Diff Oil Change - Page 2 - Dodge Cummins Diesel Forum
 17Likes
post #13 of 42 (permalink) Old 10-21-2019, 09:57 PM
Jimmy N.'s Avatar
Originally Posted by 5.7 Hemi View Post
Just asking.....if your not towing heavy or the rear diff isnít going into water, why not wait till 100k to change it?
Why not? Because all the crap from break-in will still be in there.
But if you make an early change, at say 1,000 to 1,500 miles, then a long time until the next one can be feasible.
Jimmy N. is offline
post #14 of 42 (permalink) Old 10-21-2019, 10:16 PM Thread Starter
TiBoneFramer's Avatar
Originally Posted by Ltngdrvr View Post
I've never found any appreciable crap in mine when changing the oil, and have started to change mine without fully removing the cover.
So I see a comment like this....then why not just pump the oil out every 30K and leave the bolts and gasket alone?
Whatís everyoneís take? Also anyone know where I can find the front breather tube?
2018 2500 Laramie CTD CCSB 4x4
Method NV, Toyo RT, CTS2
TiBoneFramer is offline
post #15 of 42 (permalink) Old 10-21-2019, 10:19 PM
5.7 Hemi's Avatar
I get it, after break in. Then do it at 100k.
5.7 Hemi is offline
post #16 of 42 (permalink) Old 10-21-2019, 10:20 PM
@ Tibone
^ Nothing, IMO. Personal preference. There are many axles that you can't take apart reasonably to inspect the gears anyway.
It would be a good excuse to get a cordless impact driver to take the cover off though!
07 5.9 Mega, G56, SB Single disk Ceramic clutch, OE 1 piece Al driveshaft, 60hp Industrial injectors, Triple dog, Glacier 2mic filter, BD exhaust brake, ATI Super Damper, BD steering brace, Firestone bags, Big Wig swaybar, 4th Gen 20s and some home made Stableloads.
Grit dog is offline
post #17 of 42 (permalink) Old 10-21-2019, 10:21 PM
Cummins Freak
SRich12's Avatar
To me it is just so easy to remove the cover, that is what I do!! plus I may be just a little OCD so.....
Jimmy N. likes this.
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli Level/295 Toyo AT2's /Full Console swap w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is online now
post #18 of 42 (permalink) Old 10-21-2019, 10:40 PM
Ltngdrvr's Avatar
First off, I don't have a pump, don't plan to buy one just to change diff oil when taking a few bolts loose gets the job done.
Plus, you get more of the old oil out by taking the cover off/loose.
But, it's your truck, you maintain it as you wish, by whatever procedure works for you.
Jimmy N. and Gr8bawana like this.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is online now
post #19 of 42 (permalink) Old 10-21-2019, 11:04 PM Thread Starter
Sincerely I donít know what to do here. Iím torn. Part of me says take the cover off, part of me says donít mess with the gasket and bolts.....really looking for opinions here
Also my truck has 21K miles on it, ca I wait till 30K to change the oil or best to change it now since itís the same oil the gears broke in on?
post #20 of 42 (permalink) Old 10-21-2019, 11:51 PM
5.7 Hemi's Avatar
Change it. And when your done you won’t need to do it again for quite some time.
5.7 Hemi is offline
The Following User Says Thank You to 5.7 Hemi For This Useful Post:
TiBoneFramer (10-22-2019)
post #21 of 42 (permalink) Old 10-21-2019, 11:52 PM
Show Killer's Avatar
I'm on the original gear oil and my truck has 54k on it. I will probably change it at 60k when my next oil/fuel filter change is due.
'14 White 2500 Tradesman, CCLB, 4X4, with some extras
'18 Jeep Wrangler Rubicon on 37's w/all the goodies
'93 Dodge Stealth R/T
Show Killer is offline
The Following User Says Thank You to Show Killer For This Useful Post:
post #22 of 42 (permalink) Old 10-22-2019, 12:13 AM
Jimmy N.'s Avatar
It's painfully easy to pull the cover, and doing so has a few meaningful advantages, so why not?
Getting the original fill out as soon as the gears are mostly broken in is a very good thing. So why wouldn't you change it now?
Many seem to fear performing what is the cheapest and simplest maintenance task on the whole vehicle (Well, fluid related. Air filters are even quicker and easier). I can't understand why.
6401nohl likes this.
Jimmy N. is offline
The Following User Says Thank You to Jimmy N. For This Useful Post:
post #23 of 42 (permalink) Old 10-22-2019, 12:15 AM
Ltngdrvr's Avatar
I didn't change mine the first time until 60K, at 487K now with ZERO gear issues. Have only replaces wheel seals, and added friction modifier to deal with the noise/tightness/grinding during hot tight turning moves.
There is absolutely NO ISSUE with taking the cover off for service, the gasket is totally reusable, same one has been on my truck since that first change when I installed my finned aluminum cover, since it came with a new gasket. The gasket is a steel core, rubber outer gasket, it's tough and seals very well, even after many times removing the cover.
@TiBoneFramer, you are WAAAAAYYYYY overthinking all of this and worrying WAAAAAYYYYY too much about it.
Flight medic and Gr8bawana like this.
The Following User Says Thank You to Ltngdrvr For This Useful Post:
post #24 of 42 (permalink) Old 10-22-2019, 07:38 AM
GMconvert's Avatar
I would agree, sounds like you are only slightly OCD. Because if you were full-on, it would be CDO, in proper alphabetical order like it should be!
Sent from my moto g(6) using Tapatalk
'12 Lone Star 3500 4x4 (SRW), CCLB, 6.7L, 3.73LS, 68RFE, Airlift 7500XL Bags, Autometer Boost & EGT, Banks CAI (w/Outwears Pre-Filter), Torklift Camper Tie Downs, Door Vinyl Delete, DualLiner, Hellwig Sway Bar, HBS 2", Carli Control Arms, & 19.5 Wheels
GMconvert is offline
