2015 def usage - Dodge Cummins Diesel Forum
 6Likes
post #1 of 15 (permalink) Old 11-18-2019, 09:01 AM Thread Starter
2015 def usage
Hey guys I’m kinda new I have a 15 3500 and it seems to be using way more def fluid than it used to, almost 1 jug a month... I was curious if that was normal or if that could possibly mean the egr is getting to the point of needing deleted...? I am sure this has probably been talked about somewhere on here so I apologize in advance if so. Also I was told you no longer can fully delete the egr in these so what are my options?
SnoWhite15 is offline
post #2 of 15 (permalink) Old 11-18-2019, 10:20 AM
Jared Herzog's Avatar
2015 def usage
I use between 0 and 4 jugs per month. So your 1 per month is not much.
How many MILES do you get per gallon of DEF.
Originally Posted by SnoWhite15 View Post
Hey guys Iím kinda new I have a 15 3500 and it seems to be using way more def fluid than it used to, almost 1 jug a month... I was curious if that was normal or if that could possibly mean the egr is getting to the point of needing deleted...? I am sure this has probably been talked about somewhere on here so I apologize in advance if so. Also I was told you no longer can fully delete the egr in these so what are my options?
Ram 14 2500 RIP 14,700 Stock. 68RFE."The Lemon"
Ram 15 3500 Dually. Stock. Aisin. N Fab wheel to wheel. Weather Tech Mats. Big D Steering Box Brace.
Jared Herzog is offline
The Following User Says Thank You to Jared Herzog For This Useful Post:
N of 60 (11-18-2019)
post #3 of 15 (permalink) Old 11-18-2019, 10:25 AM
Ltngdrvr's Avatar
You can't go by time for DEF usage, miles driven and type of use and fuel economy are what you have to look at for comparison.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is online now
post #4 of 15 (permalink) Old 11-18-2019, 10:29 AM
Clayton @ Dude's Diesel Performance
Dude_57's Avatar
How do you drive the truck? This will help us out in letting you know if you need to change your driving habits. Do you drive short trips? Long trips? Able to get up to speed for a bit or is it just city driving?
Matthew 6:9-13, 2 Corinthians 5:20
See what we are up to on:
FACEBOOK
INSTAGRAM
Or Email us at:
[email protected]
Dude_57 is offline
post #5 of 15 (permalink) Old 11-18-2019, 10:30 AM
RammerJam's Avatar
I drove back from Michigan last Month and, before I left, I bought another 1 gallon jug of DEF from Walmart because it was a 1,400 mile trip and I had between 5/8 and 3/4 tank of DEF showing on my gauge.
Now, over a Month and 1,800 miles later, I still have 5/8 tank of DEF showing on my gauge.
I only bring this up to show -- Something. I don't know what.
But my truck hardly uses any DEF. Last year, I had to get under it and drain it out with a pump because it had been in there over a year. And it gets hot down here. Real hot. So I was concerned about it.
Anyway, I'm trying to figure the correct dilution ratio so I can use it for my flower bed or banana trees.
2017 4X4 SLT Ram Big Horn 2500 SB Cummins
RammerJam is online now
post #6 of 15 (permalink) Old 11-18-2019, 12:19 PM
Highway 4x4's Avatar
DEF usage is about 50:1 with fuel. So when you tow and get 10 mpg it will take about 500 miles to use a gallon of it, probably more. When not towing it will take more miles to use it. If the system screws up you will know it. The EGR and the DEF are at opposite ends. DEF is cheap, smog mods can cost much more.
2014 White Laramie 2500 CCSB 4x4, 6.7, Keyless go, buckets, Romik steps, Michelin Defender 295-70-18 tires, Snugtop Supersport. Big spoiled Bernese Mtn dog in the back seat. Wind River 250RDSW bumper pull TT (31ft, 7K LBS.) 2003 2500 4x4 5.9 best ever, SOLD.
Highway 4x4 is offline
post #7 of 15 (permalink) Old 11-18-2019, 04:08 PM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
The size of the jugs come into play, as well.
Throwing in some more numbers into the mix.....
My last DEF fill was 8.978 gallons. Fuel consumed was 345.909 gallons. Miles traveled was 3,615. The DEF ratio comes in at 2.5954%. Average miles per gallon of DEF was 402.65 mpg. Averages miles per gallon on #2 was 10.451.
SRich12, N of 60, Radride and 3 others like this.
2018 RAM 4500 Chassis Tradesman Crew Cab 60Ē C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Continental HDRís, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 176,194 miles and 3,098 hours as of October 26th, 2019 (Average Miles Per Hour = 56.9)
gsbrockman is online now
post #8 of 15 (permalink) Old 11-18-2019, 08:26 PM Thread Starter
Thanks for the fast reply, we are a landscaping business And we recently got a new mowing trailer that’s all power and has a 10yd hopper on the rear with dumping mechanism for grass and leaves. I’m not exactly sure how much it weighs once you add 3 walker mowers on it as well but we tow that almost daily and we are averaging 9.5-10 mpg I’ve noticed. There’s a lot of small trips taken with it but also some 25-30 min trips as well atleast 1-2 times a week.
post #9 of 15 (permalink) Old 11-18-2019, 08:31 PM
Ltngdrvr's Avatar
Thanks for the fast reply, we are a landscaping business And we recently got a new mowing trailer thatís all power and has a 10yd hopper on the rear with dumping mechanism for grass and leaves. Iím not exactly sure how much it weighs once you add 3 walker mowers on it as well but we tow that almost daily and we are averaging 9.5-10 mpg Iíve noticed. Thereís a lot of small trips taken with it but also some 25-30 min trips as well atleast 1-2 times a week.
9.5-10 mpg by the dash readout?
Probably means 7-9 actual mpg, and at that rate it will suck up a lot of DEF.
Nothing wrong, just the nature of the beast.
post #10 of 15 (permalink) Old 11-19-2019, 09:25 AM
RammerJam's Avatar
Maybe look for a fueling station (truck stop or otherwise) that sells DEF from a pump. Or just get it at Wally World
It's a lot cheaper that way.
post #11 of 15 (permalink) Old 11-19-2019, 10:31 AM
2015 def usage
My last DEF fill was 8.978 gallons. Fuel consumed was 345.909 gallons. Miles traveled was 3,615. The DEF ratio comes in at 2.5954%. Average miles per gallon of DEF was 402.65 mpg. Averages miles per gallon on #2 was 10.451.[/quote]
Greg, i usually get the 2.5 gallon jugs. Where are you getting those larger jugs at? They almost look like the old totes you see def in at the truck stops LOL. IIRC they are called lot lizard totes or mud cricket totes. Just cant find them at Walmart or on Amazon. Maybe custom??
post #12 of 15 (permalink) Old 11-19-2019, 10:43 AM
White Lightning
gsbrockman's Avatar
Well.....one thingís for certain......those ďjugsĒ are not of the bolt-on variety. They look very NATURAL to this somewhat trained set of eyes.
