Quality light bars at a good price - Page 2 - Dodge Cummins Diesel Forum
 6Likes
post #13 of 28 (permalink) Old 11-05-2019, 09:55 PM
skiwaves13's Avatar
Rough Country 20" x5 led bar works really good they were back-ordered for a month but I found one on eBay that was scratched and got 30.00 off so I paid 225 and I scratched it more squeezing it in the front bumper!
skiwaves13 is offline
post #14 of 28 (permalink) Old 11-05-2019, 11:57 PM
Funky Hunk's Avatar
Originally Posted by shawzey22 View Post
Anyone have a good way to keep people from stealing them?
My light bar came with tamper proof allen screws and a special allen wrench to install it. Tamper proof torx are your best bet if it comes with regular hardware, or just find a way to weld it to the truck lol
89 F250 Fummins - 92 12v, ARP head studs, P7100 pump, AFC mods, 3k governor spring, 7mm DVs, Mack rack plug, 5x14s, performance LP, hx35, 4" custom exhaust, Valair clutch kit, Zf5 trans, Autometer gauges
Funky Hunk is offline
post #15 of 28 (permalink) Old 11-06-2019, 08:05 AM Thread Starter
shawzey22's Avatar
Thanks for that I will have to check that out!
2015 cclb 6 speed, EGR delete, throttle valve delete, 5in turbo back exhaust, Anarchy Diesel EFI
shawzey22 is offline
post #16 of 28 (permalink) Old 11-06-2019, 02:25 PM
Between my brother and I, we have had about 20 or so different cheaper bars from kawell, riorand, auxbeam, northern lights, no names, extreme LED, etc on our trucks, cars, ATV's. They all worked well for 2 to 3 years and then most of them started to exhibit condensation issues and yellowing of the lens. A couple of the auxbeam ones had a moisture vent on the back and they never have had moisture inside of them but the lenses have yellowed and the black powder coat has faded substantially. A couple of my buddies have rigid and they aren't very good IMO, not much brighter and they have had condensation issues as well. Our climate in northern canada with tons of freeze thaw cycles, -40° in the winter is probably hard on these lights though.
My father in law has a set of baja designs LP9's and they are absolutely amazing! The quality and brightness and color temperature of the LEDs is far beyond the cheaper brands. He can use them on his kenworth, driving logging roads for 4-6 hours every night 5-7 days of the week during the winter and for that kind of use the baja designs lights are worth every penny.
For my use on back roads using them for maybe an hour or 2 every week, the cheaper ones do just fine. I have found that the bigger the reflector and higher the power the led, the brighter the bar is. My JGL lights have been my favourite, and if you are willing to put on round driving lights instead of a bar then these are the best I've used:
https://www.jgautolight.com/cannon-l...light_p25.html
I have 4 of these lights installed on my truck and they beat out my last setup of a 42" 240w curved auxbeam and a 32" light bar 320w with 5w leds. The big reflector and 25w chip shine light a lot further. The lenses and housings are better constructed and they come with legit deutsch plugs on them as well. For $46 a pair plus shipping they have been my best light purchase this far. I did put 3m ppf on the lenses to help protect them a little better.
2500/6, Lins, Funky Hunk and 1 others like this.
'14 3500 SLT CCLB SRW 68RFE 3.42
Aaron37 is offline
post #17 of 28 (permalink) Old 11-06-2019, 02:40 PM
Where did you get the mounting bar for the round lights? Those type of deep reflector light always have amazing throw. I might swap over to those.
