Did my second oil change and first fuel filters change on my 2018 RAM - - Dodge Cummins Diesel Forum
 2Likes
post #1 of 18 (permalink) Old 07-16-2019, 08:21 AM Thread Starter
troverman's Avatar
My fuel filter life was at 10%. My truck has 12,500 miles or so on it. I'm doing oil changes every 6k. I know there are tons of arguments about going to 15k or longer, but I'm not here to argue about that.
Coming from a Ford 6.7L, neither oil nor fuel filter changes are as easy on the RAM. The fuel filter under the hood on the Ford is right on top and can literally be swapped out in less than one minute with zero mess. But let's move on to the RAM.
I did the fuel filters first, since you are working in the vicinity of the exhaust for the rear filter. It's nicer to have it cold and you can grab on to the pipe to move yourself around.
I started with the engine fuel filter, but it really doesn't matter the order. You drain the filter housing, which has a nice bright yellow quarter-turn pet valve, and even a drain hose. Problem is that the drain hose terminates right above the front axle. I used a kitty litter box and put it roughly under the hose, under the axle. It drains out well, pours over the axle, and ends up in the container.
I bought the dogbone combo tool from Geno's garage. It fits in the fuel filter housing cap nicely but there is very little room to turn it. However, with a little patience, it can be done. More fuel will drain out once the cap is cracked open. Take the cap off and set it on top of your engine valve cover. Remove the o-ring at the bottom of the threads on the filter housing. Smear some clean motor oil on the new o-ring and fit it into the groove on the housing. Remove the old filter; install the new filter and make sure it snaps down. Put the cap back on and snug it tight. I think a socket would be easier to remove the cap in the future.
Next I did the rear filter. Slide under the truck from the passenger side just ahead of the rear wheels. First, unplug the WIF sensor harness (blue connector, easy). This filter has a threaded drain valve in the bottom of the WIF sensor, which also threads into the bottom of the filter. Open the drain and basically nothing comes out. Use the kitty litter pan again and get it underneath. Now use a standard oil filter wrench on the lower, smaller diameter portion of the filter canister and start loosening it. At some point, diesel will come out the bottom and maybe the top too, and make a mess on your arm. Have shop towels nearby. Remove the filter the last little bit by hand, then up-end it into the container to drain out the rest of the fuel. You will smell like an oil burner technician at this point.
Crawl back out and set the oil filter on your tailgate. Put the oil filter wrench back on the filter, and the dogbone tool on the hex of the WIF sensor. Unthread the sensor from the old fuel filter. Discard the old filter. An OEM filter includes a new o-ring for the WIF sensor and a new seal ring for the filter itself. Remove the old o-ring from the WIF sensor, smear a little clean motor oil on the new o-ring, install it in the groove, and then using the two wrenches again, thread and snug the WIF sensor into the new filter canister. Now lightly smear a little clean oil on the seal and set it into place. Slide back under the truck and clean the mating surface of where the filter mounts. Now thread the new filter in, snug it but don't overtighten. Re-connect the WIF sensor blue plug. Now close the pet drain. On mine, it seemed to be the reverse of what you'd expect to open / close.
So your filters are done and you need to do the prime procedure, which is simple. Turn the key on to the second position where all your warning lights come on, wait 5 seconds, shut the key off, repeat 4 times. Now, start your engine. It might take some additional cranking, and might run choppy for a couple of seconds. Once running, check for leaks at the front and rear, and let it idle for 5 minutes or so to warm the engine oil. While it's idling, pour the diesel fuel you collected into a container. Mine was about a third of a gallon. If you live in the northeast like me, most people heat with a fuel oil furnace. I just poured my diesel into the furnace oil barrel. Otherwise, save it until you need to start a bonfire. Don't reuse it in your truck.
