steering box adjustment - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 1Likes
  • 1 Post By Lins
post #1 of 7 (permalink) Old 12-22-2019, 01:09 AM Thread Starter
K9Kodi's Avatar
has anyone adjusted their steering boxes? over center or preload. i've our the steering shaft bushings in and it helped a lot, but i can visibly turn the wheel and shaft slightly back and forth before the box engages the steering linkages. has anyone here had any luck with box adjustment?
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is offline
post #2 of 7 (permalink) Old 12-22-2019, 11:09 AM
Lins's Avatar
I’ve seen a couple people on here mention doing it. I haven’t done it on this truck but I did on our ‘53 GMC this summer. Apparently still pretty similar. Do it with everything as dead straight as possible as that’s when the box has the least amount of play. Tighten it just enough to remove the play. If you have any extra resistance after you need to back it off a bit or you can do some damage.
Lins is offline
post #3 of 7 (permalink) Old 12-22-2019, 12:58 PM
Jared Herzog's Avatar
Do you have a link for the bushings? I need to get them done soon also but havenít found them locally.
Ram 14 2500 RIP 14,700 Stock. 68RFE."The Lemon"
Ram 15 3500 Dually. Stock. Aisin. N Fab wheel to wheel. Weather Tech Mats. Big D Steering Box Brace.
Jared Herzog is offline
post #4 of 7 (permalink) Old 12-22-2019, 02:06 PM
Lins's Avatar
Originally Posted by Jared Herzog View Post
Do you have a link for the bushings? I need to get them done soon also but haven’t found them locally.
Google EMF intermediate shaft bushings.
Jared Herzog likes this.
Lins is offline
The Following User Says Thank You to Lins For This Useful Post:
Jared Herzog (12-24-2019)
post #5 of 7 (permalink) Old 12-22-2019, 03:15 PM Thread Starter
K9Kodi's Avatar
to be honest, i went to home depot and got some thin plastic pipe the same inner and outer diameter as the emf bushings and bought a foot for like 2 bucks. it made a noticeable difference although now since they are a plastic solid piece where there was a rubber isolator i can hear some sound as the plastic carries it better then the dampening rubber.
i said screw it, literally, and went ahead and adjusted my steering box. loosened the capture nut and adjusted the adjuster screw a little more then 1/4 turn a little less then half
K9Kodi is offline
post #6 of 7 (permalink) Old 12-24-2019, 10:04 AM
Did the adjustment make any difference? I have the fastenal spec from the other thread but cant find the parts at my local fastenal. I think I will go your route and grab something at Lowes.
post #7 of 7 (permalink) Old 12-24-2019, 10:10 AM Thread Starter
K9Kodi's Avatar
i would say the steering box adjustment absolutely worked. i almost have to recentrr my steeering wheel now. i'm gonna go another 1/4 turn n see what happens.
K9Kodi is offline
