Regen Frequency - Page 10 - Dodge Cummins Diesel Forum
 39Likes
post #109 of 116 (permalink) Old 11-05-2019, 02:57 AM
P2609 Fanatic
Electrojake's Avatar
FWIW my truck doesnt regen either. I'm no mechanic but this is the way I figure it...
I seldom run unloaded and do 90% highway driving.
My post turbo EGT's pretty much stay between 800F to 900F.
It is my assumption that when the Cummins engine is run under the conditions that it was truly designed to operate under it runs clean enough (hot enough) to not need raw fuel dumped into the exhaust system (a regen) in an attempt to simulate proper EGT's to burn off soot, thus when properly loaded regens do not occur.
I monitor regen status and pre & post DPF temperatures with a CTS2 mounted on the console.
Truck info is in signature.
-Ej-
Jimmy N. likes this.
2016 Longhorn 3500 4x4 short-bed in Pearl White.
Cummins HO, AISIN, CrewCab, SRW, Ride-Rite remote rear air suspension, Edge CTS2, plus the typical after-market bolt-on crap.
> Reduced current grid heater mod w/all emissions intact.<
*Hauling a 2017 Northstar Arrow-U.
Electrojake is offline
post #110 of 116 (permalink) Old 11-05-2019, 11:06 AM
upflying's Avatar
6000 miles on mine, never had a regen to my knowledge.
2018 Ram 2500 Tradesman, CC/SB/4X4/CTD/68RFE, stock, white, no bells and whistles.
Kelderman rear air springs, ARE cap, Bedrug, Carhartt seat covers, Huskyliner floor mats, Huskyliner mud flaps, Lund side steps, Tradesman emblem on tailgate
upflying is offline
post #111 of 116 (permalink) Old 11-05-2019, 11:29 AM
Ltngdrvr's Avatar
These trucks do their regeneration process all the time, but they do not give any indication of it happening, except when the DPF gets close to full. Normal regeneration is how the system maintains the health of the DPF, and goes unseen, without notification.
And, there are two types of regeneration, active and passive. Active is when the ecm directs the system to inject extra fuel to greatly increase the ehat in the DPF to burn off the soot, passive is when normal operation raises the temp in the DPF to burn off the soot, this happens under heavy steady state work loads, like towing/hauling heavy at highway speeds for long distances.
So, just because you've never seen any message pop up, doesn't mean that regeneration hasn't happened, it's an ongoing process.
Dogpatch, Jimmy N. and Gr8bawana like this.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is offline
post #112 of 116 (permalink) Old 11-05-2019, 12:22 PM
upflying's Avatar
I appreciate the education in the regen process. To clarify, I've never had an active regen due to the reasons you mentioned.
upflying is offline
post #113 of 116 (permalink) Old 11-06-2019, 02:04 AM
P2609 Fanatic
Just curious but... How would you know if/when active regen occurs?
post #114 of 116 (permalink) Old 11-06-2019, 10:30 AM
upflying's Avatar
Isnt there an EVIC warning that says "drive normally at highway speeds for 45 miles" or something like that?
upflying is offline
post #115 of 116 (permalink) Old 11-06-2019, 10:33 AM
Lins's Avatar
Just curious but... How would you know if/when active regen occurs? [IMG class=inlineimg]https://www.cumminsforum.com/forum/images/smilies/smilies-2008/confused013.gif[/IMG]
Not normally. Only if you’re driving style causes the DPF to get extremely full.
Electrojake likes this.
Lins is offline
post #116 of 116 (permalink) Old 11-06-2019, 10:47 AM
Cummins Dude
Dogpatch's Avatar
The two signs I notice is engine makes a slightly different sound and the smell of the regen cycle. You may miss it if you travel a lot on the highway when it occurs, but you sure know it in the City when it does. Once you recognize it, you’ll know it.
The more highway miles, or constant rpm, or as some have suggested under load, the less it needs to regen.
2015 Ram 3500 Laramie CCSB SRW 4x4 6.7L CTD 370hp-800tq 68RFE 3:42's HID's XB LED Fogs BD TSB Amp Steps Air Bags 5er Prep Anderson Ultimate Hitch
Dogpatch is offline
