Did I damage my clutch? - Dodge Cummins Diesel Forum
 11Likes
post #1 of 29 (permalink) Old 07-18-2019, 07:06 AM Thread Starter
troverman's Avatar
Yesterday, 2018 RAM dually, I had an 18k lbs trailer behind the truck. Had to back into a driveway perpendicular to the road, but while headed downhill. I pulled ahead of the driveway, stopped, engaged reverse, eased the clutch out, applied power, and it began to slip and hop. I only had to push this load uphill about 40 feet until I could swing into the driveway which was level but all you could smell was burnt clutch. Afterwards everything seems normal other than the lingering smell. I know it was a lot of weight to push backwards uphill, even for a short distance. Did I do any serious damage to the clutch?
2019 RAM 3500 Crew 4x4 Cummins H.O.
2018 RAM 3500 Crew 4x4 6.7L DRW Manual Trans - previous
2017 Ford F-250 Crew 4x4 6.7L Powerstroke
troverman is offline
post #2 of 29 (permalink) Old 07-18-2019, 08:38 AM
Walker111's Avatar
Serious damage? Probably not. But you probably shortened its life a bit. Did you continue to slip and hop the 40 feet? Once you have it in gear, it shouldn't be slipping at all, especially being new. In that situation(unless a lot of turning was involved), you could've thrown it into 4-lo to give you some more gear(torque). I think they make a kit to make just the rear wheels work. What gears do you have?
Jared Herzog, N of 60 and ptisceo like this.
16 CTD 2500 Bright White Crew Cab
Walker111 is offline
post #3 of 29 (permalink) Old 07-18-2019, 08:44 AM Thread Starter
troverman's Avatar
It pretty much slipped and hopped the whole 40 feet. I was backing into a perpendicular driveway, so yeah, had to make a 90-degree turn. This is where I missed my Ford which still used manual locking hubs...if you don't lock the fronts you can have 4-low to the rear wheels and make it easier.
You could probably wire an override to the center axl disconnect on these RAMs I guess and accomplish the same. My truck has 3.73 axle gears.
post #4 of 29 (permalink) Old 07-18-2019, 08:59 AM
Walker111's Avatar
I'm kinda surprised she had problems, but for the sake of the clutch, its best to stop, reload, and get it done smooth. Here's that kit I was talking about.
https://www.genosgarage.com/product/...ors-drivetrain
post #5 of 29 (permalink) Old 07-18-2019, 09:10 AM
I have the kit and use it fairly often. It makes the OPs situation here a thing of the past. There’s a write up on my installation somewhere on TDR.
gsbrockman likes this.
Jhenderson is offline
post #6 of 29 (permalink) Old 07-18-2019, 09:10 AM Thread Starter
troverman's Avatar
Thanks for that link...sounds like I could even wire it to a factory upfitter switch, and reasonably priced. Might be just the ticket to be able to accomplish what I need to while still using a stock clutch.
post #7 of 29 (permalink) Old 07-18-2019, 10:06 AM
gremlindude's Avatar
exactly what im installing this weekend. ive used 4 low several time maneuver a loaded trailer. make life much easier
1993 W250 Ectended Cab NV4500 Maxed pump. 4K Gov.. Diamond eye 4" Exhaust. Phatshaft 62. 5X16 Restoration in process
2006 CCLB 3500 Dually G56. SOLD 2018 Mega Dually G56
gremlindude is offline
post #8 of 29 (permalink) Old 07-18-2019, 10:22 AM
Yea I dont hesitate to use 4 low even with 10-12K behind me. Id like to get that kit but I have the manual lver on the floor, does it still work?
2018 3500 cc lb 4x4 g56
ronheater70 is offline
post #9 of 29 (permalink) Old 07-18-2019, 10:44 AM
Walker111's Avatar
Yes it does
post #10 of 29 (permalink) Old 07-18-2019, 11:47 AM Thread Starter
troverman's Avatar
People are so against the 4x4 selector knob on the dash "they'd rather have the manual floor shifter" but they fail to realize that even the floor shifter has a switch in it that commands the electrically-operated central axle disconnect to connect. Rant over.
Yeah, I think this kit is going to help.
post #11 of 29 (permalink) Old 07-18-2019, 12:17 PM
I would like to use the same kit but it doesnít look like it is available for a 2008 3500. Is there a solution for
this year truck ?
huey.hano is offline
post #12 of 29 (permalink) Old 07-18-2019, 12:30 PM
I just have to ask, why didn't you approach heading uphill so you would be backing the trailer downhill rather than up?
2015 Ram Laramie CC 2500 4x4 CTD auto in Western Brown
Mods: Undercover Elite hard tonneau, Bedrug, LED tail light strip, Amp power step, AAM finned dif cover, back seat mod, cabin air filter added
Russ661 is offline
