2018 3500 Converting 20" to 18" Wheels & Tires - Dodge Cummins Diesel Forum
 35Likes
post #1 of 54 (permalink) Old 12-15-2019, 03:50 PM Thread Starter
Question 2018 3500 Converting 20" to 18" Wheels & Tires
So I am a newb for sure. I recently picked up a brand new leftover 2018 3500 Big Horn with the 20" wheel package, mainly because I wanted the 6-speed manual transmission. Anyway, the stock 20" tires, and the wheels are boring and don't work well in these WV Mountains.
So, I would like to order a new full set of Fuel Wheels and a set of Nitto Ridge Grapplers or the Toyo Open Country MT tires in 35x12.5Rx18LT. My question is, are there any mechanical issues with converting these 20" Ram wheels to a set of 18" Fuel wheels such as brake rotors, brakes, brake lines, TPSI sensors, etc?
The tires should be Load F, but on 20" tires, you only get a 3640lbs load rating, where as the Load F, 18" tires give you the heavier 3970lbs load rating. I like the taller sidewall of the 18" tires, and they give you a higher Load Rating for towing/carrying loads.
What do you guys think?
Jimmy N. likes this.
2018 Ram 3500 Big Horn 6-SPD Manual SRW 4WD CC LB 6.7L
Glockem^45 is offline
post #2 of 54 (permalink) Old 12-15-2019, 04:06 PM
RamHunter18's Avatar
You shouldn't have any issues at at unless you go with a crazy off set wheel
18 Ram 2500 Big Horn 68rfe, CTT intact tune, Revmax vb,
RamHunter18 is online now
post #3 of 54 (permalink) Old 12-15-2019, 04:12 PM
Cummins Freak
SRich12's Avatar
Yes you will be fine just stay in the + offset!! Most recommended is +18 or so...
bcflyfisher likes this.
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli Level/295 Toyo AT2's /Full Console swap w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is online now
post #4 of 54 (permalink) Old 12-15-2019, 04:17 PM
skeemsCTD's Avatar
I have 35x12.5x18lt ridge grapplers on my 2017 ram 2500 with +1 offset fuels only had to trim inside plastic off of flares at the front,very minimal. Clears rotors and everything just fine.
ID:	862909   Click image for larger version
2017 Ram 2500 Outdoorsman CTD CCSB 4X4, 68RFE, HBS 2" Level, Thuren Track Bar, Bilstein 5100's, 18x9 +1 Fuel Maverick D538, 35x12.5 Nitto Ridge Grappler, Dee-Zee EZ Drop
skeemsCTD is offline
post #5 of 54 (permalink) Old 12-15-2019, 04:51 PM
Ltngdrvr's Avatar
What about the 20" makes them not work well in West Virginia???
Loki223 likes this.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is online now
post #6 of 54 (permalink) Old 12-15-2019, 05:46 PM
upflying's Avatar
Just a guess but the 20's have shorter and stiffer sidewalls, might ride a bit rougher and not the best tire for off-roading.
20's look good around the shopping malls though.
2018 Ram 2500 Tradesman, CC/SB/4X4/CTD/68RFE, stock, white, no bells and whistles.
Kelderman rear air springs, ARE cap, Bedrug, Carhartt seat covers, Huskyliner floor mats, Huskyliner mud flaps, Lund side steps, Tradesman emblem on tailgate
upflying is offline
post #7 of 54 (permalink) Old 12-15-2019, 07:52 PM Thread Starter
Thumbs up
I just think the stock 20" wheels are boring. As for the stock tires, they aren't doing well in the snowy/icy roads. I have slipped bad several times in this truck as we approach wintertime already, and that isn't a good feeling in a brand truck.
post #8 of 54 (permalink) Old 12-15-2019, 07:53 PM Thread Starter
Question
Sweet rig there skeemsCTD. Curious, do you have a leveling kit on the front to fit those 35's under there?
Also, did you go from the 20" wheels down to the 18" as well like I am wanting to do?
post #9 of 54 (permalink) Old 12-15-2019, 07:55 PM Thread Starter
Question
Oh, I thought most guys run the -12 offset on the Fuel wheels and 35s ?
post #10 of 54 (permalink) Old 12-15-2019, 08:06 PM
goingcamping2's Avatar
I went with the Method Mesh 18x9 +18. With the factory flares, they sit just about flush with the flares. Not that you asked, imho the fuel wheels are over played. Every other Ram has fuel wheels. Method as well, if were being honest. Look around, see if there are other styles/brands you like? Flame away!!
Radride likes this.
2016 Ram 2500 4x4 Cummins Outdoorsman/ARE V Topper w/ Yakima Rack/Bedrug/D-Z tailgate assist/Thuren 2" Overland Leveling Kit/
Method "Mesh" 18x9 +18/Toyo Open Country R/T 35/12.50 x 18/Amp Power Steps
goingcamping2 is offline
post #11 of 54 (permalink) Old 12-16-2019, 01:11 AM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
I may need to look into ditching my 19.5s as Im only 1/2 away from joining the Mall Hauler Clique.
2018 RAM 4500 Chassis Tradesman Crew Cab 60 C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Firestone FD690s, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 187,948 miles and 3,293 hours as of December 23rd, 2019 (Average Miles Per Hour = 57.1)
gsbrockman is offline
post #12 of 54 (permalink) Old 12-16-2019, 08:12 AM
Wait... Are shopping malls still a thing?
