Transmission relearn - Dodge Cummins Diesel Forum
2013-2018 General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING -
 2Likes
post #1 of 15 (permalink) Old 08-21-2019, 01:17 PM Thread Starter
lilbxl's Avatar
Just to clarify, every time the power level is changed, need to do a relearn? Asking for a friend.
'14 2500 Tradesman 4WD, 68RFE, Synergy Drag Link
lilbxl is offline
post #2 of 15 (permalink) Old 08-21-2019, 01:19 PM
From my understanding yes. Unless you love going through transmissions.
R.K.
Radride is offline
post #3 of 15 (permalink) Old 08-21-2019, 04:21 PM
pwr2tow's Avatar
Location: A-Vay-Up-Nort. U.S.A. 116*F summer 2007, -48*F winter 2018/2019.
Here yah go.
Black 2018 Laramie 3500, MC, DRW, 4WD, H.O. Cummins, Aisin, 3:73 gears. Towing a 2017 Torque 325 Toyhauler, 39', pin weight 2,370, GVWR 16,250, GCW 23,870 goosebox hitch. Retired, sort of.
pwr2tow is offline
post #4 of 15 (permalink) Old 08-21-2019, 07:12 PM
RamHunter18's Avatar
Are you talking about flashing in a new tune or changing levels with sotf switch?
18 Ram 2500 Big Horn 68rfe, CPS tune w/ aftermarket trans tune, Revmax vb, thuren springs w/ fox 2.0
RamHunter18 is offline
post #5 of 15 (permalink) Old 08-21-2019, 07:42 PM
nick00less's Avatar
No. Only when you flash your ecm with a new tune. When you turn knob it’s advised to go easy but you don’t have to do a full fledged relearn.
'18 6.7 S472-5 Blade 2018 Build
nick00less is offline
post #6 of 15 (permalink) Old 08-22-2019, 01:47 AM
RAC-1's Avatar
Originally Posted by nick00less View Post
No. Only when you flash your ecm with a new tune. When you turn knob itís advised to go easy but you donít have to do a full fledged relearn.
Not what I was told by Frank/Tom at RevMax. My understanding was that you had to do a relearn each time you changed tunes.
2014 CCLB Laramie-DJ Performance 6.7 w/stage 3 head-Rev 850-464/480 5 blade-Eaton lckrs-Highway Product service body-EFI-K5LA horns
RAC-1 is offline
post #7 of 15 (permalink) Old 08-22-2019, 07:52 AM
nick00less's Avatar
Ofcourse because they’re covering their rear ends. Totally understand. Fact is your CVI values don’t reset. And if your driving patterns don’t change and your values don’t reset then you’ll be fine. But don’t go switching from 1 to 5 and then tearing a$$ everywhere. You don’t have to do a full blown relearn however your transmission will adapt to new power levels if your driving patterns change.
I know it sounds confusing like I’m saying the same thing.
post #8 of 15 (permalink) Old 08-22-2019, 08:33 AM
Thereís a difference between changing tunes and changing power levels within a tune. Change power levels- no relearn. Have a new tune written and flash it in- relearn.
Jimmy07 is offline
post #9 of 15 (permalink) Old 08-22-2019, 09:59 AM Thread Starter
lilbxl's Avatar
Thank you all for the information. It was going to be really annoying if everytime I went to the stock tune to pull my camper I would need to do a relearn. It makes sense that if you re-flash a relearn is required. I hope the way I did the relearn will be sufficient. I have put 200 miles on the truck since tuning. I kept the throttle below 40% for over 100 miles. But I do live 9 miles outside of town, so it wasn’t all stop and go but I would slow down and let the trans down shift on the trips to town. Hopefully I’ll be ok. Again thank you all.
lilbxl is offline
post #10 of 15 (permalink) Old 08-22-2019, 01:44 PM
Ah, changing power levels is changing the tune....
R.K.
Radride is offline
post #11 of 15 (permalink) Old 08-22-2019, 05:44 PM Thread Starter
lilbxl's Avatar
I asked my tune provider and he said I do not have to do a relearn when switching power levels.
lilbxl is offline
post #12 of 15 (permalink) Old 08-22-2019, 06:16 PM
pwr2tow's Avatar
But if you don't take it easy and drive sensible allowing your transmission to relearn the extra power as nick00less mentioned you'll be back here like everyone else proclaiming the 68rfe is junk when in fact 99% of the time its owner/operator induced.
The transmission relearns as you drive it's just you don't need to do a full relearn procedure.
Radride likes this.
pwr2tow is offline
