HID: Morimoto vs Diode Dynamics? - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 58Likes
post #1 of 93 (permalink) Old 01-10-2020, 03:09 AM Thread Starter
swyman2's Avatar
I have been beating myself for the last year on what to get. I love reading Nicks posts as he seems to have tried them all but I do not want to go through the work/time/expense of buying different housings, baking them, buying different projectors to install in those aftermarket housings.....ect.ect. Don't get me wrong, the light pattern is amazing, I'm just looking (hoping) for an easy way. I have the factory projectors so I want to just install a HID kit in the lows and LED's in the high. From my research so far I personally think Morimoto and DD are the best out there. The pricing is about the same so is this just a Ram vs Chevy/Ford thing? Have any of you installed both because of a failure or lack of performance? I will be adjusting truck with Alpha so I don't plan on any anti-flicker stuff.
'16 3500 Laramie Mega 4x4 DRW Aisin Air 4.10
swyman2 is offline
post #2 of 93 (permalink) Old 01-10-2020, 07:26 AM
nick00less's Avatar
If it’s a regular bulb they’re all the same. Morimoto/DIODE..it all comes from the same factory. They both have way to high of a markup when there’s nothing special about them.
Morimoto
Diode Dynamics
So don’t go beating yourself up if you think you got the wrong one. The real difference doesn’t come into play until you upgrade to Osram or Philips.
Lastly, don’t go spending hundreds on a cheap bulb (Morimoto/Diode). Just buy it off amazon. Not to mention even name brand bulbs can be had off amazon for a fraction of the price that others sell it for.
This probably isn’t anything new for yah but I hope it helps.
Jimmy N. and G. Mcpherson like this.
'18 6.7 S472-5 Blade 2018 Build
nick00less is offline
The Following User Says Thank You to nick00less For This Useful Post:
swyman2 (01-10-2020)
post #3 of 93 (permalink) Old 01-10-2020, 08:16 AM Thread Starter
swyman2's Avatar
So you're saying Phillips or Osram bulbs would be as good or better than the HID's?
swyman2 is offline
post #4 of 93 (permalink) Old 01-10-2020, 09:10 AM
nick00less's Avatar
Technically all bulbs fall in the HID category. Philips and Osram will be better. However they were only used as a pricing example, not sure if they make a 9006/9012 bulb for stock projectors.
post #5 of 93 (permalink) Old 01-10-2020, 09:39 AM
nova3930's Avatar
Be aware buying osram off Amazon, they may come from Latvia and take a month to get to you.....
Sent from my Pixel 3a using Tapatalk
2015 Ram 2500 Crew Cab - Calibrated Power Emission Intact Tune -AlphaRex / Morimoto / Hikari Ultra Headlights -Fox IFP Steering Damper
nova3930 is offline
post #6 of 93 (permalink) Old 01-10-2020, 09:40 AM
I had retro solutions 55W HIDs and over the past 3 years I’ve had one ballast and one bulb go out. I recently made the switch to headlight revolution. 55W low beam 35W fogs. Looks really great I was just expecting a little better color on the 6000k temp. Quality of ballast, wiring is pretty substantial. I would consider them
Danny62217 is offline
post #7 of 93 (permalink) Old 01-10-2020, 10:27 AM
Morimotos ballasts have come a long way - now Hylux (basically the best aftermarket) does their electronics. The XB series is solid.
If you’re retrofitting, always use an OE (Philips or Osram) D2S bulb - most of the rebased amp connector bulbs are similar quality but I still will recommend Morimoto.
Why? The “Elite HID” kit can be had for about $120 on a good holiday sale, and it’s warrantied for an entire 5 years
I’ve posted about it before but TRS has such good warranty service I literally had an old old XB series bulb fail, ONE MONTH BEFORE WARRANTY EXPIRED - 4 yrs 11 months - also had some corrosion on the relays
A couple of pics and about 48 hours later there were a brand new pair of bulbs and fresh relays on my way to my house shipped 2 day priority mail.
And about 2 years prior, I had a ballast fail (old style “SS” ballast which was not reliable in the least if anyone is in the retrofit world) and I got a new pair of ballasts as well
Diode Dynamics is top notch as well I just am sharing my experience. I usually buy my stuff from Caesar @ Lightwerkz in NJ as he always has great sales and support and is one of the top retrofitting operations out there
2018 2500 Big Horn Sport - 6.7L 68RFE - CC 6'4"
Ricky_Bobby is offline
post #8 of 93 (permalink) Old 01-10-2020, 01:54 PM
nick00less's Avatar
I guess there’s no substitute for customer service! I also didn’t know Morimoto and Hylux joined. That’s awesome.
post #9 of 93 (permalink) Old 01-10-2020, 05:55 PM
For the newer XB ballasts (2nd gen) yes I am pretty sure Hylux does the electronics for them. The other ballasts I recommend are the 2A888 35w ballast - yes it’s a Canbus ballast but works great on cars that don’t need it - Caesar said they literally have a .2% failure rate
post #10 of 93 (permalink) Old 01-11-2020, 01:44 AM Thread Starter
swyman2's Avatar
I went back and found your old thread " INNOVITED 55w 5000k in stock projectors" and now I'm more confused....why didn't you just purchase bulbs like you advised me in this thread instead of installing these off of Amazon? Or knowing what you know now this is what you are advising me to do?
swyman2 is offline
post #11 of 93 (permalink) Old 01-11-2020, 09:33 AM
nick00less's Avatar
Like you, I too didn’t want to retrofit my headlights. Simply wanted a cheap drop in kit.
Besides, factory projectors are 9012 bulb. Osram and Philips aren’t.
post #12 of 93 (permalink) Old 01-11-2020, 04:34 PM
Cummins Freak
SRich12's Avatar
Yes, Amazon needs to be like Ebay and disclose when they are coming from a foreign Country!! I ordered some and now it is saying Feb.!!!
nova3930 likes this.
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli Level/295 Toyo AT2's /Full Console swap w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is online now
