What gear for 37s - Page 9 - Dodge Cummins Diesel Forum
 27Likes
post #97 of 122 (permalink) Old 10-10-2019, 09:45 AM
SilverFox66's Avatar
He said "I run 37ís when not towing and some 35 19.5 commercial tires when towing the toy hauler. Went with AAM 4.10ís from the factory 3.42ís " That means he was running the 37's before the switch, and now thinks he is turning less rpms. So yes, I did take it into consideration, hence my specific statement of "So, if you were turning 2,000 rpms at "X" speed in "Y" gear before..... you would turn approx 2,200 rpms now in that gear, at that speed"
Originally Posted by nick00less View Post
Did you take into consideration vehicle speed? His rpms do drop going to 37ís
Think about it for a second...
2004.5 2500/QCSB/SLT/48RE/Goerend Billet 15SS/4WD/3.73's/35-12.50-17E Ironman All Country M-T/Chrome Moto Metal 962 17x10 -24/HBS 2.5" Front & Thuren Adj Shackles Rear/ Rough Country Shocks, Dual Stabilizer & Adj Control Arms/ Synergy Steering & Adj Track Bar/Air Raid Dry/GDP Filter & Big Line Kit/4" Stainless-Turbo Back/Bush Whackers/DeeZee Bars/Bull Bar & 300W LED Light Bar/Android Double DIN Radio With Kicker Amp & JBL's/Smarty S06 & Edge CTS2 Insight
SilverFox66 is offline
post #98 of 122 (permalink) Old 10-10-2019, 10:10 AM
nick00less's Avatar
I’ll give you one more chance..switching from 35’s to 37’s does drop rpm. He didn’t switch from 37’s to 35’s and noticed the drop. He switched from 35’s to 37’s and noticed the drop..
Think about it...
'18 6.7 S472-5 Blade 2018 Build
nick00less is online now
post #99 of 122 (permalink) Old 10-10-2019, 10:18 AM
And I will give you one more chance.... he said he was ALREADY running those same 35 and 37 inch tires BEFORE the gear swap..... but didnt notice the rpm change till AFTER the gear drop, and directly related it to the gears Im well aware bigger tires turn less rpms, but he related the drop in rpms to changing gears, not changing tires If thats not what he meant, so be it... but thats what he said
post #100 of 122 (permalink) Old 10-10-2019, 10:44 AM
nick00less's Avatar
Originally Posted by SilverFox66 View Post
...thats not what he said
Letís move on shall we?
post #101 of 122 (permalink) Old 10-10-2019, 11:53 AM
bcflyfisher's Avatar
It wasn't worded all that clearly but Nick is correct. As much as it pains me to say that.
He's not comparing rpm before and after a gear change. He's saying that he needs the low gearing while towing with the 35s and enjoys the rpm drop when he switches back to the 37s for highway cruising while unloaded. It only requires a mild rewording to dig out the point.
'13 CCSB - SRW - AS69RC - 37" STT Pro - 16.5Ti - EFI by PPEI - "The AS69RC is a nightmare of a transmission. It was build [sic] with extremely low quality internal parts and its capacity to handle increased power in stock form is extremely low."
bcflyfisher is offline
post #102 of 122 (permalink) Old 10-10-2019, 11:57 AM
Originally Posted by Cummins_Michael View Post
Glad everything went well on your install....did he say what it could be that is causing the vibration under load?
he wasn't sure. said maybe with more torque being applied and softer springs maybe a little bit of axle wrap???
don't know. It only shuddered when I towed the boat.
Originally Posted by DieselMachine View Post
...now with aluminum AAM cover ...
I had the shop add this when he checked the gears on 2 days ago.
Does it hold more fluid? I was under the impression it was the same capacity as the original
'18 3500 Mega Aisin, Carli suspended
í13 3500 CCLB Aisin, Carli suspended
'11 2500 Mega, Carli suspended
kylant is offline
post #103 of 122 (permalink) Old 10-10-2019, 01:15 PM
DieselMachine's Avatar
ding ding ding winner! Whoa sorry guys didnít mean for that to get so convoluted. Absolutely saw rpm INCREASE going from 3.42 to 4.10 (with either tire setup) but now that gear swap is complete, I enjoy the DROP in rpm going from the 35ís to 37ís when Iím not towing.
bcflyfisher likes this.
2013 3500 Laramie QCLB SRW Aisin 4.10 4" BDS 285 Toyo M608z Vision 19.5s Carli track bar Fox 2.0s
1993 W250 HE351W w/ 4" TBE Gov Spring THD Fuel Pin BHAF
DieselMachine is offline
post #104 of 122 (permalink) Old 10-10-2019, 01:17 PM
Correct, same capacity as stock steel cover.
The Following User Says Thank You to DieselMachine For This Useful Post:
kylant (10-10-2019)
post #105 of 122 (permalink) Old 10-11-2019, 11:32 AM
CraigC's Avatar
Originally Posted by SRich12 View Post
No carrier change is needed!!
You reuse your same carrier.
Awesome, thanks! Now to find a shop to actually do the work.
2016 Bright Silver 2500 Laramie Longhorn CCSB 4wd Air-Ride, Black/Cattle Tan, BDS 4", 20x9 XD Badlands, 35" Cepek F-C's.
CraigC is offline
post #106 of 122 (permalink) Old 10-11-2019, 05:44 PM
I'm going to Hellbent Performance in St. Louis. Probably not far from ya. It's about 3 hours from me.
Squad2 is offline
post #107 of 122 (permalink) Old 10-14-2019, 02:16 AM Thread Starter
Was in OP shoes a couple months ago making the same decision. I run 37’s when not towing and some 35 19.5 commercial tires when towing the toy hauler. Went with AAM 4.10’s from the factory 3.42’s and am super pleased with the setup. Definitely need all that gear with the toy hauler and 35’s but when unloaded on the 37’s it drops my engine rpm some on the highway when cruising to get slightly better mileage (maybe that’s just me thinking I am by turning less rpm, either way I feel better not turning over 2000 rpm when highway cruising). 4WP did the install and did a great job. Not a single bit of sound. Would recommend adding a finned diff cover (factory AAM style). Saw some very high temps with stock steel pan when towing 200+. 150 now with aluminum AAM cover and Amsoil severe gear .
When I put in my finned cover....what torque number should i do? Reason I ask is the cover is made out of aluminum and don't want to crack it.
Thanks
2018 Ram 3500 Limited, Single Wheel, 6.7L Cummins, Aisin Transmission
Cummins_Michael is offline
post #108 of 122 (permalink) Old 10-14-2019, 03:33 AM
Cummins Freak
SRich12's Avatar
I would do about 20-23ft. lbs. on it!! That's what I did and have no leaks.
G. Mcpherson likes this.
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli Level/295 Toyo AT2's /Full Console swop w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is offline
