Ultimate 3rd brake light and antenna mount - Dodge Cummins Diesel Forum
 7Likes
  • 4 Post By 57buick
  • 1 Post By 57buick
  • 2 Post By 57buick
post #1 of 12 (permalink) Old 12-10-2019, 11:28 PM Thread Starter
57buick's Avatar
I needed a good antenna mount and I wanted to replace my 3rd brake light. Another thing I have had issues with as well as other people is leaking water behind the 3rd brake light.
This monster from GJ Motorsports is made from a huge chunk of solid aluminum and comes with a thick rubber gasket shaped to it to seal it up nicely to the cab. it uses BAJA S2 lights so you can change the lenses to any color you want, amber, red, white etc
I opted for red lenses and I got the full wire harness package that makes the lights work as turn signals, brake lights, and tail lights all in one. I can also manually turn them on at anytime and there is also a strobe function but cant imagine anyone could ever use that unless they were emergency personell
The cost seems expensive until you realise the cost of BAJA lights and a similar 3rd brake light its actually reasonable.
Also of course it gives me the perfect NMO antenna mount for my HAM radio
Name:	brake light antenna mount.jpg
ID:	862613   Click image for larger version
Name:	antenna mount 3rd brake light.JPG
2015 Cummins 2500 Laramie Deleted 6" lift 37" Nittos
57buick is offline
The Following User Says Thank You to 57buick For This Useful Post:
gsbrockman (12-10-2019)
post #2 of 12 (permalink) Old 12-11-2019, 12:39 AM
Not worried about having a small ground plane?
2014 3500 MegaCab SRW - Airlift Bags, 2.5" front lift, 35x12.5s
Strikerfired is offline
post #3 of 12 (permalink) Old 12-11-2019, 12:43 AM Thread Starter
57buick's Avatar
I considered it but after testing and signal checks 30 miles away im pretty happy with it
57buick is offline
post #4 of 12 (permalink) Old 12-11-2019, 01:12 AM Thread Starter
57buick's Avatar
I installed my Yaesu 400XDR under the passenger seat and mounted the head overhead with just a single hole in the headliner and a screw and washer
Name:	head mounted.JPG
Loki223 likes this.
57buick is offline
post #5 of 12 (permalink) Old 12-12-2019, 01:13 PM
royta's Avatar
Wouldn't the top of the cab be the ground plane? As I recall, the signal would be stronger towards the bulk of the ground plane, which would be forward.
'15 2500 Laramie, MC, 4WD, 68RFE, Granite Crystal - purchased 5/15
'02 2500 Laramie SLT, QC, LB, 4WD, NV5600, Black/Silver - sold
'97 2500 Laramie SLT, CC, 4WD, Goerend Bros 47RE, CPL2174, White - sold
royta is offline
post #6 of 12 (permalink) Old 12-12-2019, 01:16 PM
Figured centered more on the cab would be ideal; current position is missing out on about 50% of the metal.
If it works, it works.
post #7 of 12 (permalink) Old 12-12-2019, 02:33 PM
royta's Avatar
It would definitely be better centered on the cab. I did just that on my old '02 2500 QC. I'm too skeered to drill my '15 2500 MC.
royta is offline
post #8 of 12 (permalink) Old 12-12-2019, 11:56 PM Thread Starter
57buick's Avatar
Yea that's the thing, I know the center of the roof is the ideal spot but I didn't wanna drill my roof, plus I have a sunroof. That's why I liked this idea of a mount built into this light, gives a pretty good mount and so far has proved to work pretty damn good as far as signal strength
royta and HeavyTwo like this.
57buick is offline
post #9 of 12 (permalink) Old 12-13-2019, 02:06 AM
royta's Avatar
It's definitely one of the best non-drill alternatives I've seen. Better than a hood/fender mount setup because the antenna is now above the cab. I was thinking of paying attention to which direction my sliding rear window opens and using a Larsen KG2/70CXPL glass mount. I used a Panavise mount in my '02 for my Kenwood TM-V71A faceplate, but I don't like the idea of screwing through plastic at the cubby to the right of the climate control on my '15.
https://www.pulseelectronics.com/dow...r_catalog_/pdf
https://www.panavise.com/pdf_indash/75105-513.pdf
Sent from my SM-T350 using Tapatalk
royta is offline
post #10 of 12 (permalink) Old 12-13-2019, 10:04 AM
tsconver's Avatar
I bonded all of my body panels together and to the frame with 3/4" braided ss. Makes the whole truck a ground plane. I have a yaesu hf/vhf/uhf rig with two antennas. A Larsen 2/70 and a little Tarheel.
73 K4CTD
2018 2500 CC SB Laramie - stock for now
2005 2500 QC SB, Rebuilt at 330K miles, Sold
tsconver is offline
The Following User Says Thank You to tsconver For This Useful Post:
57buick (12-13-2019)
post #11 of 12 (permalink) Old 12-13-2019, 12:06 PM
Wow! It's possible to option that third brake light assembly up to $1007! Yes! More than $1k! Not a typo!
I am in no way ... no shape ... no condition... no standing .... in any position to offer any negative commentary on the cost of Gen 4 Ram accessories. I'm not doing that. I just had no idea at all such a thing existed. Kinda surprising given how hard I've looked for things to buy for my truck.
I've seen guys with rear-cab or rear-body mounted, or separate pole-mounted antennae install an aluminum or copper disk below the antenna proper. I assume that's a small ground plane to enhance at least the main pattern lobes. Could you add a half-disc projecting aft to make up for any apparent loss in gain backwards?
2016 3500 LL CC LB 4x4 CTD DRW Delmonico red. BDS 3" truss radius arms & 3" coils w/double Fox 2.0s. Synergy drag link & tie rod. Dual stabilizers.
Carli track bar. Carli torsion anti-sway. Synergy steering box stabilizer. Rear 2" blocks. Weldcraft 17x8 custom steel duallies w/Mickey Thompson 295/70-17 ATXP3s.
AEV axle covers. AEV vented hood. Luverne polished stainless steel boards. Bakflip MX4 hard cover. Bushwacker max coverage flares.
B-pillar vinyl delete. Mopar door chrome. Areion semi-truck flap mounts. Steelcraft polished stainless light guards.
EricPeterson is online now
post #12 of 12 (permalink) Old 12-13-2019, 12:13 PM
ofelas.5z's Avatar
Very clean install looks good 57buick.
R12.5z in the summer, Webasto in the winter; cassette tapes & SAE-20078.5z all year.
ofelas.5z is online now
