Swapping 3.42 to 4.10 Gears Budget - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 47Likes
post #1 of 46 (permalink) Old 01-17-2020, 12:21 PM Thread Starter
Trcolem09's Avatar
Hello, y'all,
I just wanted to know what all it takes to swap out the gears in my 14 2500 from 3.42 to 4.10 as budget friendly as possible. I am located in Joplin, MO and I have found some entire kits to re-gear for around $1,100 to 1,300 and I was just wanting to know if I could re-use stock internals with my current gears for the swap.
I have watched a lot of re-gearing youtube videos and its super involved to DIY it. I am new to the whole aspect of re-gearing my boiiiis.
Learn me!
Thanks, y'all!
Thomas R. Coleman
14 Ram 2500 (Soon to have 2nd gen swap & 4.10 Gears)
Trcolem09 is offline
post #2 of 46 (permalink) Old 01-17-2020, 12:52 PM
G. Mcpherson's Avatar
Check out C&M Gear. 4.10 F&RR AAM with Rebuild kits about 840.00 out the door.
SRich12 and 15LIMITED2500 like this.
2018 Ram Big Horn. Crew Cab Short Box. 6.7Ltr. 68 RFE. Thuren Suspension, 4.10 AAM Gears
G. Mcpherson is offline
The Following User Says Thank You to G. Mcpherson For This Useful Post:
Trcolem09 (01-17-2020)
post #3 of 46 (permalink) Old 01-17-2020, 12:56 PM Thread Starter
Trcolem09's Avatar
$840 out the door is awesome! Way more in my range of what I am wanting to spend!
Thomas R. Coleman
post #4 of 46 (permalink) Old 01-17-2020, 12:56 PM
nick00less's Avatar
nick00less is offline
The Following User Says Thank You to nick00less For This Useful Post:
post #5 of 46 (permalink) Old 01-17-2020, 12:57 PM
nick00less's Avatar
If you had a 2018 yes. Your truck is 6 years old. Don’t reuse stock internals.
'18 6.7 S472-5 Blade 2018 Build
post #6 of 46 (permalink) Old 01-17-2020, 12:59 PM
Rear Admiral Rickard Onmi
Loki223's Avatar
I would caution you to reach out to someone familiar with gear swaps to assist you, or do the install. Installing gears isn't as easy as other things and does require the correct tools, and knowledge to use the tools. Once you have the knowledge and the tools it's pretty straight forward, but i would caution you to bring in someone to help you set everything up correctly. It's a great learning experience, but your learning experience can go from budget friendly to expensive quickly if you don't have someone to help teach you
2018 Ram 3500 Limited - Crew Cab Long Box 4x4 SRW Stock at the moment, but that will change
Make your puddle lights great again!
SUPPORT SITE VENDORS, THEY MAKE ALL THIS POSSIBLE
HELP ME UPDATE MY IMAGES, IF YOU SEE A BROKEN IMAGE LINK, SEND ME A PRIVATE MESSAGE SO I CAN UPDATE THE IMAGE TO A NEW HOSTING SITE
Loki223 is online now
The Following User Says Thank You to Loki223 For This Useful Post:
post #7 of 46 (permalink) Old 01-17-2020, 01:01 PM Thread Starter
Trcolem09's Avatar
Exactly, the main reason why I am just going to have someone do it while I just watch because all of the particulars involved with aligned and making sure everything is tightened to spec.
I do appreciate the FYI!
Thomas R. Coleman
post #8 of 46 (permalink) Old 01-17-2020, 01:02 PM Thread Starter
Trcolem09's Avatar
Yes, sir!
Seems it's going to have to go that route! I rather not screw anything up! Budget friendly as much as possible without cutting corners to make the swap even more expensive down the road.
Thomas R. Coleman
post #9 of 46 (permalink) Old 01-17-2020, 01:04 PM
nick00less's Avatar
The only complex tools are a dial caliper and a torque wrench. Spend 5 minutes on YouTube to learn how to use them and you’re all set. It’s not hard. Just time consuming. You can do it by yourself in one day.
Jimmy N. likes this.
post #10 of 46 (permalink) Old 01-17-2020, 01:16 PM
Unreconstructed
Alabama Mud Machine's Avatar
Originally Posted by Trcolem09 View Post
Hello, y'all,
Learn me!
Thanks, y'all!
F&R gear sets, F&R Master Install Kita with good bearings (Timkin), and possibly new carriers, but Iím not 100% on that. You can probably look that up to see if the 3.42 carriers will work. You will need gear paint, and a dial caliper with a magnetic base to set backlash. Lots of brake clean, new RTV sealant (high-temp), and something to clean the old sealant off the diff & cover. I use a wire cup brush on a 1/4Ē die-grinder. Just cover up everything before, so you donít get particles in your diff.
If youíve never done it before, get someone experienced to help you so you learn the right way to do it.
Trcolem09 likes this.
2017 Ford Mustang GT Performance Pack - 5.0 / MT-82 6-speed, 3.73's, TORSEN LSD diff, Brembo's, oversize rad & oil cooler, staggered 255/275 P-Zero's, Custom muffler delete.
2007.5 Ram 2500 QC/SB 4x4 - 6.7 / 68RFE - Custom EFI Live tuned, and a few other mods...
1996 Ford F-250 4x4 - 7.3 PSD / ZF-5 - Awaiting 12V, ZF-6, & high-pinion D60 front axle swap
Special thanks to: www.rollinsmokediesel.com , Shibby Engineering, Black Ops Diesel, Motorsport Diesel, EFI Live, & Hardway Performance
Alabama Mud Machine is online now
post #11 of 46 (permalink) Old 01-17-2020, 01:17 PM Thread Starter
Trcolem09's Avatar
nick00less - You made my day sir! I would love to tackle this project! Could I rent tools from like auto zone, sir?
Thomas R. Coleman
post #12 of 46 (permalink) Old 01-17-2020, 01:19 PM Thread Starter
Trcolem09's Avatar
Love the picture haha, thanks brother! I'll look into it!
Thomas R. Coleman
