Turbo Actuator Not a Recall? WHY!? - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 15Likes
post #1 of 35 (permalink) Old 01-15-2020, 09:53 PM Thread Starter
bicyclesanddiesels's Avatar
I am so so close to waiving the lemon flag and getting rid of this RAM. The constant bleed of stuff going wrong with what was originally a $70K truck is at this point a joke. I get it, you pay to play. But DAAAAAAMN!
The turbo actuator seems to be a problem across the board with these motors. Mileage doesn't seem to matter either.
When does something become a recall? Or is this the magic question?
I have 2 actuator codes that started to come on and off over the last few days. I bought the reman from M&D and will dig in within the next couple of weeks. I'll take my time and test the current one as best as I can to see why it failed. Install new one and recalibrate with AlfaOBD.
If anyone has advice or words of comfort. I'll take it.
Trcolem09 likes this.
2014 3500 - 104K Miles
Cooper 37's on Method 18's
Thuren King 2.5's
bicyclesanddiesels is offline
post #2 of 35 (permalink) Old 01-15-2020, 10:35 PM
Recalls generally happen when "safety" is involved, not always failing parts unless they are in significant numbers. With that said it's hard to say how wide spread this issue is? We see a fair amount on here But a lot of people only join forums or post when they have an issue and not when things are working fine. What seems like a disproportionate number of failures on here may be a real small percentage in the real world?
Something I would like to know is did they change the turbo actuator design in the 2019 trucks? If so that would be a clue that it was a concern for them. If it's the same parts I have in my 2016 I'm guessing the failure rate is pretty low across the fleet?
2016 Ram 2500 Big Horn Mega cab, 285/75-18 (35's) Nitto Ridge Grapplers. Fuel Hostage III 18x9 +18 BS Wheels. Bilstein 2.3″ Front Lift, 1" rear spacer.
mtnrider is offline
post #3 of 35 (permalink) Old 01-15-2020, 10:41 PM
Ltngdrvr's Avatar
Yup, recalls are only for safety related issues, and a turbo actuator doesn't qualify.
Best it could be is a service bulletin.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
The Following User Says Thank You to Ltngdrvr For This Useful Post:
bicyclesanddiesels (01-16-2020)
post #4 of 35 (permalink) Old 01-16-2020, 07:18 AM
Trowel2013's Avatar
I think it is a well known and widespread issue. I was repeatedly warned by the service techs that it isn't a if but when problem. Despite being told years ago to be ready for it, it caught me off guard last year. Such a stupid, expensive problem to have with relatively low miles, but it is what it is I guess.
Sent from my iPad using Tapatalk
bicyclesanddiesels likes this.
2013-2500 Laramie 4x4-CC-Long Box-Auto-3:42
Trowel2013 is offline
post #5 of 35 (permalink) Old 01-16-2020, 09:31 AM
Lins's Avatar
You basically have had notice your actuator is failing and to have it looked at so it isn’t a safety issue.
Lins is offline
post #6 of 35 (permalink) Old 01-16-2020, 10:19 AM
RammerJam's Avatar
Is the actuator part of the extended drive train warranty??
2017 4X4 SLT Ram Big Horn 2500 SB Cummins
RammerJam is offline
post #7 of 35 (permalink) Old 01-16-2020, 10:33 AM
Walker111's Avatar
I don't think so. I think they look at it as the turbo is, but the actuator isn't.
16 CTD 2500 Bright White Crew Cab
Walker111 is offline
post #8 of 35 (permalink) Old 01-16-2020, 10:57 AM
The turbo actuator isn't covered under the emissions warranty, but it isn't excluded by the listing of not-covered components in the MaxCare Ram extended warranty I purchased last year. It does not appear to be covered by the extended powertrain warranty -- only the near-bumper-to-bumper MaxCare, and that might have changed for more recent purchases.
The DPF, SCR, and VGT actuator are the three main reasons I bought the MaxCare, and the terms of that warranty have changed since my purchase to exclude at least the DPF. That service plan doesn't appear to be nearly the deal it was a year ago now.
2016 3500 LL CC LB 4x4 CTD DRW Delmonico red. BDS 3" truss radius arms & 3" coils w/double Fox 2.0s. Synergy drag link & tie rod. Dual stabilizers.
Carli track bar. Carli torsion anti-sway. Synergy steering box stabilizer. Rear 2" blocks. Weldcraft 17x8 custom steel duallies w/Mickey Thompson 295/70-17 ATXP3s.
AEV axle covers. AEV vented hood. Luverne polished stainless steel boards. Bakflip MX4 hard cover. Bushwacker max coverage flares.
B-pillar vinyl delete. Mopar door chrome. Areion semi-truck flap mounts. Steelcraft polished stainless light guards.
EricPeterson is offline
post #9 of 35 (permalink) Old 01-16-2020, 10:57 AM
dieselbuilder's Avatar
So not calling this a safety issue is crap try pulling out in traffic and the truck falls flat on its face this happened to me almost got hit from behind and sideswiped by oncoming cars and yes it had been acting up in the few days before this happened and the cost to replace a five thousand dollar bill is BS this should fall under live time emissions
dieselbuilder is online now
post #10 of 35 (permalink) Old 01-16-2020, 11:04 AM
Recalls are for three reasons, safety, an issue that is hurting sales potential, or something cheap that can avoid huge costs later under warranty. Only one that can be forced is a safety recall, the other are purely voluntary. So I guess its only two reasons, Mandated because of safety and saving FCA money, not you.
For issues like this, you see a class action suit if enough fail.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
post #11 of 35 (permalink) Old 01-16-2020, 01:35 PM
Like any big Corporation, they way death and law suites over cost people always loose
post #12 of 35 (permalink) Old 01-16-2020, 01:59 PM
Rear Admiral Rickard Onmi
Loki223's Avatar
Most actuators fail outside of warranty coverage. Parts are designed to last through warranty coverage Any lasting beyond that is just a bonus and not intentional. The actuator on my 12 lasted for 150k miles. If the actuator on this truck lasts that long i'll be happy. People get mad when they have to replace parts, yet parts break. thats just a fact of life. Back in the 70s a vehicle lasting to 100k miles was a big deal. Now that vehicles tend to last longer and get repaired to last longer, when a part fails after 100k miles of service people suddenly get surprised. Why isn't my old truck with lots of miles in perfect like new shape anymore? this is amazing......
2018 Ram 3500 Limited - Crew Cab Long Box 4x4 SRW Stock at the moment, but that will change
Make your puddle lights great again!
SUPPORT SITE VENDORS, THEY MAKE ALL THIS POSSIBLE
HELP ME UPDATE MY IMAGES, IF YOU SEE A BROKEN IMAGE LINK, SEND ME A PRIVATE MESSAGE SO I CAN UPDATE THE IMAGE TO A NEW HOSTING SITE
Loki223 is online now
