Can I retrofit a factory 110V inverter into my Tradesman? - Dodge Cummins Diesel Forum
 10Likes
post #1 of 17 (permalink) Old 08-13-2019, 03:45 PM Thread Starter
troverman's Avatar
I had the 110v outlet in most of my Fords...would like to have it in my current 3500 Tradesman. Can it be added? How much quid?
Thanks in advance.
2018 RAM 3500 Crew 4x4 6.7L DRW Manual Trans
2017 Ford F-250 Crew 4x4 6.7L Powerstroke
2005 GMC 3500 Regular Cab Dump Truck 4x4 6.0L
troverman is offline
post #2 of 17 (permalink) Old 08-13-2019, 03:54 PM
I have a 2017 Laramie and it comes standard in the dash. I would think you could order the replacement part and probably get it installed. Might need a tool like a Dremel to cut an opening but canít tell you for sure. The output in terms of watts is not that high as it was not able to power my kids XBox and small TV at the same time.
2017 Ram 2500 MegaCab SRW with Rambox and factory air suspension.
Factory fifth wheel prep kit also installed.
dsol is offline
post #3 of 17 (permalink) Old 08-13-2019, 04:36 PM
Walker111's Avatar
It would be cheaper to retrofit an aftermarket unit. I’ve looked into it on my truck, even have the dash unit and under seat unit, But the wiring is not there. You could add that too but it’s still easier and more than likely cheaper to hook up an aftermarket unit.
RayK likes this.
16 CTD 2500 Bright White Crew Cab
Walker111 is online now
post #4 of 17 (permalink) Old 08-13-2019, 06:15 PM
some discussion here about it..
https://www.ramforum.com/threads/add...in-dash.72362/
2018 Ram 2500 Tradesman, CC/SB/4X4/CTD/68RFE, stock, white, no bells and whistles.
Kelderman rear air springs, ARE cap, Bedrug, Carhartt seat covers, Huskyliner floor mats, Huskyliner mud flaps, Lund side steps, Tradesman emblem on tailgate
upflying is offline
post #5 of 17 (permalink) Old 08-13-2019, 06:37 PM
Originally Posted by upflying View Post
That discussion is about adding it to a pre-2017 ram, so the wiring and connectors will be a little different than his 2018.
Thanks in advance.
You should be able to add it exactly like factory for just under 166 quid. You need to build one harness, add a few wires to a few existing connectors, add one wire to the BCM, and turn it on with AlfaOBD, nothing too hard. I will say though- this is one factory feature that I added that I would give back. The only reason I added it (besides the fact that I like figuring out and adding all the factory upgrades to my tradesman) was to power my Milwaukee 18v battery charger. About 30 seconds after I threw a battery on the charger, the outlet shut down due to overload. This effectively makes it strong enough to only be a phone charger, of which I already have USB ports for.
I would suggest an aftermarket inverter if you plan on doing anything else with it than charging a laptop.
RayK and ramrocker like this.
Jimmy07 is offline
post #6 of 17 (permalink) Old 08-13-2019, 07:01 PM
Ltngdrvr's Avatar
Why? What is the difference in the 2018 wiring than earlier trucks?
CCV reset/seatbelt chime disable
Ltngdrvr is offline
post #7 of 17 (permalink) Old 08-13-2019, 07:28 PM
The outlet is a different part number with the 2017+ using a 6 pin connector vs an 8 pin connector previously. The park lamp feed circuit and indicator light signal is no longer used on the new outlet. This is because the indicator light gets its signal from the BCM, now. The connectors at the kick panel have a different circuit layout. Little differences that are enough to not be able to use the exact instructions for pre-2017s, just like the window switch connectors went from two connectors to one connector in 2016, and the brake controller module switched two circuits in 2016. Enough for FCA to keep those whoíve figured out the wiring and connectors on their toes so not to assume everything is the same across all 2013+ trucks.
RayK likes this.
Jimmy07 is offline
post #8 of 17 (permalink) Old 08-13-2019, 07:38 PM
Ltngdrvr's Avatar
Park lamp feed circuit on the 110v inverter in the dash???
Ltngdrvr is offline
post #9 of 17 (permalink) Old 08-13-2019, 07:48 PM
Thatís where it used to get itís signal to be illuminated at night with the lights on (same feed as cab clearance lights). The indicator status is where the light got itís signal from when in use. Now itís all through the BCM.
Pre-2017 connector:
2017+ connector:
RayK, Dogpatch, Lins and 1 others like this.
Jimmy07 is offline
post #10 of 17 (permalink) Old 08-14-2019, 11:47 AM
sethster's Avatar
Great information Jimmy
RayK likes this.
2018 Dodge Ram. G56 Transmission
MODS: Mirror light mod, Premium Cluster
sethster is offline
post #11 of 17 (permalink) Old 08-15-2019, 07:41 PM
7492's Avatar
Pre-2017 connector:
2017+ connector:
Well at least you know. Good job.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
2020 KW T370 PX9 380HP 1250lbft @ 1400 RTO14908LL
7492 is online now
post #12 of 17 (permalink) Old 08-15-2019, 08:22 PM Thread Starter
troverman's Avatar
Just saw this post, great info. Where can I get the harness / connectors, etc? Part numbers for the outlet itself?
