. One is keyed and the other is not. But inverters use some power just sitting there on even if you have nothing plugged in. There are also Mopar ones and aftermarket ones you can mount elsewhere. Just don't leave them on and kill batteries.
bigfish95971 is offline
post #8 of 17 (permalink) Old 01-22-2020, 02:18 AM
P2609 Fanatic
Electrojake's Avatar
Still trying to decipher the question.
But I'll give it a shot...
Small inverter, say 150 to 350 watts = Simple.
Big inverter 2 or 3 kW = doable but a bit more involved as you would need a solenoid between the inverter input and the battery.
BTW...
If you're gonna' go through the aggravation of doing a nice clean install I'd go with a pure sine inverter over a modified wave inverter, but that's just me.
-Ej-
2016 Longhorn 3500 4x4 short-bed in Pearl White.
Cummins HO, AISIN, CrewCab, SRW, Ride-Rite remote rear air suspension, Edge CTS2, plus the typical after-market bolt-on crap.
> Reduced current grid heater mod w/all emissions intact.<
*Hauling a 2017 Northstar Arrow-U.
Electrojake is offline
post #9 of 17 (permalink) Old 01-22-2020, 08:55 AM
I wired in a 1000W PSW inverter on a shelf behind the rear window under my cap. Put in a solenoid at the battery that only connects when battery V is above 13.x, so effectively is only on when the engine is running. Turn on/off the inverter thru a relay connected to one of the truck's auxiliary switches.
Usually use it to charge my trailer batteries or run a frig. But it can also run a small angle grinder/cutoff for field repairs.
Electrojake and Tim'sDiesel like this.
2016 2500 4x4 Reg Cab SLT, Lux, Snow Chief
Synergy Drag Link, 2507# payload
brulaz is online now
post #10 of 17 (permalink) Old 01-22-2020, 06:00 PM
Just looked at my Makita chargers:
single 240W
double 460W
post #11 of 17 (permalink) Old 01-22-2020, 06:45 PM
HeavyTwo's Avatar
OEM charger???
My mistake. For some reason I had car charging on my mind. &#x1f609;
HeavyTwo is offline
post #12 of 17 (permalink) Old 01-22-2020, 07:25 PM
I think it's 125-150w burst but something like 90w continuous.
Xokia is offline