Shut her down and start the oil change. Slide under from the front of the truck with a 3/8" socket. Slide your oil drain pan capable of holding at least 3 gallons under the truck. There is no drain plug "bolt" but rather just a recessed plug with a square 3/8" female opening. The entire oil pan will flex and bend if you reef too hard, so just loosen it, remove the plug, and wait for it to drain. Cracking the oil filler cap and dipstick seems to help it drain faster, so you can do that too. Once some of it drains, you can commence with the filter. Some people pull off the turbo intake plumbing and do the whole procedure from the top, but I think it's quicker to do the factory-recommended through the fender method. It can be a real pain to get the large intake plumbing fully seated back on right at the turbo, and sometimes you spend more time on that than you'd like. For filter removal, go through the side fender opening with your oil filter wrench. Get it loose, then spin it down by hand. If you let the engine run too long, the filter will be extremely hot. I lower the filter down until it stops and sits against whatever is in the way underneath. I did buy the Geno's oil filter cap...thread it in place, then turn the filter sideways and out through the fender opening without spilling any. Some folks just use a zip-lock bag and let the oil spill into the bag and throw the whole thing out. But really, you should drain the oil out of the filter before discarding. At this point, even though you can't easily see it, I take a clean rag and clean the mating surface of the filter mount. Next, I prefill the new filter with fresh oil to lessen that tiny bit of extra wear during initial startup. If you do this, you need to cap the filter again or the oil will spill out when it goes through the fender sideways. Remove the cap, raise the filter, and find the threads. Tighten until it stops, then turn an extra quarter to half turn. Reinstall the drain plug and snug it. Refill the engine oil sump - I usually go a quart less in case you didn't get everything out. Start the engine, check for leaks, watch your oil pressure warning go out. Run for a minute and shut down. Let it sit for 5 or 10 minutes, then check the oil level on the dipstick. If it's low, add some or all of your leftover quart until it's full. Clean up, reset your fuel filter and oil change reminders on the dash, record your mileage and hours, and keep your receipts and documentation in a folder.
For what it's worth, I buy Rotella T6 synthetic oil - I can get 3 gallons shipped to my door with Amazon prime for $55. I use only Mopar or Fleetguard filters. On this last service, with fuel and oil, my total cost was $186. On a standard oil change, it's about $65. Compared to the dealer, you save money and have the satisfaction of doing the work yourself, getting to know your truck more, and likely doing a better job. Don't forget to grease your front driveshaft u-joint every other change.
2018 RAM 3500 Crew 4x4 6.7L DRW Manual Trans
2017 Ford F-250 Crew 4x4 6.7L Powerstroke
2005 GMC 3500 Regular Cab Dump Truck 4x4 6.0L
troverman is offline
The Following User Says Thank You to troverman For This Useful Post:
mrcyrus16 (07-17-2019)
post #2 of 18 (permalink) Old 07-16-2019, 08:51 AM
Nice writeup I do my own oil change because the dealer never drains all the oil out and they are very expensive compared to doing it yourself. As far as the fuel filters I buy them from genos and the dealer charges $100 for labour for both filters its going in Thursday for the first fuelfilter change 11000 miles a year last August.
2018 3500 drw air suspension
Gary Morency is offline
post #3 of 18 (permalink) Old 07-16-2019, 09:59 AM
Ltngdrvr's Avatar
Well, each to his own, but for me it's just so much easier to go through the top for oil filter changes. The hole in the fenderwell is just too small to work through with the cooler lines in the way, and especially reaching around the tire.
And, I added a longer drain hose to my front fuel filter, it hangs down past the steering gear, easy drain with no mess.
As to the separator drain valve not draining when you first open it, sometimes mine only trickles, but if I twist the valve back and forth some it will flow out, then crack the filter loose from the mount a little and the fuel drains out without any mess. Then close the drain and remove the filter the rest of the way. And, I rest my drain bucket/jug on top of the driveshaft, leaning against the fuel tank, so the fuel doesn't run down over the shaft.
And, of course, I've done this many times in the last 467,000 miles.
Minnow101 and BrianF like this.
CCV reset/seatbelt chime disable
Ltngdrvr is offline
post #4 of 18 (permalink) Old 07-16-2019, 11:04 AM Thread Starter
troverman's Avatar
Good tips...you've definitely got experience!
Your truck being 2WD changes a couple of things...there is probably less clearance between the wheel and the fender to access the filter through the side. Your truck is also probably a little easier to lean over the hood and access the intake plumbing.
I don't seem to have any 'cooler' lines in the way through the side...are you referring to transmission cooler lines ? (Mine is a G56).
