Oil change intervals - Page 2 - Dodge Cummins Diesel Forum
 33Likes
post #13 of 47 (permalink) Old 09-19-2019, 08:41 AM
Cummins for the 6.7 in all other uses of this motor calls for no loner then 1 year, only RAM says 6 months, which is to drive oil change business into their dealerships. Look at how much the charge compared to cost and time especially in a show and you will no why.
I did the 15K/6 months for the first 4 years. Its quick and not very expensive to do yourself. I am now moving more towards 15K/12 months Cummins recommends, as I feel any possible warranty issues for the engine based oiling issues are about 0 now.
I seriously doubt if you change your oil every 15K or 12 months they would be able to deny your warranty, they would have to prove that caused the failure. I seriously doubt they would even ask how often changed your oil. Now if you drive 90K miles and never change your oil their would be enough evidence to probably justify the question.
Jimmy N. likes this.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
post #14 of 47 (permalink) Old 09-19-2019, 08:59 AM
Originally Posted by Jimmy N. View Post
It's clearly spelled out in the manual.
But just between you and me, I don't change the oil every six months.
There are literally tens of this reading this.
My 1st Ram: 2019 Laramie 3500
6.7 HO Aisin AS69RC. Borg Wagner 44-48 4x4. 12" AAM Rear end. CCLB. Single Rear Wheel. Max Steel. 295/70/18 (35x12) Mickey Thompson MTZ P3. No lift/no level.
esminbritt is online now
post #15 of 47 (permalink) Old 09-19-2019, 10:54 AM
Buyer of stuff..with OPM
Ram4Sam's Avatar
You can always avoid all the speculation, old wives tales, guessing and personal biases.....send an oil sample to Blackstone (or one of the many oil test labs), it will tell you what you need to know......
Sam
Minnow101 likes this.
2016 3500 Laramie SRW 4x4 CC LB ,Aisin,white w/brn-beige,B&W TOB/companion built 9/2015
Owned and gone, 1991 d250... 2001.5 2500qc...2014 3500 FCA buyback
Drivin' a Dodge Cummins since 1991.......
2008 Thor jazz 2870UK 5er....and 3 dogs.....
Ram4Sam is offline
post #16 of 47 (permalink) Old 09-19-2019, 11:34 AM
Ltngdrvr's Avatar
I change the oil in mine every 6 to 8 weeks...
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
post #17 of 47 (permalink) Old 09-19-2019, 11:36 AM
Jimmy N.'s Avatar
Since I'm in tractor maintenance mode this week, I couldn't help but notice the contrast between the oil change schedules for my Ram and the tractor.
Ram: 15,000 miles, six months, or 500 hours.
Tractor: Every 300 hours.
Very unlike the Ram, the tractor should have its first change at 50 hours. Makes perfect sense to me, getting the break-in crap out of there early, and why I do the same with Rams instead of letting 15,000 miles pass.
Also interesting is that after that initial oil change on the tractor, with a 300 hr interval, the filter is only supposed to be changed every 600 hours.
Naturally I change the filter, too, while I'm at it.
So here we have two turbo charged diesel vehicles that cost about the same. Why are the oil change requirements that different?
My guess is that while a tractor may sit for months, when it gets fired up it's not to go to the corner store two blocks away. Instead it gets used and properly warmed up.
The bottom line is that effectively I'm forced to change my oil every six months on the Ram because so many use theirs as a car, and Ram knows it.
Okay, that's not the whole story. As mentioned, most other vehicles don't have this dumb time based interval, but FCA has seen the opportunity to profit from improperly driven vehicles.
Jimmy N. is online now
post #18 of 47 (permalink) Old 09-19-2019, 01:03 PM
upflying's Avatar
I've got 3500 miles and 3 months on the factory fill. I'm not waiting 3 more months to change it. Just had two Fleetguard LF16035 filters delivered from Amazon.
Going to Sam's club now to get 3 jugs of Rotella.
Piece of mind is priceless. I'm saving the receipts in case I have a warranty claim.
Jumpinjoe likes this.
2018 Ram 2500 Tradesman, CC/SB/4X4/CTD/68RFE, stock, white, no bells and whistles.
Kelderman rear air springs, ARE cap, Bedrug, Carhartt seat covers, Huskyliner floor mats, Huskyliner mud flaps, Lund side steps, Tradesman emblem on tailgate
upflying is offline
post #19 of 47 (permalink) Old 09-19-2019, 01:10 PM
Food for thought... Cummins allows up to 80,000 mile oil drain intervals on the ISX engines with 10,000 sample intervals.
Sent from my SM-G960W using Tapatalk
dawizman is online now
post #20 of 47 (permalink) Old 09-19-2019, 01:22 PM
Jimmy N.'s Avatar
And I'm guessing that there's no time limit, either?
post #21 of 47 (permalink) Old 09-19-2019, 01:30 PM
Actually they still recommend 6 months with the standard schedule. Not sure if that still applies with their extended drain & analysis program
post #22 of 47 (permalink) Old 09-19-2019, 01:39 PM
Jimmy N.'s Avatar
In all fairness, six months with a tractor trailer is usually a crap load of miles.
post #23 of 47 (permalink) Old 09-19-2019, 01:59 PM
Or a crap load of hours. Either that or your business plan is flawed.
post #24 of 47 (permalink) Old 09-19-2019, 03:42 PM
I've been doing 15,000 miles, changing it with Valvoline Extreme, and a fleet gaurd lf16035. 15,000 miles put me at about 5 moth intervals. My Blackstone analysis say it's all working well together.
cityboy172 is offline
