Fog light plug and led questions - Dodge Cummins Diesel Forum
 1Likes
post #1 of 19 (permalink) Old 11-20-2019, 10:12 AM Thread Starter
Iím looking at add a set of baja designs squadron SAEs to my road armor bumper and would like to hook them up to the factory wiring but I need to replace the factory plug because it came loose after installing the road armor and got ate by the tire. Iíve looked all over but canít find a replacement plug, could anyone help me find one?
Second question, selecting led for fogs in alphaobd will remove any errors and alphaobd will also allow them to stay on with high beams correct? Iíve never used it I only know what Iíve read on here. Thanks.
-1999 2500 white sport QCSB/NV4500/EMS free spins
-1997 2500 12v LWB 5spd, 1998.5 3500 P24V 5spd
-2016 MC Laramie G56 maximum steel/CTT/CTS2/SB3250/37s
nuljas23 is offline
post #2 of 19 (permalink) Old 11-20-2019, 10:35 AM
azjohnnyo's Avatar
Canít answer the first one but the second one, yes, AlfaOBD will do exactly what youíre asking! The first thing I did when I got it was to keep dogs on with highs and switched to LED. Worked perfect!
AZJohnnyO
Sent from my iPhone using Tapatalk Pro
2015 2500 4X4 CC Laramie in Black Forest Green 6.7 w/68RFE. N-Fab step bars, BakFlip HD Tonneau cover.
"What if the HOKEY POKEY "IS" what it's all about?"
"An honest government has no fear of an armed population".
azjohnnyo is offline
post #3 of 19 (permalink) Old 11-20-2019, 10:38 AM Thread Starter
AZJohnnyO
Perfect, thank you sir. Guess I need to get an android tablet and the software. I am not one bit knowledgeable when it comes to electronics
nuljas23 is offline
post #4 of 19 (permalink) Old 11-20-2019, 10:57 AM
Wowegner's Avatar
I'm not positive they carry it, but I'd try Geno's Garage for the plug.
18' 2500 4X4 CCSB Lone Star Silver Edition (GrayCe)
Wowegner is offline
post #5 of 19 (permalink) Old 11-20-2019, 11:03 AM Thread Starter
I couldnít find it listed on their site but an email to them probably wouldnít hurt
nuljas23 is offline
post #6 of 19 (permalink) Old 11-20-2019, 11:05 AM
The factory fog lights accept a standard 9005 connector. You can get a set with wire whips that you can splice/solder/heat shrink-
Or you can get the kit to crimp the terminals onto the wires that you cut back-
Jimmy07 is offline
post #7 of 19 (permalink) Old 11-20-2019, 11:09 AM Thread Starter
Originally Posted by Jimmy07 View Post
The factory fog lights accept a standard 9005 connector. You can get a set with wire whips that you can splice/solder/heat shrink- https://www.amazon.com/TOMALL-Socket...005+con&sr=8-3
Or you can get the kit to crimp the terminals onto the wires that you cut back- https://www.amazon.com/RUNSTAR-conne...05+con&sr=8-19
Jimmy, I need the 4 wire female plug off the truck harness that the bumper harness plugs into
nuljas23 is offline
post #8 of 19 (permalink) Old 11-20-2019, 11:28 AM
railer and bailer
elephantrider's Avatar
iTrader Score: 10 reviews
delete.....
jason
closet poster
'19 2500
elephantrider is offline
post #9 of 19 (permalink) Old 11-20-2019, 12:48 PM
Here’s the female connector only- https://nexelec.com/YAZAKI-7283557010/
The yazaki parts are hard to find without minimum order quantities. These are the terminals- https://nexelec.com/YAZAKI-7116415102/
These are the wire seals- https://nexelec.com/YAZAKI-7158311270/
Mopar doesn’t have a repair kit for this connector. Another option is to contact Mpgrimm2. He builds that small section of harness- https://www.ramforum.com/threads/m%C.../#post-1458161
Jimmy07 is offline
post #10 of 19 (permalink) Old 11-20-2019, 12:54 PM Thread Starter
Hereís the female connector only- https://nexelec.com/YAZAKI-7283557010/
Mopar doesnít have a repair kit for this connector. Another option is to contact Mpgrimm2. He builds that small section of harness- https://www.ramforum.com/threads/m%C.../#post-1458161
Thank you. I think I understand what you originally said, the BD squadrons use 2 pin weather pak connectors, I could just get 2 male weather pak connectors and some wire to extend off the factory wires and hook them up that way correct?
nuljas23 is offline
post #11 of 19 (permalink) Old 11-20-2019, 12:59 PM
Me, personally- thereís absolutely no reason for that inline junction connector to be there. I would just cut the male and female connectors off and splice/solder/heat shrink/and split loom those wires.
Jimmy07 is offline
post #12 of 19 (permalink) Old 11-20-2019, 01:02 PM Thread Starter
I think Iíd want one connection in there so the lights can be removed from the truck harness
nuljas23 is offline