Anyway, I'll try the rear filter drain tip next time. Made a big mess for me, just trying to warn others. My entire oil change from drain to refill and start was 40 minutes, down from 1.5 hours the first time.
post #5 of 18 (permalink) Old 07-16-2019, 11:11 AM
I need a job doing fuel filter changes, $100 that works out to like $600 per hour. Not a bad job that would be, if I could keep the trucks lined up and moving that is like making $1,200,000 a year for doing fuel filter changes. Doing the fuel filter is so much quicker and easier then the oil change.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
post #6 of 18 (permalink) Old 07-16-2019, 11:32 AM
Ltngdrvr's Avatar
Yes, manual trans trucks have a larger opening in the fenderwell since they have no cooler lines in the way. But, I'd still go through the top, with that intake tract out of the way, the oil filter area is wide open.
And, for the front fuel and oil filters, I have a terrific aluminum step platform to stand on that I got at harbor freight, best 20 bucks I've spent there.
My fuel filter change kit...
Ltngdrvr is offline
The Following User Says Thank You to Ltngdrvr For This Useful Post:
troverman (07-16-2019)
post #7 of 18 (permalink) Old 07-16-2019, 11:41 AM
Ltngdrvr's Avatar
100 bucks for the filter change labor is cheap at most dealers.
Like the dealers that charge 250 labor for the CCV filter change, they should be ashamed of themselves for screwing their customers like that!
Ltngdrvr is offline
post #8 of 18 (permalink) Old 07-16-2019, 12:00 PM
. . . Remove the cap, raise the filter, and find the threads. Tighten until it stops, then turn an extra quarter to half turn. Reinstall the drain plug and snug it . . .
Very informative write-up, Troverman! Thanks! The only thing I would suggest is turning the OEM Mopar filter 3/4's of a turn with a filter wrench (vs. 1/4 to 1/2)---after tightening it by hand. This 3/4 turn recommendation is stenciled on the outside of the OEM Mopar filter with A, B, C, & D, 90 degree markers. These markers help you gauge how much you've turned the filter. Can't speak about the procedure for other brands of oil filters. Bottom line, you definitely don't want that oil filter coming loose or leaking.
MoreTorque is offline
post #9 of 18 (permalink) Old 07-16-2019, 12:07 PM Thread Starter
troverman's Avatar
Fair enough, and good point. I have large hands and probably above average strength, so where I 'stop' hand tightening is probably further than most, but good advice nonetheless. I've changed oil on many vehicles, and you kind of just get a feel for it.
post #10 of 18 (permalink) Old 07-16-2019, 12:11 PM
Drive the truck in the bay put it on the hoist to change the rear one drop it down throw a mat on the fender drain the filter change the filter all for $100 Canadian or $75 US . A person would have to go pretty quick to do all that in 1 hr then get rid of the stinky things I used to do all my filter changes on my 02 it sticks. Plus I picked up $65 worth of beer cans this week and $40 last week at .10 each I,m still ahead $5.
post #11 of 18 (permalink) Old 07-16-2019, 12:21 PM
Well, each to his own, but for me it's just so much easier to go through the top for oil filter changes. The hole in the fenderwell is just too small to work through with the cooler lines in the way, and especially reaching around the tire . . .
I would agree it's probably easier to access the oil filter from the "top" if you're not willing to remove the front, passenger side tire (for easier access to the oil filter via the wheel well). I always rotate my tires at every oil change (6k-8k mi. every 6 mo.), so removing the tire is not really an extra step for me. With the tire removed, it's SO easy to R&R the oil filter while seated on a small garage stool. I use the cheaper Lisle 57180 oil filter plug for a spill-free removal of the old filter. The Lisle is also handy for a spill-free, pre-fill of the new oil filter (for those who do this).
post #12 of 18 (permalink) Old 07-16-2019, 01:41 PM Thread Starter
troverman's Avatar
I leave the wheel on with my dually. I wonder if the 17" tire that comes on the dually also provides a little more reach room. The manual recommended removing the tire but I can do it well enough without.
Tire wear is another annoying issue. My 12k mile 2018 is wearing out the edges of my front tires already. The rears are wearing like iron.
Although I really have no complaints against them, I dislike the cheap name "Nexen" tires that came on mine. Why the dealer ordered with the extra cost "outlined white letter" is beyond me...to advertise a cheap brand tire?
