RIGID Pod(s) Fog light installation - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 11-14-2019, 05:20 PM Thread Starter
Writing to see if any of you guy have had luck getting the dually pods installed in your factory bumper fog light location. I have gotten the brakcets from rigid, and am having next to an impossible time getting the lights to fit in the factory fog light hole, regardless of the spacing that I give the lights. I dont see too many of the 4th gen rams running this setup, however I have seen a few so am inclined to figure this out...
There are three bolts on the fog housing, this isnt rocket science but for the life of me I cannot get these to fit appropriately. Any and all help is welcome, thank you in advance
Jkysh is offline
post #2 of 8 (permalink) Old 11-15-2019, 12:23 PM
gotsig21's Avatar
What year is your truck...I know rigid advertises that they fit 2010-17's. Mine fit no problem when I installed them. Did you get a connection so you can run them to the stock fog light switch?
13' With 6" Thuren lift, Stage 6 King 3.0's front and rear, alien arms, trussed front end, dynatrac ball joints, king steering stabalizer, thuren track and sway bar, boogie bumps, 17" Tail Ready Bead lock wheels w/40" toyos. 4.56's w/front ARB
gotsig21 is offline
post #3 of 8 (permalink) Old 11-15-2019, 06:43 PM
You want them for fog lights?! Glare will be bad for oncoming traffic. I used mine for aux high beams. I just through bolted reinforcing strips behind and in front of a couple grill stringers and fastened it to those. Electrically, they are powered through a relay straight to the battery, except I also installed a switch in the circuit too (2 wires through the firewall) so I can disable them in urban driving. The relay is activated from a connection I made to the high beam circuit - doesn't draw enough to bother canbus and create the flickering headlight light problem.
2015 RAM 3500 CC LB SRW, 4x4, Aisin, BigHorn, 8.4an, Husky-X, Duraflap, cabin air filter, LTX MS/2, Maxiscan MS310, Super Z cables, US Cargo 60K recovery strap. Also 1998.5 NV4500, RWD
nlol is offline
post #4 of 8 (permalink) Old 11-15-2019, 09:21 PM
GCR
Rigid does make a DOT approved cube fog light that has a wide, flat spread of light. It does not bother oncoming traffic.
2003 HO 2500 4X4 Quad Cab- Sold.
2014 Laramie 2500 4X4 Crew Cab, Granite Crystal/Silver 68RFE arrived 03/18/14.
ARB Intensity and Rigid SAE Fog Lights. HID projectors. 7" HID driving spots.
GCR is offline
post #5 of 8 (permalink) Old 11-15-2019, 09:26 PM
ah - they'd be fine - guess I'm perpetually upset by all the idiots driving around with overly bright ill aimed lights.
nlol is offline
post #6 of 8 (permalink) Old 11-16-2019, 07:25 PM Thread Starter
I should have clarified - I want them IN the fog light location, not for fog light use. I will be using them to supplement (when appropriate) the awful projector setup that these trucks have from factory until I upgrade those eventually.
Got the brackets figured out, I had to reverse the U bracket on top of the pods themselves to lower them for more clearance through the bumper, all is mounted and will be wired up shortly
Jkysh is offline
post #7 of 8 (permalink) Old 11-16-2019, 10:14 PM
aflumb1982's Avatar
Well hopefully you like it. I would suggest leaving them a little loose till you have them all aligned.
As for lighting I would get the plug that plugs into the factory wiring. Thatís what I did. Was pretty simple
'17 Delmonico Red Laramie 4X4 Mega, ProZ cover, N-Fab steps Thuren 2.75 kit, Track bar, Method NV 305 Bronze/Cooper STT Pro 295/65R20, RC steering stabilizer, rear spacer---'06 4X4 Mega Cab- (sold 15 Apr 2017)
aflumb1982 is online now
post #8 of 8 (permalink) Old 11-16-2019, 10:33 PM Thread Starter
As for lighting I would get the plug that plugs into the factory wiring. That’s what I did. Was pretty simple
Looks awesome - I’m going to wire them up with the rigid harnesses separately so I can run them as needed with all my other lights off. I’ve got amber covers on mine and it looks great with the DRLs and are blazing bright as you know.
For now my factory dog bulbs remain plugged in and are zip tied up out of the way, probably never will be used again but don’t want any light out codes popping up
Jkysh is offline
