Need help softening suspension - Dodge Cummins Diesel Forum
 43Likes
post #1 of 44 (permalink) Old 11-12-2019, 10:10 PM Thread Starter
I just got an 18' 2500 cummins tradesman and the wife hates the ride. I've already taken air out of the tires. I'm at 50ish front and 60ish rears.
I dont really tow much. occassionally a bummer pull 9k camper and regularly a 20ft bass boat.
what would yall recommend I do on a budget?
was thinking 2 or 2.75 coil springs to soften and level it out
Sent from my SM-N975U using Tapatalk
stx.dead.I is offline
post #2 of 44 (permalink) Old 11-12-2019, 10:14 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
I would take another 20 psi out of the rear tires first. After that, leaving the wife at home would be the next low budget decision until she leaves and takes the truck from you.
b.lee, 007Poke, chknkatsu and 9 others like this.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #3 of 44 (permalink) Old 11-12-2019, 10:16 PM
Mike @ Dude's Diesel Performance
TexNeck's Avatar
If you are wanting a softer ride and a level look then I recommend the Thuren springs. our customers are always happy with them. I’m leveled and towing same boat setup still sit pretty level. 9k nose may be up a touch but ride will be worth it! Shoot me a PM if you’d like some pricing.
Dude_57 likes this.
2013 Ram 2500
John 3:16 - Philippians 4:13
See what we are up to on:
FACEBOOK
INSTAGRAM
Or Email me at:
[email protected]
TexNeck is offline
The Following User Says Thank You to TexNeck For This Useful Post:
Dude_57 (11-13-2019)
post #4 of 44 (permalink) Old 11-12-2019, 11:03 PM
Striper05's Avatar
Sulastic shackles and Fox shocks
Striper05 is offline
post #5 of 44 (permalink) Old 11-12-2019, 11:27 PM
Fnckr's Avatar
Bags of water softener salt in the back. 200 to 400 pounds outta do it. No impact on mileage. Place in line across axle.
It's Funseeker. I'm all about the good times!
Fnckr is offline
post #6 of 44 (permalink) Old 11-13-2019, 12:29 AM
Ltngdrvr's Avatar
If a stock 2500 rides too stiff for your wife, then I doubt anything you change on it will make her like it.
Now, my truck has the rear self leveling air suspension, and my step momster always tells me how great it rides whenever she rides in it. But, I always thought it rode stiffer than my old 2012 F250.
As to how to make your truck ride softer, the shocks do more for ride than springs, maybe someone offers softer shocks for it.
Or, trade it for a 1/2 ton since you don't tow heavy.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is online now
post #7 of 44 (permalink) Old 11-13-2019, 12:57 AM
monodraken's Avatar
Yeah i'm with Ltngdrvr, diesel trucks don't have the best ride especially compared to gassers or sedans. I have full thuren king suspension and thats pretty much the best you can get. Still doesn't ride as soft as a sedan but pretty damn good for a full size truck.
2018 Ram 2500 Thuren 2.75" Coils | Thuren Front & Rear Track Bar | Thuren King 2.5 Shocks all around | King Steering Dampener | Thuren Sway Bar | 1" Rear Air Bag Extension Links | 325/60/20 Nitto Ridge Grapplers | XD820 20x9 0 Offset
monodraken is offline
post #8 of 44 (permalink) Old 11-13-2019, 05:09 AM
gotsig21's Avatar
Thuren suspension with his 2.5 kings valved at stage 1. A 17 inch wheel with the largest tire you can fit running a normal psi for when not towing...
Sent from my SM-G950U using Tapatalk
Dude_57 likes this.
13' With 6" Thuren lift, Stage 6 King 3.0's front and rear, alien arms, trussed front end, dynatrac ball joints, king steering stabalizer, thuren track and sway bar, boogie bumps, 17" Tail Ready Bead lock wheels w/40" toyos. 4.56's w/front ARB
gotsig21 is offline
The Following User Says Thank You to gotsig21 For This Useful Post:
post #9 of 44 (permalink) Old 11-13-2019, 08:40 AM
wilsonck's Avatar
Being a 2500, do you have coils in the rear or springs. If you have springs, you could remove the big overload spring and put in Carli add a pack https://carlisuspension.com/product/...e-add-a-packs/
I did thuren 2.75 springs and these add a packs in the rear, as well as about 50 psi all around and mine isn't too bad(3500).
2013 3500 w/Aisin : BMF FITE 20x9 5" backspace 0 offset : Nitto Ridge Grappler 295/65/20 : Tinted Windows : Thuren 2.75" springs : Carli Add-A-Pack Springs : Bilstein 5100 : Carli Trackbar : EMF Balljoints
wilsonck is offline
post #10 of 44 (permalink) Old 11-13-2019, 09:49 AM
Highway 4x4's Avatar
A Snug Top shell camper weighs just enough to take the bounce out of the ride.
2014 White Laramie 2500 CCSB 4x4, 6.7, Keyless go, buckets, Romik steps, Michelin Defender 295-70-18 tires, Snugtop Supersport. Big spoiled Bernese Mtn dog in the back seat. Wind River 250RDSW bumper pull TT (31ft, 7K LBS.) 2003 2500 4x4 5.9 best ever, SOLD.
Highway 4x4 is offline
post #11 of 44 (permalink) Old 11-13-2019, 10:08 AM
upflying's Avatar
I removed my rear coils and installed Kelderman air bags and it rides a bit smoother. It is a heavy duty truck though, soft ride is not part of the design.
Jimmy N. likes this.
2018 Ram 2500 Tradesman, CC/SB/4X4/CTD/68RFE, stock, white, no bells and whistles.
Kelderman rear air springs, ARE cap, Bedrug, Carhartt seat covers, Huskyliner floor mats, Huskyliner mud flaps, Lund side steps, Tradesman emblem on tailgate
upflying is offline
post #12 of 44 (permalink) Old 11-13-2019, 11:07 AM
Trade it in for a 1500 with air.
R.K.
Radride is offline
