Roof top clearence lights - Page 2 - Dodge Cummins Diesel Forum
 9Likes
post #13 of 20 (permalink) Old 07-12-2019, 05:54 AM
US ARMY Retired
Cummins0867's Avatar
I like them and always have...they're fairly easy to install. I have installed them on about every truck that I have had that didn't come with them from the factory. The OEM kit comes with a template to let you know exactly where to install. If you follow the instructions you won't have any trouble with leaking if you use the correct drill size and don't over tighten the screws on the light covers. If you have a 2500/3500 the wiring plugs in right in the cab. I have also installed them on a 1500 and I ran the wiring out under the hood. I have also installed the Ram OEM light bar that mounts right under the tailgate but above the rear license plate. These are usually only installed on dually trucks but I currently have one installed on my 2019 Ram 3500 SRW, To each their own but I have always really liked the clearance lights on trucks.
Suny and michaelrc51 like this.
'19 Laramie 3500 CCSW SRW 4X4, Aisin 3:73's
SOLD: '17 Laramie 2500 CCSW 4X4 3.42's
SOLD: '11 Laramie 3500 CCSW SRW 4X4 3:73's
SOLD: '08 Laramie 2500 CCSW 4X4 3:73's "2Timothy1:7"
Cummins0867 is offline
post #14 of 20 (permalink) Old 07-12-2019, 09:15 AM
cumminsdieselfreak's Avatar
I had them thrown in as part of the deal on my 2018. Out of pocket my dealer charges $300 for labor and kit.
Current: 2018 G56
2013, 2007.5, 2007(5.9), 2006, 2002, 2000 Dodge 2500 - SOLD
cumminsdieselfreak is offline
post #15 of 20 (permalink) Old 08-25-2019, 01:43 PM
I'm having them added on my 18 I just bought too. Sure hope they don't leak LOL. Just under $300 for the install and parts.
18 2500 Mega - White, sport appearance package, fox 2.0 in front, leveling kit...stock otherwise
06 2500 Mega - SOLD 3/2018
b5dart70 is offline
post #16 of 20 (permalink) Old 08-25-2019, 02:53 PM
Cummins_Michael's Avatar
Snap some photos when the get you fixed up.
Cab lights look awesome on any truck.
b5dart70 likes this.
2018 Ram 3500 Limited, Single Wheel, 6.7L Cummins, Aisin Transmission
Cummins_Michael is offline
post #17 of 20 (permalink) Old 08-25-2019, 03:30 PM
Originally Posted by lpennock View Post
I think the snow plow package includes them also.
Sent from my SM-T350 using Tapatalk
My truck has the snow plow prep package and shows the clearance lights as an added option on the sticker. The only things I know that the package comes with are the heavier alternator, skid plate package, and heavier front suspension. My truck sits like it has a small leveling kit on it from the factory.
98 24v 3500 dually 4x4
18 6.7 3500 4x4 G56
Baradium is offline
post #18 of 20 (permalink) Old 08-25-2019, 05:49 PM
Jared Herzog's Avatar
I have them on my 15 DRW since they have to come factory. As a builder/roofer i hate unnecessary/extra holes in a roof. Even if installed right they will eventually leak. I have three of mine leak already and had them replaced. The platform the screw goes into is unsupported so just barely finger tight is about all they can take before cracking the housing. Mine came cracked from the factory installation.
My plan is to have them removed and the holes filled and the roof repainted. It is on my short list as my warranty is about to expire. Or it may be done after we get some Texas hail.
Also, there was an updated cab light gasket. So the lights that were leaking had to be returned by the dealer for the new seal type. When the second set came one was still wrong but they installed it anyway. This is aggravating because now i have two gasket types on my roof. For this updated thicker/softer gasket to look balanced i moved them to the outer position. This gasket also cups over the sides some. This makes a pool for the water so sit in. Thats the second issue with the screw that goes into the top. It is recessed with a cheap hard plastic washer. This creates a pool where water sits and percolates through past the gasket and into the light. It makes itself known as it starts to fog up. I inspect mine every week for now to make sure they are dry so my headliner stays nice. The older two lights are much more damaged by UV. The leak was discovered a couple of weeks after purchasing the truck new. At this time the lights were swapped. The newer lights have held up to UV and still look new.
All my lights are now siliconed in and the screws with their recessed hole is filled. The silicone is also around the perimeter of my third brake light.
I have no idea why someone would decide to willingly add these things.
When i do paint the roof i want to find a way to seal five LED bulbs to the windshield inside the cab near the headliner so i have the required lights without the necessary holes in the roof.
The thicker gasket traps more water and is the supposed new part. The photos are two of the three replacements. In the image with the older flatter gasket you can see the original light that is significantly more UV damaged. It is a bit hard to tell but the older style gasket is pretty flat without the water trapping lip.
Ram 14 2500 RIP 14,700 Stock. 68RFE."The Lemon"
Ram 15 3500 Dually. Stock. Aisin. N Fab wheel to wheel. Weather Tech Mats. Big D Steering Box Brace.
Jared Herzog is offline
post #19 of 20 (permalink) Old 08-26-2019, 07:16 AM
My 2015 2500 megacab has them, just ordered that way. I love them, just the look I like. No problems with them leaking. I wonder if the people who have issues had them dealer installed as opposed to factory ordered.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
post #20 of 20 (permalink) Old 08-26-2019, 07:49 AM
I have cab lights on my truck. Theyíre aftermarket, so is my sunroof. One cab light leaked, the water took out the controls for the sunroof and it got stuck open. Dealership gave a lifetime warranty on it, and had it fixed the next day.
Even having aftermarket lights that failed, Iíd still have them again.
Personally, Iím much more concerned about my leaking 3rd Brake Light because that came factory and hasnít been touched since.
2016 Ram 2500 CCSB 6.7L CTD 4x4 Outdoorsman. 18in Dropstar 645B -12 wrapped in 35x12.5r18 Nitto Ridge Grapplers "SAP Clone". EFI Live by Anarchy, 5in Flo Pro TBE.
HFolb23 is online now
