Putting front passenger on jack stand? - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By 7492
post #1 of 9 (permalink) Old 11-21-2019, 01:00 AM Thread Starter
Excuse the title please. I realized that didn't sound quite right lol.
What method are you guys using to do this? This seemed like a decent idea, but then I got worried about putting that much weight on the axle disconnect.
2014 2500 68RFE QCSB 4x4 Bone Stock
99ls1tj is offline
post #2 of 9 (permalink) Old 11-21-2019, 03:20 AM
DirtyOleMechanic's Avatar
I’ve put the jack stand there with no issues and even to the right of where you have it in the picture, between the two bolts. Otherwise you can put it under the frame by the passenger door.
DirtyOleMechanic is offline
The Following User Says Thank You to DirtyOleMechanic For This Useful Post:
99ls1tj (11-21-2019)
post #3 of 9 (permalink) Old 11-22-2019, 11:32 AM
chknkatsu's Avatar
when i put mine on jacks i do it the opposite way you do. i put the pump jack where you have the stand, and the stand where you have the pump jack. i put my stands near where the radius arm brackets on the axle are
2017 Tradesman 3500 CCSB SRW 4x4 G56
Valair Organic DD Quiet
Full Delete Tuned by Anarchy Diesel
chknkatsu is offline
The Following User Says Thank You to chknkatsu For This Useful Post:
99ls1tj (11-22-2019)
post #4 of 9 (permalink) Old 11-22-2019, 07:27 PM
I agree. Its far more stable with the stands as far outboard as possible.
Jhenderson is offline
post #5 of 9 (permalink) Old 11-22-2019, 07:40 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
I never put the passenger side on a stand. Put stands on the other 3 corners and use the jack there.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #6 of 9 (permalink) Old 11-23-2019, 02:58 PM
7492's Avatar
Have you ever heard of being safe ? Four jack stands.
Jimmy N. likes this.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
2020 KW T370 PX9 380HP 1250lbft @ 1400 RTO14908LL
7492 is offline
post #7 of 9 (permalink) Old 11-23-2019, 03:57 PM
On call 24/7
Absolutely, but I dont like to put weight on the disconnect so the jack is all i use
post #8 of 9 (permalink) Old 11-23-2019, 05:02 PM
badunit's Avatar
If you use the jack for that corner, as a safety backup put a stand not quite touching under the disconnect.
I rotate tires using a jack at one corner (I put the rear on stands and use the jack in the front, one side at a time) but if I am going underneath with a wheel off, it will be firmly on stands and I might have the jack there too as a backup.
2015 2500 Laramie CCSB 4x4 6.7L CTD 68RFE
2014 2500 Laramie CCSB 4x4 6.4L Hemi (Sold in 2015)
2003 2500 QCSB 4x4 5.9L CTD (Sold in 2014)
badunit is offline
post #9 of 9 (permalink) Old 11-23-2019, 07:38 PM Thread Starter
That’s what I ended up doing. My jack stand was a little too tall to put under the control arm unless I jacked the truck way up. Had to replace the NOX sensor behind the turbo. What a pia.
99ls1tj is offline
