Rear diff oil? - Page 2 - Dodge Cummins Diesel Forum
 6Likes
post #13 of 32 (permalink) Old 08-23-2019, 06:10 PM
KATOOM's Avatar
I'm confused... I thought the 4th gen trucks have torsion differentials. Friction modifier does nothing for those.
7492, SRich12 and Jimmy N. like this.
KATOOM is offline
post #14 of 32 (permalink) Old 08-23-2019, 06:16 PM
Lins's Avatar
It's technically not REQUIRED, however some people are getting some chatter, especially warmed up, and it seems to help.
Lins is offline
post #15 of 32 (permalink) Old 08-23-2019, 06:19 PM
KATOOM's Avatar
How can it help? There's nothing but gears in there. No clutches for the friction modifier...
KATOOM is offline
post #16 of 32 (permalink) Old 08-23-2019, 06:19 PM Thread Starter
lilbxl's Avatar
Originally Posted by Ltngdrvr View Post
Originally Posted by lilbxl View Post
When backing up while turning or taking off with the wheels turning. Does it for a second or two then stops.
Yes, exactly that.
Add the tube/bottle of limited slip additive to the gear lube and that will go away.
Is there a certain brand/type I need to use?
'14 2500 Tradesman 4WD, 68RFE, Synergy Drag Link
lilbxl is offline
post #17 of 32 (permalink) Old 08-23-2019, 06:23 PM
Lins's Avatar
It's still modifying the fluid to make it more slippery for the torsen gears that are chattering? Just repeating what people have done, mine's an open diff so I don't have that issue.
Lins is offline
post #18 of 32 (permalink) Old 08-23-2019, 06:43 PM
upflying's Avatar
Make sure the seal on the bottle is intact before you leave the store. Some crooks pull return scams on oil by pouring something else in the bottle and getting a refund.
2018 Ram 2500 Tradesman, CC/SB/4X4/CTD/68RFE, stock, white, no bells and whistles.
Kelderman rear air springs, ARE cap, Bedrug, Carhartt seat covers, Huskyliner floor mats, Huskyliner mud flaps, Lund side steps, Tradesman emblem on tailgate
upflying is online now
post #19 of 32 (permalink) Old 08-23-2019, 06:49 PM Thread Starter
lilbxl's Avatar
Nothing surprises me anymore. It’s a shame.
lilbxl is offline
post #20 of 32 (permalink) Old 08-23-2019, 06:51 PM
Ltngdrvr's Avatar
No, it's all the same, just needs to be limited slip differential additive.
I use K&W because the local autozone has it about as cheap as anyplace.
https://www.crcindustries.com/produc...oz-402508.html
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is online now
post #21 of 32 (permalink) Old 08-23-2019, 06:56 PM Thread Starter
lilbxl's Avatar
I read the bottle of the valvoline and it states it has “special additives” for limited slip🏼
lilbxl is offline
post #22 of 32 (permalink) Old 08-23-2019, 06:59 PM
Ltngdrvr's Avatar
Required for the gear type diff? No.
Does it help the grinding sticking issue in the gear type diff? Absolutely.
I had this issue with my truck, and after doing some research, came across a thread where someone else had this issue, believe it was on another forum. So, I tried it and it completely eliminated the issue.
So, if something that easy to do fixes the issue, I won't complain.
Jimmy N. likes this.
post #23 of 32 (permalink) Old 08-23-2019, 07:02 PM
Ltngdrvr's Avatar
Some brands have more than others, try the valvoline without adding any more to it, if it still has the issue, you can always add a tube to it, only takes a few minutes.
And, if you fill the axle correctly, to just about 1/4"-3/8" below the fill plug, you will still have plenty of room to put the additive in.
post #24 of 32 (permalink) Old 08-23-2019, 07:03 PM Thread Starter
lilbxl's Avatar
If it does it again, I will definitely put in the additive.
lilbxl is offline
