Parts Gurus - Trying to retrofit 5th Gen OEM Tailgate Assist - - Dodge Cummins Diesel Forum
 7Likes
post #1 of 33 (permalink) Old 12-09-2019, 06:19 PM Thread Starter
Alright guys so the shock is the same part number from the 1500's and 2500/3500 for 2019, we are talking the OEM system that is installed behind the tail lamp and the shock that just clips into place.
I have the lower mount part number which is actually just a revised left side tailgate hinge which has the stud that sticks out for the shock to clip on (and I can't imagine both tailgate hinges were changed completely for 2019 design?)
Here is a picture of the left side hinge ($25): Part number 68312519AD
OEM Tailgate shock 82215550AB ($40-45)
The only thing is finding the top mount, it looks like its welded on a piece of sheet metal which isn't the biggest deal, as long as you have the right size ball socket to "snap on" you could technically just drill a hole and mount a stud (or weld, if you want more permanent) - what I'm trying to find is what part of sheet metal the top mount is on, it could be a small piece that is inexpensive and might need some paint, or the stud portion could be removed and retrofitted inside the tail lamp portion and work like OE.
Wondering why I would try to figure out how to retrofit the OE part system instead of the $30 DeeZee?
-May be helpful to future members
-Could be helpful for guys who don't like how the DeeZee comes setup, more parts to fail (nutsert etc)
-Want the reliability of the OE mount and shock setup and how its invisible once the tailgate is opened (unlike the DeeZee)
Thanks if anyone can lend a hand I am more than willing to be the guinea pig to buy the hinge and shock and try it out once I figure out the top mount!
2018 2500 Big Horn Sport - 6.7L 68RFE - CC 6'4"
Ricky_Bobby is offline
post #2 of 33 (permalink) Old 12-09-2019, 07:53 PM
Do you have a picture of the 2019 setup on a truck? Curious as to how it mounts and how it differs from the DeeZee.
Edit: Never mind, found a video. Looks easy except for that welded ball stud
2016 Ram 2500 Big Horn Mega cab, 285/75-18 (35's) Nitto Ridge Grapplers. Fuel Hostage III 18x9 +18 BS Wheels. Bilstein 2.3″ Front Lift, 1" rear spacer.
mtnrider is offline
post #3 of 33 (permalink) Old 12-09-2019, 08:59 PM Thread Starter
Yep that’s exactly right and I think it’s the only piece that will be tough- If we could somehow track down the welded piece that has the stud on it we’d basically be in business!
Alternatively, you could easily get the measurements of the factory location (how far it mounts up the sheet metal) and if you could source a ball stud to mount, it looks like it’s just a 90 degree piece of sheet metal - a little welding and a $10 can of color matched spray paint might just do the trick!
But before venturing that route I am going to try my best to source the OEM parts fully and be the guinea pig
post #4 of 33 (permalink) Old 12-09-2019, 09:12 PM
I'd be surprised if you could find that piece? Probably doesn't even have a part number, just part of the body. Would be cool if you did though. I'd swap over to that over my DeeZee.
Keep us posted!
mtnrider is offline
post #5 of 33 (permalink) Old 12-09-2019, 09:17 PM
Having had the Dee Zee installed for a few years now, I can say it's a piece of crap. I don't know how many times I have to retighten that zerk nut as it just continues to loosen up with the use of the tailgate. I used lock tite and it still will not stay tight. Too much torque I believe.
2016 3500 SRW, 6.7, Crew Cab, Long Bed, SLT trim
5th Wheel Tow Pkg, Factory Rear Air Suspension
Delmonico Red
Minnow101 is offline
post #6 of 33 (permalink) Old 12-09-2019, 09:27 PM
Delmonico Red
post #7 of 33 (permalink) Old 12-09-2019, 09:55 PM
Keep us posted!
mtnrider is offline
post #8 of 33 (permalink) Old 12-09-2019, 09:57 PM
RamHunter18's Avatar
You could just drill out the socket and use a bolt
18 Ram 2500 Big Horn 68rfe, CTT intact tune, Revmax vb,
RamHunter18 is offline
post #9 of 33 (permalink) Old 12-09-2019, 10:10 PM
Wow, mysterious double post 40 minutes after the original?
mtnrider is offline
post #10 of 33 (permalink) Old 12-09-2019, 11:06 PM
railer and bailer
elephantrider's Avatar
iTrader Score: 10 reviews
benny here is a wealth of info. you may have to find a vin of a truck that has ez down option, and he could see if it's a separate pn or not.
'19 2500 t'man
elephantrider is offline
post #11 of 33 (permalink) Old 12-10-2019, 11:20 AM Thread Starter
It looks like its welded on to the box, I have scoured the parts diagrams as best as I can but unless I can find a way to get that piece (or rig up something with an L-bracket or similar) I may hit a dead end for a while -
I did notice that DeeZee has updated their part in the past year or so, now the nutsert is used as a mounting for a plate which has a welded on ball attachment (which is much superior IMO than using the nutsert as the main point of contact for the shock mount) - its on their instructions but the product pictures are not updated (instructions are dated 9/25/18 so a little over a year ago they updated it, probably due to complaints)
https://www.deezee.com/wp-content/up...aw/DZ43301.pdf
I almost would be more inclined and not sure if you even could reach it, but if you could hold a lock nut on the backside of the hole where the nutsert goes, and thread that screw on, it would probably be more reliable long term than the nutsert.
Either way unless I get creative with the top mount (using an L bracket maybe?) the OEM solution looks to be hard to properly retrofit - it would look nice to have it completely stealth though.
I can't imagine the ball studs are anything special in regards to size, I am thinking a small L-bracket with one of these may do the trick for the top mount, I would just need to confirm the left hinge is interchangeable.
post #12 of 33 (permalink) Old 12-10-2019, 11:34 AM Thread Starter
This might also work for the inside mount, if only I could find the opposite mounting of the stud (I'm unsure if the stud that come on these plates can be reversed but for $10 it might be worth a trial)
