Cummins intake baffle removed and upgrade - Dodge Cummins Diesel Forum
 124Likes
post #1 of 92 (permalink) Old 12-10-2019, 11:55 PM Thread Starter
57buick's Avatar
If you've done your research you have learned three things about the cummins intake system
1. the 13+ Rams have whats called a "Ram Air" system which means it pulls air from the front grill when it needs it. So an aftermarket cold air intake is pretty much a waste of money on this engine.
2. It has been dyno proven that removing the baffle and foam from your stock intake tube, you will actually lose a couple psi of boost and lose some cfm of air. Thats because of the large lip that would be left inside the stock tube.
3. the factory air filter flows more air than your engine can ever use unless your building a race motor and the factory filters WAY better than any of those aftermarket filters. K&N and similar filters allow more dust and particles into your cylinders at the trade off of allowing more air (but again more air is unusable)
So my idea is rather than a complete cold air system is to just replace the stock tube with this air raid tube which solves these problems and gives a nice smooth bend for the air flow.
ID:	862617   Click image for larger version
Name:	stock silencer.JPG
ID:	862619   Click image for larger version
Name:	stock tube inside.JPG
ID:	862621   Click image for larger version
2500/6 and HeavyTwo like this.
2015 Cummins 2500 Laramie Deleted 6" lift 37" Nittos
57buick is offline
post #2 of 92 (permalink) Old 12-11-2019, 12:05 AM
K9Kodi's Avatar
very cool
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is offline
post #3 of 92 (permalink) Old 12-11-2019, 12:23 AM
Ltngdrvr's Avatar
So, this was "your idea"???
Uh, that airraid intake tube has been on the market for a few years, so I think someone else had the idea a long time before you did!
My issue with that tube is that airraid charges $153 for a plastic tube, a silicone connector and a couple of clamps.
URDiesel, Loki223 and Gr8bawana like this.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
post #4 of 92 (permalink) Old 12-11-2019, 12:26 AM Thread Starter
57buick's Avatar
Yep its been on the market for a long time, just meant that my idea is that this is all I need. I agree its a little over priced but still it was the only thing I found online other than building my own tube and buying the silicone couplers and in the end that cost almost as much buying the individual pieces so figured this was easier
57buick is offline
post #5 of 92 (permalink) Old 12-11-2019, 12:31 AM
Ltngdrvr's Avatar
Well, my idea is a lot cheaper, and works just fine, and that is to leave the stock muffler in place and not worry about it!
Ltngdrvr is offline
post #6 of 92 (permalink) Old 12-11-2019, 12:40 AM Thread Starter
57buick's Avatar
Yep, that's another option
bcflyfisher likes this.
57buick is offline
post #7 of 92 (permalink) Old 12-11-2019, 12:47 AM
K9Kodi's Avatar
why do people have to rain on others parades. hahaha. dudes happy he did something. he didn't hurt anyone. oh well, let em roll
K9Kodi is offline
post #8 of 92 (permalink) Old 12-11-2019, 01:25 AM
HeavyTwo's Avatar
Ive been wanting to do the same mod. I may do it soon.
2014 RAM HD. Cummins 6.7 364.5SXE Turbo. EZLynk Tuned. Straight piped. Air-Ride.
HeavyTwo is offline
The Following User Says Thank You to HeavyTwo For This Useful Post:
57buick (12-11-2019)
post #9 of 92 (permalink) Old 12-11-2019, 07:46 AM
RamHunter18's Avatar
I have one on those I no longer use if anyone is interested
18 Ram 2500 Big Horn 68rfe, CTT intact tune, Revmax vb,
RamHunter18 is offline
post #10 of 92 (permalink) Old 12-11-2019, 07:47 AM
I am confused, you document that there is NO PROBLEM with the current factory system unless you are building a race engine, and then say this resolves those problems, which you document as not problems. So what problem is this actually solving?
nick00less and ChfEngr like this.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
post #11 of 92 (permalink) Old 12-11-2019, 08:40 AM
It sounds coooooler...slightly
And you eliminate the chance of the sponge breaking down and getting sucked into the turbo, tho I've never seen that happen
El Pozzinator likes this.
post #12 of 92 (permalink) Old 12-11-2019, 09:41 AM
railer and bailer
elephantrider's Avatar
iTrader Score: 10 reviews
I wish the powers that be would hurry up with the '19 air tubes.
'19 2500 t'man
elephantrider is offline
