‘17 Factory block heater - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 14Likes
post #1 of 22 (permalink) Old 01-16-2020, 06:19 PM Thread Starter
NOTYALC's Avatar
Last winter my factory block heater worked great, I’d plug it in at night and in thee morning it would be some what warm and there wasn’t a “wait to start” countdown. This year it’s not the same. It’s the same temp out side as last year (around -5 to -10) and I’ll have it plugged in over night and it doesn’t warm at all. I have to wait for the countdown and it’s definitely not a quick warm up.
Is there a fuse for the block heater that I could have blown at some point? I just can’t seem to find one. How else could I figure out if the block heater is dead?
NOTYALC is offline
post #2 of 22 (permalink) Old 01-16-2020, 06:52 PM
Ltngdrvr's Avatar
There is no fuse, cord plugs directly into the heater. Could be a bad heater, or could be that the cord isn't connected properly.
The block heater is right next to the oil filter in the side of the block if you want to check it out. Pull the air intake tract out and you'll have room to work.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
post #3 of 22 (permalink) Old 01-16-2020, 07:15 PM Thread Starter
NOTYALC's Avatar
Ah alright, thanks for the info!
NOTYALC is offline
post #4 of 22 (permalink) Old 01-16-2020, 07:37 PM
Ltngdrvr's Avatar
Block heater location with cord and plastic retainer holding cord onto the heater...
Electrojake likes this.
Ltngdrvr is offline
post #5 of 22 (permalink) Old 01-16-2020, 10:04 PM
chknkatsu's Avatar
stupid question, but are you sure you have power at the outlet?
Jimmy N. and Tim'sDiesel like this.
2017 Tradesman 3500 CCSB SRW 4x4 G56
Valair Organic DD Quiet
Full Delete Tuned by Anarchy Diesel
chknkatsu is offline
post #6 of 22 (permalink) Old 01-16-2020, 10:11 PM
Lins's Avatar
See if there’s heat above ambient at that location after being plugged in. There’s also no fuse in the block heater cord.
Lins is offline
post #7 of 22 (permalink) Old 01-16-2020, 10:25 PM
Durk's Avatar
Get a multimeter and see if you have an open circuit. (. Put leads across both hot wires of plug ) Maybe it’s burnt out you may even get a local. Auto Parts store to check it for you for free
Black trucks are the fastest.
Durk is offline
post #8 of 22 (permalink) Old 01-18-2020, 09:49 PM
BrianF's Avatar
I just did the multimeter test on my gasser. Test continuity, and have a look at the resistance. The thing either works or it doesnt.
2017 Ram 3500 Megacab, SLT, True Blue, SRW, CTD, AS69RC. Ubique
BrianF is offline
post #9 of 22 (permalink) Old 01-18-2020, 10:10 PM
7492's Avatar
Resistance should be around 19 ohms, dependent on temperature.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
2020 KW T370 PX9 380HP 1250lbft @ 1400 RTO14908LL
7492 is offline
post #10 of 22 (permalink) Old 01-19-2020, 06:48 PM Thread Starter
NOTYALC's Avatar
Thanks for help, I’ll give it a try and test it.
NOTYALC is offline
post #11 of 22 (permalink) Old 01-19-2020, 07:27 PM
You may have burnt it out by leaving it plugged in all the time.
I would use a timer, if it was mine. Just a thought!
2016 Laramie 2500 CC 4X4 6.7L CUMMINS
URDiesel is offline
post #12 of 22 (permalink) Old 01-19-2020, 08:34 PM
7492's Avatar
The heater by design, have a 100% duty cycle. Leave them powered up as much as desired. Standby generators have heaters running for years.
7492 is offline