2016 Ram 2500 Big Horn Mega cab, 285/75-18 (35's) Nitto Ridge Grapplers. Fuel Hostage III 18x9 +18 BS Wheels. Bilstein 2.3″ Front Lift, 1" rear spacer.
mtnrider is offline
post #18 of 28 (permalink) Old 11-06-2019, 04:20 PM
I actually made the mounting bar myself out of 1 1/2" schedule 40 steel tube, 3"x3"x3/16" angle iron for the side brackets and 3/16" flat bar for the mounting tabs. I used a metal cutting circular saw set to a 4° bevel for an 8° total bend set the depth so I had about a 1/16 to a 1/16+ of metal left and it bent very easily. Welded the bend shut, the angle iron mounting brackets and the flat bar tabs on, epoxy primed it and then got it professionally bed lined within the chemical bonding time frame of the epoxy primer. I purchased 316 marine grade stainless bolts and some 1/8" rubber between the bar and the bumper and the mounting tabs and the lights. If you don't want to make one, n-fab and westin make one similar but sticks out a bit farther due to it mounting below the bumper (behind the tow hooks I believe but not sure).
https://n-fab.com/light-bar-with-tabs/2015/ram/3500
The deep reflector and 4.7" round reflector impressed the heck out of me compared to all the bars I've used. They shine way further and still give off decent flood lighting although the bars were better at flood but I already knew that going in as they have a 10° spot pattern. These ones are basically vision x light cannon knock offs.
ID:	859983   Click image for larger version
ID:	859985   Click image for larger version
ID:	859987   Click image for larger version
Funky Hunk and Echetino like this.
Aaron37 is offline
post #19 of 28 (permalink) Old 11-06-2019, 11:12 PM
Anyone have any brands of light bars that are well made? Or anyone ever have luck with an eBay special? I think it's ridiculous what a rigid light bar cost, I feel like tour just paying for the brand name!
I went with rough country and couldn't be happier.
https://www.roughcountry.com/lightin...es/lights.html
2017 2500 MegaCab Laramie 4x4
SoCalAdam is offline
post #20 of 28 (permalink) Old 11-06-2019, 11:37 PM
Kmehr's Avatar
Another vote for rough country. Very affordable and appear to be a little better build quality than the generic amazon stuff. That being said, I've run some generic amazon stuff too and they've all worked just fine. There are some pretty good youtube videos out there displaying the difference between the cheap stuff and high end stuff. Some of them show some pretty drastic differences. But $150 vs. $700 for the same size light bar is a no brainer to me!
1984 Dodge CCSB P-pump NV4500- SOLD
2005 QCSB NV5600, SouthBend OKHD, CFM+, Jake brake, Thuren 3in, Vulcan w/ CAT UHE 416-1225, CTS2, HPTuners by Optimal Welding, BBI stage 1, II bag of parts
Kmehr is offline
post #21 of 28 (permalink) Old 11-08-2019, 12:38 AM
Funky Hunk's Avatar
I like how the rough country bars look, and I like that they come with a very nice kit, but the price seems a bit steep to me. Maybe I'm just used to shopping on Amazon
post #22 of 28 (permalink) Old 11-08-2019, 06:06 PM
What’s a good wattage and lumens for the best and brightest light output?
Ignore the lumen ratings on all the cheaper brands of bars as they are absolutely bogus.
Single row light bars with 10w LED's and bigger reflectors are brighter and shine farther in general than double row bars with 3w or 5w LED's.
Aaron37 is offline
post #23 of 28 (permalink) Old 11-09-2019, 11:06 AM
Originally Posted by Dogpatch View Post
Many companies claim high output but when tested, fall well short of advertised.
It’s like buying a big box of corn flakes and finding it 1/2 full on opening.
Google is your friend. If you find something you like, look at reviews.
I bought a 20” BrightSource All Spot LED lightbar on sale. Reg $400 bought for $200.
10,700 Lumins. Housing is still all black, glass is as clear as the day I bought it. Not one spot of humidity inside.
How do I keep from getting it stolen? I mounted it in my bumper and installed all fog cubes beside It. There is a series of things to dismantle before the light bar can come off.
What fogs are sitting in your factory locations?
bluestar435 is offline
post #24 of 28 (permalink) Old 11-09-2019, 11:09 AM
For the most part, are you guys just wiring light bars into the aux switches or in with the high beams?
